[Geoserver-devel] Build failed in Hudson: geoserver-1.6.x #242
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/242/changes
Changes:
[bmmpxf] Slight textual changes. Nothing fancy. -MDP
[bmmpxf] Standardized version numbering to 1.6.(n+1)-beta in all files,
where n is the latest stable release. In this case, files were
changed to 1.6.5-beta. This will make it easier to do future
releases. -MDP
[...truncated 963 lines...]
[INFO] snapshot org.geotools:gt2-render:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-shapefile-renderer:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wfs:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wms:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml:2.4-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 129 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/classes
[INFO] [resources:testResources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:testCompile]
[INFO] Compiling 26 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.map.gif.GifMapProducerTest
May 27, 2008 2:54:03 PM org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest testSimpleGetMapQuery
INFO: about to create map ctx for BasicPolygons with bounds ReferencedEnvelope[-2.0 : 2.0, -1.0 : 6.0]
27 May 14:54:04 ERROR [geotools.rendering] -
java.lang.NullPointerException
  at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1538)
  at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:641)
  at org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(ShapefileRenderer.java:1461)
  at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1331)
  at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:262)
  at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:310)
  at org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest.testSimpleGetMapQuery(DefaultRasterMapProducerTest.java:119)
  at junit.framework.TestCase.runTest(TestCase.java:154)
  at junit.framework.TestCase.runBare(TestCase.java:127)
  at junit.framework.TestCase.run(TestCase.java:118)
  at junit.framework.TestSuite.runTest(TestSuite.java:208)
  at junit.framework.TestSuite.run(TestSuite.java:203)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:22)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:19)
  at junit.extensions.TestSetup.run(TestSetup.java:23)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
May 27, 2008 2:54:04 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testSimpleGetMapQuery: pixel count=90000 non bg pixels: 90000
INFO: testDefaultStyle Streams: pixel count=192000 non bg pixels: 3777
INFO: testDefaultStyle Bridges: pixel count=192000 non bg pixels: 49
INFO: testDefaultStyle BasicPolygons: pixel count=280000 non bg pixels: 101880
INFO: testDefaultStyle Forests: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle NamedPlaces: pixel count=280000 non bg pixels: 56
INFO: testDefaultStyle Buildings: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle RoadSegments: pixel count=280000 non bg pixels: 63
INFO: testDefaultStyle DividedRoutes: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle Lakes: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle MapNeatline: pixel count=280000 non bg pixels: 49
INFO: testDefaultStyle Ponds: pixel count=280000 non bg pixels: 49
May 27, 2008 2:54:05 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testBlueLake: pixel count=250000 non bg pixels: 250000
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.144 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.412 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.548 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.333 sec
Running org.vfny.geoserver.wms.responses.palette.CustomPaletteBuilderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.04 sec
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.32 sec
Running org.vfny.geoserver.wms.DescribeLayerTest
<WMS_DescribeLayerResponse version="1.1.1">
<LayerDescription name="cite:Forests" wfs="src/test/resources/geoserver/wfs/WfsDispatcher?">
<Query typeName="cite:Forests"/>
</LayerDescription>
</WMS_DescribeLayerResponse>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.272 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.244 sec
Running org.geoserver.wms.CapabilitiesTest
May 27, 2008 2:54:08 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.7 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMZMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.344 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.vfny.geoserver.wms.responses.map.png.GetMapTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.88 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.4 sec
Running org.vfny.geoserver.wms.responses.map.legend.DefaultRasterLegendProducerTest
May 27, 2008 2:54:10 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.204 sec
Running org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest
May 27, 2008 2:54:10 PM org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest testSimpleGetMapQuery
27 May 14:54:10 ERROR [geotools.rendering] -
May 27, 2008 2:54:11 PM org.geoserver.wms.WMSTestSupport assertNotBlank
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.316 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGTest
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.38 sec <<< FAILURE!
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
org.vfny.geoserver.wms.WmsException: No such style: ThisStyleDoesNotExists
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.252 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest
<table border='1'>
<tr>
  <th colspan='2' scope='col'>testType</th>
</tr>
<tr>
  <td>string</td> <td> three </td>
</tr>
<tr>
  <td>int</td> <td> 3 </td>
</tr>
<tr>
  <td>double</td> <td> 3.3 </td>
</tr>
<tr>
  <td>geom</td> <td> [GEOMETRY] </td>
</tr>
</table>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.212 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.204 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.2 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.228 sec
Results :
Tests in error:
  testBatikSvgGenerator(org.vfny.geoserver.wms.responses.map.svg.SVGTest)
Tests run: 68, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 13 seconds
[INFO] Finished at: Tue May 27 14:54:14 EDT 2008
[INFO] Final Memory: 33M/63M
Failed to send e-mail to bmmpxf because no e-mail address is known, and no default e-mail domain is configured
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/243/changes
