See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/306/changes
Changes:
[aaime] GEOS-2052, Can't disable caching and remove the caching time (in feature type configuration). Also added i18n error messages that were missing
[aaime] GEOS-2050, Proxy filter engages even if the proxying is not enabled
[...truncated 1131 lines...]
INFO: testDefaultStyle Forests: pixel count=280000 non bg pixels: 289
Jul 18, 2008 4:57:58 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testDefaultStyle NamedPlaces: pixel count=280000 non bg pixels: 306
INFO: testDefaultStyle Buildings: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle RoadSegments: pixel count=280000 non bg pixels: 323
INFO: testDefaultStyle DividedRoutes: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle Lakes: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle MapNeatline: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle Ponds: pixel count=280000 non bg pixels: 289
Jul 18, 2008 4:57:59 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testBlueLake: pixel count=250000 non bg pixels: 250000
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.363 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
org.vfny.geoserver.wms.WmsException: No such style: ThisStyleDoesNotExists
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.592 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest
<table border='1'>
<tr>
<th colspan='2' scope='col'>testType</th>
</tr>
<tr>
<td>string</td> <td> three </td>
</tr>
<tr>
<td>int</td> <td> 3 </td>
</tr>
<tr>
<td>double</td> <td> 3.3 </td>
</tr>
<tr>
<td>geom</td> <td> [GEOMETRY] </td>
</tr>
</table>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.256 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.21 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.22 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.206 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.263 sec
Results :
Tests run: 73, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6.5-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6.5-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6.5-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6.5-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.6.5-SNAPSHOT/wms-1.6.5-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6.5-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.6.5-SNAPSHOT/wms-1.6.5-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6.5-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.6.5-SNAPSHOT/wms-1.6.5-SNAPSHOT-sources.jar
[INFO] Building Web Application Module
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from central
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target
[INFO] [config:clean {execution: configClean}]
clean:
[delete] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/src/main/webapp/data
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 109 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 3 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/surefire-reports
T E S T S
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 7, Failures: 0, Errors: 7, Skipped: 0, Time elapsed: 0.513 sec <<< FAILURE!
Running org.vfny.geoserver.jetty.SpringContextTest
Jul 18, 2008 4:58:51 PM org.vfny.geoserver.global.Data loadFeatureTypes
INFO: Loading feature type 'cdf:::Deletes' (layer 1/29)
Jul 18, 2008 4:58:52 PM org.vfny.geoserver.global.Data loadFeatureTypes
INFO: Loading feature type 'cdf:::Fifteen' (layer 2/29)
INFO: Loading feature type 'cdf:::Inserts' (layer 3/29)
INFO: Loading feature type 'cdf:::Locks' (layer 4/29)
INFO: Loading feature type 'cdf:::Nulls' (layer 5/29)
INFO: Loading feature type 'cdf:::Other' (layer 6/29)
INFO: Loading feature type 'cdf:::Seven' (layer 7/29)
INFO: Loading feature type 'cdf:::Updates' (layer 8/29)
INFO: Loading feature type 'cgf:::Lines' (layer 9/29)
INFO: Loading feature type 'cgf:::MLines' (layer 10/29)
INFO: Loading feature type 'cgf:::MPoints' (layer 11/29)
INFO: Loading feature type 'cgf:::MPolygons' (layer 12/29)
INFO: Loading feature type 'cgf:::Points' (layer 13/29)
INFO: Loading feature type 'cgf:::Polygons' (layer 14/29)
INFO: Loading feature type 'cite:::BasicPolygons' (layer 15/29)
INFO: Loading feature type 'cite:::Bridges' (layer 16/29)
INFO: Loading feature type 'cite:::Buildings' (layer 17/29)
INFO: Loading feature type 'cite:::DividedRoutes' (layer 18/29)
INFO: Loading feature type 'cite:::Forests' (layer 19/29)
INFO: Loading feature type 'cite:::Geometryless' (layer 20/29)
INFO: Loading feature type 'cite:::Lakes' (layer 21/29)
INFO: Loading feature type 'cite:::MapNeatline' (layer 22/29)
INFO: Loading feature type 'cite:::NamedPlaces' (layer 23/29)
INFO: Loading feature type 'cite:::Ponds' (layer 24/29)
INFO: Loading feature type 'cite:::RoadSegments' (layer 25/29)
INFO: Loading feature type 'cite:::Streams' (layer 26/29)
INFO: Loading feature type 'sf:::AggregateGeoFeature' (layer 27/29)
INFO: Loading feature type 'sf:::GenericEntity' (layer 28/29)
INFO: Loading feature type 'sf:::PrimitiveGeoFeature' (layer 29/29)
Jul 18, 2008 4:58:53 PM org.vfny.geoserver.global.Data loadFeatureTypes
Jul 18, 2008 4:58:53 PM org.vfny.geoserver.global.GeoServer destroy
INFO: Disposing DataStores at GeoServer shutdown...
INFO: Done disposing datastores.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.329 sec
Results :
Tests in error:
testInit(org.geoserver.filters.ReverseProxyFilterTest)
testDoFilterDisabled(org.geoserver.filters.ReverseProxyFilterTest)
testDoFilterExtraProxyContext(org.geoserver.filters.ReverseProxyFilterTest)
testDoFilterNonMatchingMime(org.geoserver.filters.ReverseProxyFilterTest)
testDoFilterRelativeUrl(org.geoserver.filters.ReverseProxyFilterTest)
testDoFilterProxyRoot(org.geoserver.filters.ReverseProxyFilterTest)
testDoFilterContentContainsProxifiedUrl(org.geoserver.filters.ReverseProxyFilterTest)
Tests run: 8, Failures: 0, Errors: 7, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target/surefire-reports for the individual test results.
[INFO] Total time: 7 minutes 19 seconds
[INFO] Finished at: Fri Jul 18 16:58:53 EDT 2008
[INFO] Final Memory: 31M/63M
