See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/92/changes
Changes:
[arneke] GEOS-1797 WMS reflector did not handle coverages properly
[...truncated 718 lines...]
Running org.geoserver.wfs.xml.GMLOutputFormatTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.376 sec
Running org.geoserver.wfs.v1_1.WFSReprojectionTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.128 sec
Running org.geoserver.wfs.ReprojectionTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.421 sec
Running org.geoserver.wfs.TransactionListenerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.644 sec
Running org.geoserver.wfs.MaxFeaturesTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.124 sec
Running org.geoserver.wfs.DescribeFeatureTest
13 Mar 23:09:38 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
13 Mar 23:09:38 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.86 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.62 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.144 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.396 sec
Running org.geoserver.wfs.response.ShapeZipTest
Mar 13, 2008 11:09:44 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.232 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.58 sec
Results :
Tests run: 124, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfs/target/wfs-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfs/target/wfs-1.6-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfs/target/wfs-1.6-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfs/target/wfs-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.6-SNAPSHOT/wfs-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfs/target/wfs-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.6-SNAPSHOT/wfs-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfs/target/wfs-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.6-SNAPSHOT/wfs-1.6-SNAPSHOT-sources.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building Versioning Web Feature Service Model
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.wfsv/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 28 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.wfsv/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.6-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfsv/1.6-SNAPSHOT/net.opengis.wfsv-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfsv/1.6-SNAPSHOT/net.opengis.wfsv-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfsv/1.6-SNAPSHOT/net.opengis.wfsv-1.6-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] snapshot org.geotools.maven:gt2-xmlcodegen:2.4-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geotools.maven:gt2-xmlcodegen:2.4-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.geotools.maven:gt2-maven:2.4-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geotools.maven:gt2-maven:2.4-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.geotools.maven:gt2-build:2.4-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geotools.maven:gt2-build:2.4-SNAPSHOT: checking for updates from refractions-plugins
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfsv/target
[INFO] Reloading plugin container for: org.geotools.maven:gt2-xmlcodegen. The plugin artifact has changed.
[INFO] snapshot org.geotools:gt2-postgis-versioned:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-postgis:2.4-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 45 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfsv/target/classes
[INFO] Nothing to compile - all classes are up to date
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfsv/target/surefire-reports
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfsv/target/wfsv-1.6-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfsv/target/wfsv-1.6-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfsv/target/wfsv-1.6-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfsv/target/wfsv-1.6-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.6-SNAPSHOT/wfsv-1.6-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfsv/target/wfsv-1.6-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.6-SNAPSHOT/wfsv-1.6-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wfsv/target/wfsv-1.6-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.6-SNAPSHOT/wfsv-1.6-SNAPSHOT-sources.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target
[INFO] snapshot org.geotools:gt2-render:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-shapefile-renderer:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wfs:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wms:2.4-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml:2.4-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 129 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/classes
[INFO] Compiling 17 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.6.x/ws/geoserver/wms/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.268 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.12 sec
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.66 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.309 sec
Running org.vfny.geoserver.wms.responses.map.png.GetMapTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.36 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMZMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.356 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.22 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.796 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
org.vfny.geoserver.wms.WmsException: No such style: ThisStyleDoesNotExists
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.232 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest
<table border='1'>
<tr>
<th colspan='4' scope='col'>testType</th>
</tr>
<tr>
<td>string</td>
<td>int</td>
<td>double</td>
<td>geom</td>
</tr>
<tr>
<td>
three
</td>
<td>
3
</td>
<td>
3.3
</td>
<td>
[GEOMETRY]
</td>
</tr>
</table>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.348 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.172 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.672 sec
Results :
Tests run: 47, Failures: 0, Errors: 0, Skipped: 0
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
org.geotools:gt2-shapefile:jar:2.4-SNAPSHOT
from the specified remote repositories:
central (http://repo1.maven.org/maven2),
refractions (http://lists.refractions.net/m2/),
mortbay (http://www.mortbay.org/maven2/release),
geotools (http://maven.geotools.fr/repository/)
Path to dependency:
1) org.geoserver:wms:jar:1.6-SNAPSHOT
2) org.geoserver:wfs:jar:1.6-SNAPSHOT
3) org.geotools:gt2-shapefile:jar:2.4-SNAPSHOT
Caused by I/O exception: Connection refused
[INFO] Total time: 76 minutes 7 seconds
[INFO] Finished at: Fri Mar 14 00:08:13 EDT 2008
[INFO] Final Memory: 25M/63M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
