[Geoserver-devel] Build failed in Hudson: geoserver-1.6.x #39
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/39/changes
Changes:
[aaime] GEOS-1659, WFS Maxfeatures refinement
[aaime] Going back to gt2 2.4-SNAPSHOT depedency
[...truncated 22715 lines...]
INFO: Done disposing datastores.
13 Feb 05:49:32 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext;hashCode=32862047]: org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [validation,validationConfig,validationRegisterar,validationConfigRegisterar,resourceLoader,extensions,config,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,serviceStrategyFactory,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,customEditorConfigurer,dispatcher,wfsConfig,wfsRegisterar,wfsConfigRegisterar,filterFactory,wfs,wfsServiceTarget,wfsLogger,wfsService,wfsInsertElementHandler,wfsUpdateElementHandler,wfsDeleteElementHandler,wfsNativeElementHandler,wfsService-1.0.0,wfsService-1.1.0,wfsExceptionHandler,gml2SchemaBuilder,gml3SchemaBuilder,xmlConfiguration-1.0,xmlConfiguration-1.1,getCapabilitiesResponse,lockFeatureResponse,transactionResponse-1.0.0,citeComplianceHack,wfsURLMapping,typeNameKvpParser,featureIdKvpParser,bboxKvpParser,filterKvpParser,cqlKvpParser,propertyNameKvpParser,maxFeatureKvpParser,srsNameKvpParser,sortByKvpParser,expiryKvpParser,resultTypeKvpParser,acceptVersionsKvpParser,acceptFormatsKvpParser,strictKvpParser,wfsGetCapabilitiesKvpReader,describeFeatureTypeKvpReader,getFeatureKvpReader,getFeatureWithLockKvpReader,lockFeatureKvpReader,transactionKvpReader,releaseLockKvpReader,xmlReader-1.0.0,wfsGetCapabilitiesXmlReader,describeFetureTypeXmlReader,getFeatureXmlReader,getFeatureWithLockXmlReader,lockFeatureXmlReader,transactionXmlReader,xmlReader-1.1.0,wfsGetCapabilitiesXmlReader-1.1.0,describeFeatureTypeXmlReader-1.1.0,getFeatureTypeXmlReader-1.1.0,getFeatureWithLockXmlReader-1.1.0,lockFeatureXmlReader-1.1.0,transactionXmlReader-1.1.0,gml2FeatureTypeEncoder,gml3FeatureTypeEncoder,gml2OutputFormat,gml3OutputFormat,hitsOutputFormat,shapezipOutputFormat,geojsonOutputFormat,filterChainProxy,filterInvocationInterceptor,httpSessionContextIntegrationFilterWithASCTrue,httpSessionContextIntegrationFilterWithASCFalse,logoutFilter,authenticationProcessingFilter,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,basicProcessingFilter,basicProcessingFilterEntryPoint,consoleExceptionTranslationFilter,owsExceptionTranslationFilter,rememberMeServices,authenticationManager,daoAuthenticationProvider,userDetailsService,operationSecurityInterceptor]; root of BeanFactory hierarchy
13 Feb 05:49:32 INFO [test.GeoServerTestApplicationContext] - 106 beans defined in application context [org.geoserver.test.GeoServerTestApplicationContext;hashCode=32862047]
13 Feb 05:49:32 INFO [test.GeoServerTestApplicationContext] - Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@anonymised.com]
13 Feb 05:49:32 INFO [test.GeoServerTestApplicationContext] - Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@anonymised.com]
Feb 13, 2008 5:49:32 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: /tmp/mock29201data
Feb 13, 2008 5:49:32 AM org.vfny.geoserver.global.xml.XMLConfigReader loadCatalog
WARNING: Your catalog.xml file is not up to date and is probably from an older version of GeoServer. This problem is now being fixed automatically.
Feb 13, 2008 5:49:32 AM org.vfny.geoserver.global.GeoServer configureGeoServerLogging
WARNING: No log4jConfigFile defined in services.xml: using 'DEFAULT_LOGGING.properties'
WARNING: log4jConfigFile 'DEFAULT_LOGGING.properties' couldn't be found in the data dir, so GeoServer will install the various logging config file into the data dir, and then try to find it again.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
INFO: StdOut logging enabled. Log file also output to '/tmp/mock29201data/logs/geoserver.log'
Feb 13, 2008 5:49:32 AM org.vfny.geoserver.global.Data loadFeatureTypes
INFO: Loading feature type 'cdf:::Deletes' (layer 1/29)
INFO: Loading feature type 'cdf:::Fifteen' (layer 2/29)
INFO: Loading feature type 'cdf:::Inserts' (layer 3/29)
INFO: Loading feature type 'cdf:::Locks' (layer 4/29)
INFO: Loading feature type 'cdf:::Nulls' (layer 5/29)
INFO: Loading feature type 'cdf:::Other' (layer 6/29)
INFO: Loading feature type 'cdf:::Seven' (layer 7/29)
INFO: Loading feature type 'cdf:::Updates' (layer 8/29)
INFO: Loading feature type 'cgf:::Lines' (layer 9/29)
INFO: Loading feature type 'cgf:::MLines' (layer 10/29)
INFO: Loading feature type 'cgf:::MPoints' (layer 11/29)
INFO: Loading feature type 'cgf:::MPolygons' (layer 12/29)
INFO: Loading feature type 'cgf:::Points' (layer 13/29)
INFO: Loading feature type 'cgf:::Polygons' (layer 14/29)
INFO: Loading feature type 'cite:::BasicPolygons' (layer 15/29)
INFO: Loading feature type 'cite:::Bridges' (layer 16/29)
INFO: Loading feature type 'cite:::Buildings' (layer 17/29)
INFO: Loading feature type 'cite:::DividedRoutes' (layer 18/29)
INFO: Loading feature type 'cite:::Forests' (layer 19/29)
INFO: Loading feature type 'cite:::Geometryless' (layer 20/29)
INFO: Loading feature type 'cite:::Lakes' (layer 21/29)
INFO: Loading feature type 'cite:::MapNeatline' (layer 22/29)
INFO: Loading feature type 'cite:::NamedPlaces' (layer 23/29)
INFO: Loading feature type 'cite:::Ponds' (layer 24/29)
INFO: Loading feature type 'cite:::RoadSegments' (layer 25/29)
INFO: Loading feature type 'cite:::Streams' (layer 26/29)
INFO: Loading feature type 'sf:::AggregateGeoFeature' (layer 27/29)
INFO: Loading feature type 'sf:::GenericEntity' (layer 28/29)
INFO: Loading feature type 'sf:::PrimitiveGeoFeature' (layer 29/29)
Feb 13, 2008 5:49:32 AM org.geoserver.wfs.WFSLogger invoke
INFO:
Request: getCapabilities
  acceptVersions:
    version = [1.0.0]
  sections = null
  acceptFormats = null
  updateSequence = null
  baseUrl = http://localhost:80/geoserver/
  service = WFS
Result:
13 Feb 05:49:32 INFO [test.GeoServerTestApplicationContext] - Closing application context [org.geoserver.test.GeoServerTestApplicationContext;hashCode=32862047]
Feb 13, 2008 5:49:32 AM org.vfny.geoserver.global.GeoServer destroy
INFO: Disposing DataStores at GeoServer shutdown...
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.592 sec
Results :
Failed tests:
  testLock(org.geoserver.wfs.v1_1.LockFeatureTest)
  testGetFeatureReproject10(org.geoserver.wfs.GeometrylessTest)
  testGetFeatureReproject11(org.geoserver.wfs.GeometrylessTest)
  testGetFeatureReprojectPost(org.geoserver.wfs.GeometrylessTest)
  testWfs11(org.geoserver.wfs.SrsNameTest)
  testLax(org.geoserver.wfs.GetFeatureTest)
  testUpdateLockedFeatureWithLockId(org.geoserver.wfs.GetFeatureWithLockTest)
  testUpdateLockedFeatureWithoutLockId(org.geoserver.wfs.GetFeatureWithLockTest)
  testGetFeatureWithLockReleaseActionSome(org.geoserver.wfs.GetFeatureWithLockTest)
  testGet(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPost(org.geoserver.wfs.v1_1.GetFeatureTest)
  testGetPropertyNameEmpty(org.geoserver.wfs.v1_1.GetFeatureTest)
  testGetPropertyNameStar(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPostWithFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPostFormEncoded(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPostWithBboxFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPostWithFailingUrnBboxFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPostWithMatchingUrnBboxFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
  testResultTypeHitsGet(org.geoserver.wfs.v1_1.GetFeatureTest)
  testResultTypeHitsPost(org.geoserver.wfs.v1_1.GetFeatureTest)
  testWithSRS(org.geoserver.wfs.v1_1.GetFeatureTest)
  testWithSillyLiteral(org.geoserver.wfs.v1_1.GetFeatureTest)
  testWithGmlObjectId(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPostWithBoundsEnabled(org.geoserver.wfs.v1_1.GetFeatureTest)
  testAfterFeatureTypeAdded(org.geoserver.wfs.v1_1.GetFeatureTest)
  testWithGMLProperties(org.geoserver.wfs.v1_1.GetFeatureTest)
  testInsert1(org.geoserver.wfs.v1_1.TransactionTest)
  testInsertWithNoSRS(org.geoserver.wfs.v1_1.TransactionTest)
  testInsertWithSRS(org.geoserver.wfs.v1_1.TransactionTest)
  testInsertWithGMLProperties(org.geoserver.wfs.v1_1.TransactionTest)
  testUpdateWithGMLProperties(org.geoserver.wfs.v1_1.TransactionTest)
  testInsert2(org.geoserver.wfs.v1_1.TransactionTest)
  testUpdateForcedSRS(org.geoserver.wfs.v1_1.TransactionTest)
  testUpdateNoSRS(org.geoserver.wfs.v1_1.TransactionTest)
  test(org.geoserver.wfs.v1_1.GetFeatureWithLockTest)
  testGML2(org.geoserver.wfs.xml.GMLOutputFormatTest)
  testGML3(org.geoserver.wfs.xml.GMLOutputFormatTest)
  testCombinedLocalMaxes(org.geoserver.wfs.MaxFeaturesTest)
  testCombinedLocalMaxesBigger(org.geoserver.wfs.MaxFeaturesTest)
  testCombinedLocalMaxesBiggerRequestOverride(org.geoserver.wfs.MaxFeaturesTest)
Tests in error:
  testBboxReproject(org.geoserver.wfs.ReprojectingFilterVisitorTest)
  testBboxReprojectUnreferencedProperty(org.geoserver.wfs.ReprojectingFilterVisitorTest)
  testIntersectsReproject(org.geoserver.wfs.ReprojectingFilterVisitorTest)
  testIntersectsUnreferencedProperty(org.geoserver.wfs.ReprojectingFilterVisitorTest)
  testUpdate(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testGetFeatureGet(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testGetFeaturePost(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testGetFeatureWithProjectedBoxGet(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testGetFeatureWithProjectedBoxPost(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testInsertSrsName(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testInsertGeomSrsName(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testUpdateReprojectFilter(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testUpdateReprojectFilterDefaultCRS(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testDeleteReprojectFilter(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testDeleteReprojectFilterDefaultCRS(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testLockReprojectFilter(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testLockReprojectFilterDefaultCRS(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testUpdate(org.geoserver.wfs.ReprojectionTest)
  testGetFeatureGet(org.geoserver.wfs.ReprojectionTest)
  testGetFeaturePost(org.geoserver.wfs.ReprojectionTest)
  testGetFeatureWithProjectedBoxGet(org.geoserver.wfs.ReprojectionTest)
  testGetFeatureWithProjectedBoxPost(org.geoserver.wfs.ReprojectionTest)
  testInsertSrsName(org.geoserver.wfs.ReprojectionTest)
  testInsertGeomSrsName(org.geoserver.wfs.ReprojectionTest)
Tests run: 131, Failures: 40, Errors: 24, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfs/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 38 seconds
[INFO] Finished at: Wed Feb 13 05:49:32 EST 2008
[INFO] Final Memory: 24M/60M
Updating GEOS-1659
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/40/changes
Changes:
[aaime] GEOS-1489, Geoserver returns more than maxFeatures if more than 1 layer is requested in WFS request
[...truncated 22847 lines...]
13 Feb 06:49:41 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext;hashCode=23051988]: org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [validation,validationConfig,validationRegisterar,validationConfigRegisterar,resourceLoader,extensions,config,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,serviceStrategyFactory,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,customEditorConfigurer,dispatcher,wfsConfig,wfsRegisterar,wfsConfigRegisterar,filterFactory,wfs,wfsServiceTarget,wfsLogger,wfsService,wfsInsertElementHandler,wfsUpdateElementHandler,wfsDeleteElementHandler,wfsNativeElementHandler,wfsService-1.0.0,wfsService-1.1.0,wfsExceptionHandler,gml2SchemaBuilder,gml3SchemaBuilder,xmlConfiguration-1.0,xmlConfiguration-1.1,getCapabilitiesResponse,lockFeatureResponse,transactionResponse-1.0.0,citeComplianceHack,wfsURLMapping,typeNameKvpParser,featureIdKvpParser,bboxKvpParser,filterKvpParser,cqlKvpParser,propertyNameKvpParser,maxFeatureKvpParser,srsNameKvpParser,sortByKvpParser,expiryKvpParser,resultTypeKvpParser,acceptVersionsKvpParser,acceptFormatsKvpParser,strictKvpParser,wfsGetCapabilitiesKvpReader,describeFeatureTypeKvpReader,getFeatureKvpReader,getFeatureWithLockKvpReader,lockFeatureKvpReader,transactionKvpReader,releaseLockKvpReader,xmlReader-1.0.0,wfsGetCapabilitiesXmlReader,describeFetureTypeXmlReader,getFeatureXmlReader,getFeatureWithLockXmlReader,lockFeatureXmlReader,transactionXmlReader,xmlReader-1.1.0,wfsGetCapabilitiesXmlReader-1.1.0,describeFeatureTypeXmlReader-1.1.0,getFeatureTypeXmlReader-1.1.0,getFeatureWithLockXmlReader-1.1.0,lockFeatureXmlReader-1.1.0,transactionXmlReader-1.1.0,gml2FeatureTypeEncoder,gml3FeatureTypeEncoder,gml2OutputFormat,gml3OutputFormat,hitsOutputFormat,shapezipOutputFormat,geojsonOutputFormat,filterChainProxy,filterInvocationInterceptor,httpSessionContextIntegrationFilterWithASCTrue,httpSessionContextIntegrationFilterWithASCFalse,logoutFilter,authenticationProcessingFilter,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,basicProcessingFilter,basicProcessingFilterEntryPoint,consoleExceptionTranslationFilter,owsExceptionTranslationFilter,rememberMeServices,authenticationManager,daoAuthenticationProvider,userDetailsService,operationSecurityInterceptor]; root of BeanFactory hierarchy
13 Feb 06:49:41 INFO [test.GeoServerTestApplicationContext] - 106 beans defined in application context [org.geoserver.test.GeoServerTestApplicationContext;hashCode=23051988]
13 Feb 06:49:41 INFO [test.GeoServerTestApplicationContext] - Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@anonymised.com]
13 Feb 06:49:41 INFO [test.GeoServerTestApplicationContext] - Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@anonymised.com]
Feb 13, 2008 6:49:41 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: /tmp/mock1707data
Feb 13, 2008 6:49:41 AM org.vfny.geoserver.global.xml.XMLConfigReader loadCatalog
Feb 13, 2008 6:49:41 AM org.vfny.geoserver.global.GeoServer configureGeoServerLogging
INFO: StdOut logging enabled. Log file also output to '/tmp/mock1707data/logs/geoserver.log'
Feb 13, 2008 6:49:41 AM org.vfny.geoserver.global.Data loadFeatureTypes
Feb 13, 2008 6:49:41 AM org.geoserver.wfs.WFSLogger invoke
INFO:
  acceptVersions:
    version = [1.0.0]
  sections = null
  service = WFS
Result:
13 Feb 06:49:41 INFO [test.GeoServerTestApplicationContext] - Closing application context [org.geoserver.test.GeoServerTestApplicationContext;hashCode=23051988]
Feb 13, 2008 6:49:41 AM org.vfny.geoserver.global.GeoServer destroy
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.604 sec
Results :
Failed tests:
Tests in error:
Tests run: 132, Failures: 40, Errors: 24, Skipped: 0
[INFO] Total time: 2 minutes 49 seconds
[INFO] Finished at: Wed Feb 13 06:49:41 EST 2008
[INFO] Final Memory: 24M/56M
Updating GEOS-1489
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/41/changes
