See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/1011/
[...truncated 4560 lines...]
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Error: Could not find mediaLib accelerator wrapper classes. Continuing in pure Java mode.
Occurs in: com.sun.media.jai.mlib.MediaLibAccessor
java.lang.NoClassDefFoundError: com/sun/medialib/mlib/Image
at com.sun.media.jai.mlib.MediaLibAccessor$1.run(MediaLibAccessor.java:248)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.media.jai.mlib.MediaLibAccessor.setUseMlib(MediaLibAccessor.java:245)
at com.sun.media.jai.mlib.MediaLibAccessor.useMlib(MediaLibAccessor.java:177)
at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:357)
at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:315)
at com.sun.media.jai.mlib.MlibWarpRIF.create(MlibWarpRIF.java:65)
at sun.reflect.GeneratedMethodAccessor130.invoke(Unknown Source)
at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
at javax.media.jai.ThreadSafeOperationRegistry.invokeFactory(ThreadSafeOperationRegistry.java:473)
at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
at javax.media.jai.RenderedOp.getMinX(RenderedOp.java:2161)
at org.geotools.coverage.processing.operation.Resampler2D.reproject(Resampler2D.java:650)
at org.geotools.coverage.processing.operation.Resample.doOperation(Resample.java:207)
at org.vfny.geoserver.util.WCSUtils.scale(WCSUtils.java:225)
at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:335)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy16.getCoverage(Unknown Source)
at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:583)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:212)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1012)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:979)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:449)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:430)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:704)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:666)
at org.geoserver.catalog.rest.CoverageTest.testPostAsXML(CoverageTest.java:147)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
./target/mock27359data/temp/wcs/gs_usa_1244558464426644000.outputFormat
09 Jun 10:41:05 ERROR [geoserver.rest] - No such coverage: wcs,BlueMarble,NonExistant
09 Jun 10:41:06 ERROR [geoserver.rest] - No such coverage: wcs,BlueMarble,NonExistant
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 47.632 sec
Running org.geoserver.catalog.rest.CoverageStoreFileUploadTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.905 sec
Running org.geoserver.catalog.rest.CoverageStoreTest
09 Jun 10:43:09 ERROR [geoserver.rest] - No such coverage store: wcs,nonExistant
09 Jun 10:43:10 ERROR [geoserver.rest] - No such coverage store: wcs,nonExistant
09 Jun 10:43:10 ERROR [geoserver.rest] - coveragestore not empty
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 122.642 sec
Running org.geoserver.catalog.rest.LayerGroupTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 76.903 sec
Running org.geoserver.catalog.rest.NamespaceTest
09 Jun 10:46:59 ERROR [geoserver.rest] - No such namespace: none
09 Jun 10:47:00 ERROR [geoserver.rest] - No such namespace: newExistant
09 Jun 10:47:00 ERROR [geoserver.rest] - No such namespace: foo
09 Jun 10:47:01 ERROR [geoserver.rest] - No such namespace: nonExistant
09 Jun 10:47:01 ERROR [geoserver.rest] - Namespace not empty
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 153.9 sec
Running org.geoserver.catalog.rest.FeatureTypeTest
09 Jun 10:47:25 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Feature type sf:pdsa unknown
at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.read(GetFeatureKvpRequestReader.java:101)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1088)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:429)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:209)
at org.geoserver.catalog.rest.FeatureTypeTest.testPostAsXML(FeatureTypeTest.java:91)
09 Jun 10:47:26 ERROR [geoserver.ows] -
at org.geoserver.catalog.rest.FeatureTypeTest.testPostAsJSON(FeatureTypeTest.java:123)
09 Jun 10:47:27 ERROR [geoserver.rest] - No such feature type: sf,sf,NonExistant
09 Jun 10:47:28 ERROR [geoserver.rest] - No such feature type: sf,sf,NonExistant
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 28.184 sec
Running org.geoserver.catalog.rest.DataStoreTest
09 Jun 10:55:21 ERROR [geoserver.rest] - No such datastore: sf,nonExistant
09 Jun 10:55:21 ERROR [geoserver.rest] - datastore not empty
09 Jun 10:55:22 ERROR [geoserver.rest] - Can't change name of data store.
09 Jun 10:55:22 ERROR [geoserver.rest] - No such datastore: sf,nonExistant
09 Jun 10:55:22 ERROR [geoserver.rest] - Can't change workspace of data store.
Tests run: 19, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 473.018 sec <<< FAILURE!
Running org.geoserver.catalog.rest.LayerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 216.954 sec
Running org.geoserver.catalog.rest.StyleTest
09 Jun 11:04:39 ERROR [geoserver.rest] - Can't delete style referenced by existing layers.
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 340.465 sec
Running org.geoserver.catalog.rest.WorkspaceTest
09 Jun 11:09:06 ERROR [geoserver.rest] - No such workspace: none
09 Jun 11:09:07 ERROR [geoserver.rest] - No such workspace: newExistant
09 Jun 11:09:07 ERROR [geoserver.rest] - No such workspace: foo
09 Jun 11:09:07 ERROR [geoserver.rest] - Workspace not empty
09 Jun 11:09:08 ERROR [geoserver.rest] - Can't change the name of a workspace.
09 Jun 11:09:08 ERROR [geoserver.rest] - No such workspace: nonExistant
Tests run: 21, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 268.935 sec <<< FAILURE!
Results :
Tests in error:
testGetAllAsHTML(org.geoserver.catalog.rest.DataStoreTest)
testGetAsHTML(org.geoserver.catalog.rest.DataStoreTest)
testGetAllAsHTML(org.geoserver.catalog.rest.WorkspaceTest)
Tests run: 138, Failures: 0, Errors: 3, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/restconfig/target/surefire-reports for the individual test results.
[INFO] Total time: 36 minutes 39 seconds
[INFO] Finished at: Tue Jun 09 11:09:09 EDT 2009
[INFO] Final Memory: 46M/63M
