[Geoserver-devel] Build failed in Hudson: geoserver-1.6.x #211
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/211/changes
[...truncated 17 lines...]
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer 1.6.x
[INFO] GeoServer Maven Plugins
[INFO] Plugins configuration files
[INFO] Configuration Deployment PlugIn
[INFO] Core Platform Module
[INFO] Data Module
[INFO] Open Web Service Model
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Validation Module
[INFO] Web Feature Service Model
[INFO] Web Feature Service Module
[INFO] Versioning Web Feature Service Model
[INFO] Versioned Web Feature Service Module
[INFO] Web Map Service Module
[INFO] Web Application Module
[INFO] Community Space
[INFO] Geoserver REST Support Code
[INFO] REST SLD service
[INFO] CSV thematic mapping module
[INFO] REST Configuration Service Module
[INFO] User Query Service Module
[INFO] Building GeoServer 1.6.x
[INFO] artifact org.apache.maven.plugins:maven-clean-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-clean-plugin: checking for updates from central
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-surefire-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-surefire-plugin: checking for updates from central
[INFO] artifact org.codehaus.mojo:cobertura-maven-plugin: checking for updates from refractions-plugins
[INFO] artifact org.codehaus.mojo:cobertura-maven-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-jar-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-jar-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-source-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-source-plugin: checking for updates from central
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/target
[INFO] artifact org.apache.maven.plugins:maven-site-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-site-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-install-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-install-plugin: checking for updates from central
[INFO] [site:attach-descriptor]
[INFO] snapshot org.geotools:gt2-api:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-library:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-modules:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-referencing:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-metadata:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-main:2.4-SNAPSHOT: checking for updates from refractions
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/target/geoserver-1.6-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/pom.xml to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.6-SNAPSHOT/geoserver-1.6-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/target/geoserver-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.6-SNAPSHOT/geoserver-1.6-SNAPSHOT-tests.jar
[INFO] Building GeoServer Maven Plugins
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/target
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/target/maven-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/1.6-SNAPSHOT/maven-1.6-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/target/maven-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/1.6-SNAPSHOT/maven-1.6-SNAPSHOT-tests.jar
[INFO] Building Plugins configuration files
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from central
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.6-SNAPSHOT/build-configs-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.6-SNAPSHOT/build-configs-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.6-SNAPSHOT/build-configs-1.6-SNAPSHOT-sources.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from central
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target/config-1.6-SNAPSHOT.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target/config-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target/config-1.6-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target/config-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.6-SNAPSHOT/config-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target/config-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.6-SNAPSHOT/config-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target/config-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.6-SNAPSHOT/config-1.6-SNAPSHOT-sources.jar
[INFO] [plugin:updateRegistry]
[INFO] Building Core Platform Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target
[INFO] Compiling 8 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/surefire-reports
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/platform-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/platform-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/platform-1.6-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/platform-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.6-SNAPSHOT/platform-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/platform-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.6-SNAPSHOT/platform-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/platform/target/platform-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.6-SNAPSHOT/platform-1.6-SNAPSHOT-sources.jar
[INFO] Building Data Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target
[INFO] snapshot org.geotools:gt2-epsg-hsql:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-plugin:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-gml2:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-unsupported:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-coverage:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-xsd:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-graph:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-extension:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.demo:gt2-demo-property:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.demo:gt2-demo:2.4-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 16 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/src/main/java/org/geoserver/feature/retype/RetypingFeatureSource.java :[29,7] org.geoserver.feature.retype.RetypingFeatureSource is not abstract and does not override abstract method getQueryCapabilities() in org.geotools.data.FeatureSource
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/src/main/java/org/geoserver/feature/retype/RetypingFeatureStore.java :[25,7] org.geoserver.feature.retype.RetypingFeatureStore is not abstract and does not override abstract method getQueryCapabilities() in org.geotools.data.FeatureSource
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/data/src/main/java/org/geoserver/feature/retype/RetypingFeatureLocking.java :[18,0] org.geoserver.feature.retype.RetypingFeatureLocking is not abstract and does not override abstract method getQueryCapabilities() in org.geotools.data.FeatureSource
[INFO] Total time: 18 seconds
[INFO] Finished at: Thu May 08 05:55:14 EDT 2008
[INFO] Final Memory: 24M/43M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/212/changes
[INFO] Data Module
[INFO] Main Module
[INFO] [jar:jar]
[INFO] [jar:jar]
T E S T S
Results :
[INFO] [jar:jar]
[INFO] Total time: 17 seconds
[INFO] Finished at: Thu May 08 06:34:36 EDT 2008
[INFO] Final Memory: 23M/42M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/213/changes
Changes:
[aaime] GEOS-1904, Dump data loading stack traces with a normal logging configuration, as it is now it makes error diagnosis just too hard
[INFO] Data Module
[INFO] Main Module
[INFO] [jar:jar]
[INFO] [jar:jar]
T E S T S
Results :
[INFO] [jar:jar]
[INFO] Finished at: Thu May 08 10:51:56 EDT 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/214/changes
