[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #1
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/1/changes
[...truncated 4715 lines...]
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] [clean:clean]
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] No sources to compile
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.0-SNAPSHOT.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT-sources.jar
[INFO] [plugin:updateRegistry]
[INFO] Building Core Platform Module
[INFO] Compiling 9 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/classes
[INFO] Nothing to compile - all classes are up to date
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/surefire-reports
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Data Module
[INFO] snapshot org.geotools:gt-epsg-hsql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:plugin:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-coverage:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-h2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:unsupported:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-data:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-jdbc:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.h2database:h2:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.openplans:spatialdbbox:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-property:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:xsd:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:extension:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-graph:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 19 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/classes
[INFO] Compiling 7 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/surefire-reports
T E S T S
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.632 sec
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Jun 20, 2008 1:34:06 PM org.geotools.data.DefaultTransaction finalize
SEVERE: There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.028 sec
Results :
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/data-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/data-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/data-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/data-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.0-SNAPSHOT/data-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/data-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.0-SNAPSHOT/data-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/data-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.0-SNAPSHOT/data-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] snapshot org.geotools.ogc:net.opengis.ows:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:ogc:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.ogc:org.w3.xlink:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 71 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/classes
[INFO] Compiling 13 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/surefire-reports
T E S T S
Running org.geoserver.ows.DispatcherTest
log4j:WARN No appenders could be found for logger (org.springframework.context.support.FileSystemXmlApplicationContext).
log4j:WARN Please initialize the log4j system properly.
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.608 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.42 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.076 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Results :
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/ows-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/ows-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/ows-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/ows-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/ows-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] snapshot org.geotools:gt-cql:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt-cql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-validation:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt-validation:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 218 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/src/main/java/org/vfny/geoserver/config/CoverageConfig.java :[18,19] package javax.units does not exist
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/src/main/java/org/vfny/geoserver/config/CoverageConfig.java :[514,47] cannot find symbol
symbol : class Unit
location: class org.vfny.geoserver.config.CoverageConfig
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/src/main/java/org/vfny/geoserver/config/CoverageConfig.java :[473,18] cannot find symbol
symbol : class Unit
[INFO] Total time: 44 seconds
[INFO] Finished at: Fri Jun 20 13:34:18 EDT 2008
[INFO] Final Memory: 29M/60M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/2/changes
[...truncated 114 lines...]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target
[INFO] [jar:jar]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target
T E S T S
Results :
[INFO] [jar:jar]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target
T E S T S
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.368 sec
Jun 20, 2008 1:44:10 PM org.geotools.data.DefaultTransaction finalize
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.368 sec
Results :
[INFO] [jar:jar]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target
T E S T S
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.82 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.2 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Results :
[INFO] [jar:jar]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target
symbol : class Unit
symbol : class Unit
[INFO] Total time: 39 seconds
[INFO] Finished at: Fri Jun 20 13:44:21 EDT 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/3/changes
[INFO] [jar:jar]
T E S T S
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.472 sec
Jun 20, 2008 1:49:42 PM org.geotools.data.DefaultTransaction finalize
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.156 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.708 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.252 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Results :
[INFO] [jar:jar]
symbol : class Unit
symbol : class Unit
[INFO] Total time: 42 seconds
[INFO] Finished at: Fri Jun 20 13:49:54 EDT 2008
[INFO] Final Memory: 29M/58M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/4/changes
