See http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/352/changes
[...truncated 937 lines...]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target
[INFO] [resources:resources]
[WARNING] Using platform encoding (UTF-8 actually) to copy filtered resources, i.e. build is platform dependent!
[INFO] Copying 15 resources
[INFO] [compiler:compile]
[INFO] Compiling 130 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/classes
[INFO] [resources:testResources]
[INFO] Copying 7 resources
[INFO] [compiler:testCompile]
[INFO] Compiling 26 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.map.gif.GifMapProducerTest
Oct 22, 2008 8:30:34 AM org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest testSimpleGetMapQuery
INFO: about to create map ctx for BasicPolygons with bounds ReferencedEnvelope[-2.0 : 2.0, -1.0 : 6.0]
22 Oct 08:30:34 ERROR [geotools.rendering] -
java.lang.NullPointerException
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1538)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:641)
at org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(ShapefileRenderer.java:1461)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1331)
at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:262)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:317)
at org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest.testSimpleGetMapQuery(DefaultRasterMapProducerTest.java:119)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:22)
at junit.extensions.TestSetup$1.protect(TestSetup.java:19)
at junit.extensions.TestSetup.run(TestSetup.java:23)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Oct 22, 2008 8:30:34 AM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testSimpleGetMapQuery: pixel count=90000 non bg pixels: 90000
INFO: testDefaultStyle Streams: pixel count=192000 non bg pixels: 3877
INFO: testDefaultStyle Bridges: pixel count=192000 non bg pixels: 289
INFO: testDefaultStyle BasicPolygons: pixel count=280000 non bg pixels: 101880
INFO: testDefaultStyle Forests: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle NamedPlaces: pixel count=280000 non bg pixels: 306
Oct 22, 2008 8:30:35 AM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testDefaultStyle Buildings: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle RoadSegments: pixel count=280000 non bg pixels: 323
INFO: testDefaultStyle DividedRoutes: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle Lakes: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle MapNeatline: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle Ponds: pixel count=280000 non bg pixels: 289
INFO: testBlueLake: pixel count=250000 non bg pixels: 250000
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.076 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.471 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.571 sec
Running org.vfny.geoserver.wms.responses.palette.CustomPaletteBuilderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.358 sec
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.413 sec
Running org.vfny.geoserver.wms.DescribeLayerTest
<WMS_DescribeLayerResponse version="1.1.1">
<LayerDescription name="cite:Forests" wfs="src/test/resources/geoserver/wfs/WfsDispatcher?">
<Query typeName="cite:Forests"/>
</LayerDescription>
</WMS_DescribeLayerResponse>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.3 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.28 sec
Running org.geoserver.wms.CapabilitiesTest
Oct 22, 2008 8:30:38 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.694 sec
Running org.vfny.geoserver.wms.responses.map.png.GetMapTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.012 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMZMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.307 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.292 sec
Running org.vfny.geoserver.wms.responses.map.legend.DefaultRasterLegendProducerTest
Oct 22, 2008 8:30:40 AM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.221 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGTest
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.141 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest
22 Oct 08:30:42 ERROR [geotools.rendering] -
Oct 22, 2008 8:30:42 AM org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest testSimpleGetMapQuery
Oct 22, 2008 8:30:42 AM org.geoserver.wms.WMSTestSupport assertNotBlank
Oct 22, 2008 8:30:43 AM org.geoserver.wms.WMSTestSupport assertNotBlank
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.245 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
org.vfny.geoserver.wms.WmsException: No such style: ThisStyleDoesNotExists
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.714 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest
<table border='1'>
<tr>
<th colspan='2' scope='col'>testType</th>
</tr>
<tr>
<td>string</td> <td> three </td>
</tr>
<tr>
<td>int</td> <td> 3 </td>
</tr>
<tr>
<td>double</td> <td> 3.3 </td>
</tr>
<tr>
<td>geom</td> <td> [GEOMETRY] </td>
</tr>
</table>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.245 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.216 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.226 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.206 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.273 sec
Results :
Tests in error:
testBatikSvgGenerator(org.vfny.geoserver.wms.responses.map.svg.SVGTest)
Tests run: 73, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 19 seconds
[INFO] Finished at: Wed Oct 22 08:30:46 EDT 2008
[INFO] Final Memory: 32M/63M
