See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/73/changes
started
Updating https://svn.codehaus.org/geoserver/branches/1.6.x/geoserver
A community/community-schemas/wfs-c/src/main/java/org/geoserver/wfs/xml/v1_1_0/overrides/ISOMeasureTypeBinding.java
Fetching 'http://svn.codehaus.org/geoserver/trunk/configuration/minimal’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/community/community-schemas/web-c/minimal’
At revision 8463
Fetching 'http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/img’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/community/community-schemas/web-c/src/main/webapp/openlayers/img’
At revision 6381
Fetching 'http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/lib’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/community/community-schemas/web-c/src/main/webapp/openlayers/lib’
At revision 6381
Fetching 'http://svn.codehaus.org/geoserver/trunk/configuration/minimal’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/web/minimal’
At revision 8463
At revision 8462
WARNING: clock of the subversion server appears to be out of sync. This can result in inconsistent check out behavior.
FATAL: Provider org.apache.xalan.processor.TransformerFactoryImpl not found
javax.xml.transform.TransformerFactoryConfigurationError: Provider org.apache.xalan.processor.TransformerFactoryImpl not found
at javax.xml.transform.TransformerFactory.newInstance(TransformerFactory.java:108)
at hudson.scm.SubversionChangeLogBuilder.createTransformerHandler(SubversionChangeLogBuilder.java:158)
at hudson.scm.SubversionChangeLogBuilder.run(SubversionChangeLogBuilder.java:66)
at hudson.scm.SubversionSCM.calcChangeLog(SubversionSCM.java:228)
at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:320)
at hudson.model.AbstractProject.checkout(AbstractProject.java:558)
at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:215)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:181)
at hudson.model.Run.run(Run.java:659)
at hudson.model.Build.run(Build.java:101)
at hudson.model.ResourceController.execute(ResourceController.java:70)
at hudson.model.Executor.run(Executor.java:65)
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/74/changes
started
U community/community-schemas/wfs-c/src/main/java/org/geoserver/wfs/xml/v1_1_0/WFSConfiguration.java
At revision 8463
At revision 6382
At revision 6382
At revision 8463
At revision 8463
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/75/changes
started
U wms/src/main/java/org/vfny/geoserver/wms/responses/helpers/WMSCapsTransformer.java
U web/src/main/java/org/vfny/geoserver/action/data/TypesEditorAction.java
U web/src/main/java/org/vfny/geoserver/action/data/StylesSelectAction.java
U web/src/main/java/org/vfny/geoserver/action/data/CoveragesEditorAction.java
U web/src/main/java/ApplicationResources.properties
At revision 8470
At revision 6386
At revision 6386
At revision 8470
At revision 8470
