See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/70/changes
Changes:
[aaime] GEOS-1752, GetFeatureInfo does not work on layer whose srs was reprojected at the configuration level
[groldan] GEOS-1745, fixed parsing a kvp single element with outer delimiter
[...truncated 656 lines...]
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.geoserver.test.GeoServerTestSupport.dispatch(GeoServerTestSupport.java:493)
at org.geoserver.test.GeoServerTestSupport.post(GeoServerTestSupport.java:300)
at org.geoserver.test.GeoServerTestSupport.postAsDOM(GeoServerTestSupport.java:348)
at org.geoserver.wfs.GeometrylessTest.testDelete(GeometrylessTest.java:114)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 8, Failures: 8, Errors: 0, Skipped: 0, Time elapsed: 2.169 sec <<< FAILURE!
Running org.geoserver.wfs.v1_1.DescribeFeatureResponseTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.364 sec
Running org.geoserver.wfs.SrsNameTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.16 sec
Running org.geoserver.wfs.GetFeatureTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.152 sec
Running org.geoserver.wfs.v1_1.WFSXmlTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.484 sec
Running org.geoserver.wfs.LockFeatureTest
25 Feb 12:53:07 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
25 Feb 12:53:07 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
25 Feb 12:53:08 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
25 Feb 12:53:08 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
25 Feb 12:53:08 ERROR [geoserver.wfs] - Transaction failed
org.geoserver.wfs.WFSTransactionException: Transaction does not have authorization for Locks:Locks.0
at org.geoserver.wfs.DeleteElementHandler.execute(DeleteElementHandler.java:187)
at org.geoserver.wfs.Transaction.execute(Transaction.java:328)
at org.geoserver.wfs.Transaction.transaction(Transaction.java:104)
at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:156)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:122)
at org.geoserver.wfs.WFSLogger.invoke(WFSLogger.java:44)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
at $Proxy1.transaction(Unknown Source)
at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
at org.geoserver.wfs.LockFeatureTest.testDeleteWithoutLockId(LockFeatureTest.java:105)
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.912 sec
Running org.geoserver.wfs.GetFeatureWithLockTest
25 Feb 12:53:09 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
25 Feb 12:53:09 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
25 Feb 12:53:09 ERROR [geoserver.wfs] - Transaction failed
org.geoserver.wfs.WFSTransactionException: org.geotools.data.FeatureLockException: Transaction does not have authorization for Locks:Locks.0
at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:261)
at org.geoserver.wfs.GetFeatureWithLockTest.testUpdateLockedFeatureWithoutLockId(GetFeatureWithLockTest.java:119)
Caused by: org.geotools.data.FeatureLockException: Transaction does not have authorization for Locks:Locks.0
at org.geotools.data.InProcessLockingManager.assertAccess(InProcessLockingManager.java:284)
at org.geotools.data.InProcessLockingManager$1.write(InProcessLockingManager.java:327)
at org.geotools.data.FilteringFeatureWriter.write(FilteringFeatureWriter.java:105)
at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:156)
at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:98)
at org.vfny.geoserver.global.GeoServerFeatureStore.modifyFeatures(GeoServerFeatureStore.java:124)
at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:225)
... 52 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.08 sec
Running org.geoserver.wfs.kvp.FilterKvpParserTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.104 sec
Running org.geoserver.wfs.v1_1.GetFeatureTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.909 sec
Running org.geoserver.wfs.v1_1.TransactionTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.128 sec
Running org.geoserver.wfs.v1_1.GetFeatureWithLockTest
25 Feb 12:53:35 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
25 Feb 12:53:35 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.777 sec
Running org.geoserver.wfs.xml.GML3FeatureProducerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.468 sec
Running org.geoserver.wfs.response.WfsXmlWriterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.144 sec
Running org.geoserver.wfs.TransactionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.872 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.112 sec
Running org.geoserver.wfs.v1_1.WFSReprojectionTest
25 Feb 12:53:49 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
25 Feb 12:53:49 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.716 sec
Running org.geoserver.wfs.ReprojectionTest
25 Feb 12:53:50 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
25 Feb 12:53:50 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.576 sec
Running org.geoserver.wfs.TransactionListenerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.612 sec
Running org.geoserver.wfs.MaxFeaturesTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.009 sec
Running org.geoserver.wfs.DescribeFeatureTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.536 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.744 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.14 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.016 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.244 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.532 sec
Results :
Failed tests:
testGetFeature10(org.geoserver.wfs.GeometrylessTest)
testGetFeatureReproject10(org.geoserver.wfs.GeometrylessTest)
testGetFeature11(org.geoserver.wfs.GeometrylessTest)
testGetFeatureReproject11(org.geoserver.wfs.GeometrylessTest)
testGetFeatureReprojectPost(org.geoserver.wfs.GeometrylessTest)
testUpdate(org.geoserver.wfs.GeometrylessTest)
testDelete(org.geoserver.wfs.GeometrylessTest)
testInsert(org.geoserver.wfs.GeometrylessTest)
Tests run: 124, Failures: 8, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfs/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 8 seconds
[INFO] Finished at: Mon Feb 25 12:54:10 EST 2008
[INFO] Final Memory: 31M/63M
Updating GEOS-1752
Updating GEOS-1745
