See http://geo.openplans.org:8080/hudson/job/geoserver-1.6.x/4/changes
Changes:
[jdeolive] added srsName test
[...truncated 25700 lines...]
WARNING: No log4jConfigFile defined in services.xml: using 'DEFAULT_LOGGING.properties'
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
Jan 5, 2008 3:50:59 PM org.vfny.geoserver.global.GeoServer configureGeoServerLogging
INFO: StdOut logging enabled. Log file also output to '/tmp/mock61723data/logs/geoserver.log'
Jan 5, 2008 3:50:59 PM org.vfny.geoserver.global.Data loadFeatureTypes
INFO: Loading feature type 'cdf:::Deletes' (layer 1/29)
INFO: Loading feature type 'cdf:::Fifteen' (layer 2/29)
INFO: Loading feature type 'cdf:::Inserts' (layer 3/29)
INFO: Loading feature type 'cdf:::Locks' (layer 4/29)
INFO: Loading feature type 'cdf:::Nulls' (layer 5/29)
INFO: Loading feature type 'cdf:::Other' (layer 6/29)
INFO: Loading feature type 'cdf:::Seven' (layer 7/29)
INFO: Loading feature type 'cdf:::Updates' (layer 8/29)
INFO: Loading feature type 'cgf:::Lines' (layer 9/29)
INFO: Loading feature type 'cgf:::MLines' (layer 10/29)
INFO: Loading feature type 'cgf:::MPoints' (layer 11/29)
INFO: Loading feature type 'cgf:::MPolygons' (layer 12/29)
INFO: Loading feature type 'cgf:::Points' (layer 13/29)
INFO: Loading feature type 'cgf:::Polygons' (layer 14/29)
INFO: Loading feature type 'cite:::BasicPolygons' (layer 15/29)
INFO: Loading feature type 'cite:::Bridges' (layer 16/29)
INFO: Loading feature type 'cite:::Buildings' (layer 17/29)
INFO: Loading feature type 'cite:::DividedRoutes' (layer 18/29)
INFO: Loading feature type 'cite:::Forests' (layer 19/29)
INFO: Loading feature type 'cite:::Geometryless' (layer 20/29)
INFO: Loading feature type 'cite:::Lakes' (layer 21/29)
INFO: Loading feature type 'cite:::MapNeatline' (layer 22/29)
INFO: Loading feature type 'cite:::NamedPlaces' (layer 23/29)
INFO: Loading feature type 'cite:::Ponds' (layer 24/29)
INFO: Loading feature type 'cite:::RoadSegments' (layer 25/29)
INFO: Loading feature type 'cite:::Streams' (layer 26/29)
INFO: Loading feature type 'sf:::AggregateGeoFeature' (layer 27/29)
INFO: Loading feature type 'sf:::GenericEntity' (layer 28/29)
INFO: Loading feature type 'sf:::PrimitiveGeoFeature' (layer 29/29)
Jan 5, 2008 3:50:59 PM org.vfny.geoserver.global.GeoServer destroy
INFO: Disposing DataStores at GeoServer shutdown...
INFO: Done disposing datastores.
05 Jan 15:50:59 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext;hashCode=1714586101]: org.springframework.beans.factory.support.DefaultListableBeanFactory defining beans [resourceLoader,extensions,config,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,serviceStrategyFactory,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,customEditorConfigurer,dispatcher,validation,validationConfig,validationRegisterar,validationConfigRegisterar,wfsConfig,wfsRegisterar,wfsConfigRegisterar,filterFactory,wfs,wfsServiceTarget,wfsLogger,wfsService,wfsInsertElementHandler,wfsUpdateElementHandler,wfsDeleteElementHandler,wfsNativeElementHandler,wfsService-1.0.0,wfsService-1.1.0,wfsExceptionHandler,gml2SchemaBuilder,gml3SchemaBuilder,xmlConfiguration-1.0,xmlConfiguration-1.1,getCapabilitiesResponse,lockFeatureResponse,transactionResponse-1.0.0,citeComplianceHack,wfsURLMapping,typeNameKvpParser,featureIdKvpParser,bboxKvpParser,filterKvpParser,cqlKvpParser,propertyNameKvpParser,maxFeatureKvpParser,srsNameKvpParser,sortByKvpParser,expiryKvpParser,resultTypeKvpParser,acceptVersionsKvpParser,acceptFormatsKvpParser,strictKvpParser,wfsGetCapabilitiesKvpReader,describeFeatureTypeKvpReader,getFeatureKvpReader,getFeatureWithLockKvpReader,lockFeatureKvpReader,transactionKvpReader,releaseLockKvpReader,xmlReader-1.0.0,wfsGetCapabilitiesXmlReader,describeFetureTypeXmlReader,getFeatureXmlReader,getFeatureWithLockXmlReader,lockFeatureXmlReader,transactionXmlReader,xmlReader-1.1.0,wfsGetCapabilitiesXmlReader-1.1.0,describeFeatureTypeXmlReader-1.1.0,getFeatureTypeXmlReader-1.1.0,getFeatureWithLockXmlReader-1.1.0,lockFeatureXmlReader-1.1.0,transactionXmlReader-1.1.0,gml2FeatureTypeEncoder,gml3FeatureTypeEncoder,gml2OutputFormat,gml3OutputFormat,hitsOutputFormat,shapezipOutputFormat,geojsonOutputFormat,filterChainProxy,filterInvocationInterceptor,httpSessionContextIntegrationFilterWithASCTrue,httpSessionContextIntegrationFilterWithASCFalse,logoutFilter,authenticationProcessingFilter,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,basicProcessingFilter,basicProcessingFilterEntryPoint,consoleExceptionTranslationFilter,owsExceptionTranslationFilter,rememberMeServices,authenticationManager,daoAuthenticationProvider,userDetailsService,operationSecurityInterceptor]; root of BeanFactory hierarchy
05 Jan 15:50:59 INFO [test.GeoServerTestApplicationContext] - 106 beans defined in application context [org.geoserver.test.GeoServerTestApplicationContext;hashCode=1714586101]
05 Jan 15:50:59 INFO [test.GeoServerTestApplicationContext] - Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@anonymised.com]
05 Jan 15:50:59 INFO [test.GeoServerTestApplicationContext] - Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@anonymised.com]
Jan 5, 2008 3:50:59 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: /tmp/mock61724data
Jan 5, 2008 3:50:59 PM org.vfny.geoserver.global.xml.XMLConfigReader loadCatalog
WARNING: Your catalog.xml file is not up to date and is probably from an older version of GeoServer. This problem is now being fixed automatically.
WARNING: log4jConfigFile 'DEFAULT_LOGGING.properties' couldn't be found in the data dir, so GeoServer will install the various logging config file into the data dir, and then try to find it again.
INFO: StdOut logging enabled. Log file also output to '/tmp/mock61724data/logs/geoserver.log'
Jan 5, 2008 3:50:59 PM org.geoserver.wfs.WFSLogger invoke
INFO:
Request: getCapabilities
acceptVersions:
version = [1.0.0]
sections = null
acceptFormats = null
updateSequence = null
baseUrl = http://localhost:80/geoserver/
service = WFS
Result:
05 Jan 15:50:59 INFO [test.GeoServerTestApplicationContext] - Closing application context [org.geoserver.test.GeoServerTestApplicationContext;hashCode=1714586101]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.919 sec
Results :
Failed tests:
testWfs11(org.geoserver.wfs.SrsNameTest)
Tests run: 125, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://geo.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfs/target/surefire-reports for the individual test results.
[INFO] Total time: 4 minutes 7 seconds
[INFO] Finished at: Sat Jan 05 15:51:00 GMT-05:00 2008
[INFO] Final Memory: 52M/251M
