[Geoserver-devel] Build failed in Hudson: geoserver-1.6.x #317
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/317/changes
Changes:
[arneke] GEOS-2121 buffer size in ShapeZipOutputFormat set to 4kb
[...truncated 5756 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Aug 12, 2008 2:59:19 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testSimpleGetMapQuery: pixel count=90000 non bg pixels: 90000
INFO: testDefaultStyle Streams: pixel count=192000 non bg pixels: 3877
INFO: testDefaultStyle Bridges: pixel count=192000 non bg pixels: 289
INFO: testDefaultStyle BasicPolygons: pixel count=280000 non bg pixels: 101880
INFO: testDefaultStyle Forests: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle NamedPlaces: pixel count=280000 non bg pixels: 306
INFO: testDefaultStyle Buildings: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle RoadSegments: pixel count=280000 non bg pixels: 323
INFO: testDefaultStyle DividedRoutes: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle Lakes: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle MapNeatline: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle Ponds: pixel count=280000 non bg pixels: 289
Aug 12, 2008 2:59:20 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testBlueLake: pixel count=250000 non bg pixels: 250000
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.109 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.459 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.579 sec
Running org.vfny.geoserver.wms.responses.palette.CustomPaletteBuilderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.044 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.361 sec
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.367 sec
Running org.vfny.geoserver.wms.DescribeLayerTest
<WMS_DescribeLayerResponse version="1.1.1">
<LayerDescription name="cite:Forests" wfs="src/test/resources/geoserver/wfs/WfsDispatcher?">
<Query typeName="cite:Forests"/>
</LayerDescription>
</WMS_DescribeLayerResponse>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.301 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.277 sec
Running org.geoserver.wms.CapabilitiesTest
Aug 12, 2008 2:59:23 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.658 sec
Running org.vfny.geoserver.wms.responses.map.png.GetMapTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.016 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMZMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.301 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.282 sec
Running org.vfny.geoserver.wms.responses.map.legend.DefaultRasterLegendProducerTest
Aug 12, 2008 2:59:25 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.234 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.208 sec
Running org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest
12 Aug 14:59:26 ERROR [geotools.rendering] -
java.lang.NullPointerException
  at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1538)
  at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:641)
  at org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(ShapefileRenderer.java:1461)
  at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1331)
  at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:262)
  at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:317)
  at org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest.testSimpleGetMapQuery(DefaultRasterMapProducerTest.java:119)
  at junit.framework.TestCase.runTest(TestCase.java:154)
  at junit.framework.TestCase.runBare(TestCase.java:127)
  at junit.framework.TestCase.run(TestCase.java:118)
  at junit.framework.TestSuite.runTest(TestSuite.java:208)
  at junit.framework.TestSuite.run(TestSuite.java:203)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:22)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:19)
  at junit.extensions.TestSetup.run(TestSetup.java:23)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
Aug 12, 2008 2:59:26 PM org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest testSimpleGetMapQuery
INFO: about to create map ctx for BasicPolygons with bounds ReferencedEnvelope[-2.0 : 2.0, -1.0 : 6.0]
Aug 12, 2008 2:59:26 PM org.geoserver.wms.WMSTestSupport assertNotBlank
Aug 12, 2008 2:59:27 PM org.geoserver.wms.WMSTestSupport assertNotBlank
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.216 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
org.vfny.geoserver.wms.WmsException: No such style: ThisStyleDoesNotExists
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.598 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest
<table border='1'>
<tr>
  <th colspan='2' scope='col'>testType</th>
</tr>
<tr>
  <td>string</td> <td> three </td>
</tr>
<tr>
  <td>int</td> <td> 3 </td>
</tr>
<tr>
  <td>double</td> <td> 3.3 </td>
</tr>
<tr>
  <td>geom</td> <td> [GEOMETRY] </td>
</tr>
</table>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.246 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.215 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.218 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.202 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.265 sec
Results :
Tests run: 73, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6.5-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6.5-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6.5-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6.5-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.6.5-SNAPSHOT/wms-1.6.5-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6.5-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.6.5-SNAPSHOT/wms-1.6.5-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/wms-1.6.5-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.6.5-SNAPSHOT/wms-1.6.5-SNAPSHOT-sources.jar
[INFO] Building Web Application Module
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from central
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/target
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/src/main/webapp/data
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot xerces:xercesImpl:1.6.5-SNAPSHOT: checking for updates from refractions
Downloading: http://lists.refractions.net/m2//xerces/xercesImpl/1.6.5-SNAPSHOT/xercesImpl-1.6.5-SNAPSHOT.pom
Downloading: http://lists.refractions.net/m2//xerces/xercesImpl/1.6.5-SNAPSHOT/xercesImpl-1.6.5-SNAPSHOT.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) xerces:xercesImpl:jar:1.6.5-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=xerces -DartifactId=xercesImpl -Dversion=1.6.5-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=xerces -DartifactId=xercesImpl -Dversion=1.6.5-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver:web:jar:1.6.5-SNAPSHOT
    2) xerces:xercesImpl:jar:1.6.5-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  maven-restlet (http://maven.restlet.org),
  refractions (http://lists.refractions.net/m2/),
  mortbay (http://www.mortbay.org/maven2/release),
  geotools (http://maven.geotools.fr/repository/)
[INFO] Total time: 8 minutes 26 seconds
[INFO] Finished at: Tue Aug 12 15:00:05 EDT 2008
[INFO] Final Memory: 32M/63M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/318/changes
