[Geoserver-devel] Build failed in Hudson: geoserver-1.6.x #361
See http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/361/changes
Changes:
[bencaradocdavies] Fixed broken externals for minimal config (pointed them at this branch, not trunk)
[...truncated 1162 lines...]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/target/geoserver-1.6.6-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
Downloading: http://lists.refractions.net/m2//org/apache/maven/maven-archiver/2.4/maven-archiver-2.4.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/maven-archiver/2.4/maven-archiver-2.4.pom
3/3K
3K downloaded
Downloading: http://lists.refractions.net/m2//org/codehaus/plexus/plexus-archiver/1.0-alpha-11/plexus-archiver-1.0-alpha-11.pom
Downloading: http://repo1.maven.org/maven2/org/codehaus/plexus/plexus-archiver/1.0-alpha-11/plexus-archiver-1.0-alpha-11.pom
1/1K
1/1K
1K downloaded
Downloading: http://lists.refractions.net/m2//org/codehaus/plexus/plexus-io/1.0-alpha-3/plexus-io-1.0-alpha-3.pom
Downloading: http://repo1.maven.org/maven2/org/codehaus/plexus/plexus-io/1.0-alpha-3/plexus-io-1.0-alpha-3.pom
1/1K
1K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/maven-model/2.0.9/maven-model-2.0.9.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/maven-model/2.0.9/maven-model-2.0.9.pom
2/3K
3/3K
3K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/maven/2.0.9/maven-2.0.9.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/maven/2.0.9/maven-2.0.9.pom
1/18K
4/18K
5/18K
9/18K
9/18K
12/18K
16/18K
18/18K
18K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/maven-plugin-api/2.0.9/maven-plugin-api-2.0.9.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/maven-plugin-api/2.0.9/maven-plugin-api-2.0.9.pom
1/1K
1K downloaded
Downloading: http://lists.refractions.net/m2//org/codehaus/plexus/plexus-utils/1.5.8/plexus-utils-1.5.8.pom
Downloading: http://repo1.maven.org/maven2/org/codehaus/plexus/plexus-utils/1.5.8/plexus-utils-1.5.8.pom
4/7K
5/7K
7/7K
7K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/maven-project/2.0.9/maven-project-2.0.9.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/maven-project/2.0.9/maven-project-2.0.9.pom
2/2K
2K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/maven-settings/2.0.9/maven-settings-2.0.9.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/maven-settings/2.0.9/maven-settings-2.0.9.pom
2/2K
2K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/maven-profile/2.0.9/maven-profile-2.0.9.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/maven-profile/2.0.9/maven-profile-2.0.9.pom
2/2K
2K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/maven-artifact-manager/2.0.9/maven-artifact-manager-2.0.9.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/maven-artifact-manager/2.0.9/maven-artifact-manager-2.0.9.pom
2/2K
2K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/maven-repository-metadata/2.0.9/maven-repository-metadata-2.0.9.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/maven-repository-metadata/2.0.9/maven-repository-metadata-2.0.9.pom
1/1K
1K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/maven-artifact/2.0.9/maven-artifact-2.0.9.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/maven-artifact/2.0.9/maven-artifact-2.0.9.pom
1/1K
1K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/maven-plugin-registry/2.0.9/maven-plugin-registry-2.0.9.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/maven-plugin-registry/2.0.9/maven-plugin-registry-2.0.9.pom
1/1K
1K downloaded
Downloading: http://lists.refractions.net/m2//org/apache/maven/maven-archiver/2.4/maven-archiver-2.4.jar
Downloading: http://repo1.maven.org/maven2/org/apache/maven/maven-archiver/2.4/maven-archiver-2.4.jar
4/19K
4/19K
5/19K
8/19K
11/19K
13/19K
15/19K
16/19K
19/19K
19K downloaded
Downloading: http://lists.refractions.net/m2//org/codehaus/plexus/plexus-utils/1.5.8/plexus-utils-1.5.8.jar
Downloading: http://repo1.maven.org/maven2/org/codehaus/plexus/plexus-utils/1.5.8/plexus-utils-1.5.8.jar
4/261K
8/261K
11/261K
12/261K
16/261K
18/261K
22/261K
23/261K
25/261K
26/261K
30/261K
33/261K
37/261K
39/261K
43/261K
45/261K
46/261K
50/261K
50/261K
54/261K
56/261K
60/261K
61/261K
65/261K
69/261K
72/261K
76/261K
80/261K
84/261K
88/261K
92/261K
96/261K
100/261K
104/261K
107/261K
111/261K
115/261K
119/261K
123/261K
127/261K
131/261K
135/261K
139/261K
143/261K
147/261K
149/261K
151/261K
155/261K
159/261K
163/261K
167/261K
171/261K
175/261K
179/261K
183/261K
187/261K
191/261K
195/261K
199/261K
203/261K
204/261K
208/261K
212/261K
216/261K
220/261K
224/261K
228/261K
232/261K
236/261K
240/261K
244/261K
248/261K
252/261K
256/261K
260/261K
261/261K
261K downloaded
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/pom.xml to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.6.6-SNAPSHOT/geoserver-1.6.6-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/target/geoserver-1.6.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.6.6-SNAPSHOT/geoserver-1.6.6-SNAPSHOT-tests.jar
[INFO] Building GeoServer Maven Plugins
[INFO] [clean:clean]
[INFO] Deleting file set: http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/maven/target (included: [**], excluded: )
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/maven/target/maven-1.6.6-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/maven/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/1.6.6-SNAPSHOT/maven-1.6.6-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/maven/target/maven-1.6.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/1.6.6-SNAPSHOT/maven-1.6.6-SNAPSHOT-tests.jar
[INFO] Building Plugins configuration files
[INFO] Deleting file set: http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target (included: [**], excluded: )
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from central
[INFO] [resources:resources]
[WARNING] Using platform encoding (UTF-8 actually) to copy filtered resources, i.e. build is platform dependent!
[INFO] Copying 1 resource
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] skip non existing resourceDirectory http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/src/test/java
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6.6-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6.6-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.6.6-SNAPSHOT/build-configs-1.6.6-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.6.6-SNAPSHOT/build-configs-1.6.6-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/maven/build-configs/target/build-configs-1.6.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.6.6-SNAPSHOT/build-configs-1.6.6-SNAPSHOT-sources.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from central
[INFO] Deleting file set: http://hudson.opengeo.org/hudson/job/geoserver-1.6.x/ws/geoserver/maven/config/target (included: [**], excluded: )
[INFO] [plugin:descriptor]
[WARNING] Using platform encoding (UTF-8 actually) to read mojo metadata, i.e. build is platform dependent!
[ERROR] BUILD ERROR
[INFO] The API of the mojo scanner is not compatible with this plugin version. Please check the plugin dependencies configured in the POM and ensure the versions match.
Embedded error: org.apache.maven.tools.plugin.scanner.MojoScanner.populatePluginDescriptor(Lorg/apache/maven/tools/plugin/PluginToolsRequest;)V
[INFO] Total time: 1 minute 1 second
[INFO] Finished at: Wed May 27 04:51:33 EDT 2009
[INFO] Final Memory: 24M/44M
Failed to send e-mail to bencaradocdavies because no e-mail address is known, and no default e-mail domain is configured
