See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/1079/changes
Changes:
[afabiani] - cleanup
[afabiani] - removing old lower case featureinfo
[aaime] Reverting unintended commit about the eclipse plugin output directory
[...truncated 3418 lines...]
<item>
<title>BasicPolygons.1107531493643</title>
<link><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493643]]></link>
<guid><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493643]]></guid>
<description><![CDATA[<h4>BasicPolygons</h4>
<ul class="textattributes">
</ul>
]]></description>
<georss:polygon>6.0 -2.0 6.0 1.0 3.0 1.0 3.0 -2.0 6.0 -2.0</georss:polygon>
</item>
<item>
<title>BasicPolygons.1107531493644</title>
<link><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493644]]></link>
<guid><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493644]]></guid>
</ul>
]]></description>
<georss:polygon>5.0 -1.0 5.0 2.0 2.0 2.0 2.0 -1.0 5.0 -1.0</georss:polygon>
</item>
</channel>
</rss>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.324 sec
Running org.vfny.geoserver.wms.responses.palette.CustomPaletteBuilderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Running org.geoserver.wms.WMSExtensionsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.035 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.205 sec
Running org.vfny.geoserver.wms.responses.GetCapabilitiesTest
Jul 7, 2009 7:41:37 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.988 sec
Running org.geoserver.wms.CapabilitiesTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.611 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.wms.responses.MapDecorationLayoutTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: -0.033 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.441 sec
Running org.vfny.geoserver.wms.responses.map.legend.DefaultRasterLegendProducerTest
Jul 7, 2009 7:41:39 AM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.197 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.236 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLSuperOverlayTransformerTest
<kml>
<Document>
<Region>
<Lod>
<minLodPixels>128</minLodPixels>
<maxLodPixels>-1</maxLodPixels>
</Lod>
<LatLonAltBox>
<north>90.0</north>
<south>-90.0</south>
<east>180.0</east>
<west>0.0</west>
</LatLonAltBox>
</Region>
<NetworkLink>
<name>00</name>
<Region>
<Lod>
</Lod>
<LatLonAltBox>
<north>90.0</north>
<south>0.0</south>
<east>90.0</east>
<west>0.0</west>
</LatLonAltBox>
</Region>
<Link>
<href>http://localhost:80/geoserver/wms?service=wms&srs=EPSG%3A4326&width=256&styles=Default&height=256&superoverlay=true&transparent=false&bbox=0.0%2C0.0%2C90.0%2C90.0&request=GetMap&layers=Dispersed&format=application%2Fvnd.google-earth.kml%2Bxml&version=1.1.1</href>
<viewRefreshMode>onRegion</viewRefreshMode>
</Link>
</NetworkLink>
<NetworkLink>
<name>01</name>
<Region>
<Lod>
</Lod>
<LatLonAltBox>
<north>90.0</north>
<south>0.0</south>
<east>180.0</east>
<west>90.0</west>
</LatLonAltBox>
</Region>
<Link>
<href>http://localhost:80/geoserver/wms?service=wms&srs=EPSG%3A4326&width=256&styles=Default&height=256&superoverlay=true&transparent=false&bbox=90.0%2C0.0%2C180.0%2C90.0&request=GetMap&layers=Dispersed&format=application%2Fvnd.google-earth.kml%2Bxml&version=1.1.1</href>
</Link>
</NetworkLink>
<NetworkLink>
<name>10</name>
<Region>
<Lod>
</Lod>
<LatLonAltBox>
<north>0.0</north>
<east>90.0</east>
<west>0.0</west>
</LatLonAltBox>
</Region>
<Link>
<href>http://localhost:80/geoserver/wms?service=wms&srs=EPSG%3A4326&width=256&styles=Default&height=256&superoverlay=true&transparent=false&bbox=0.0%2C-90.0%2C90.0%2C0.0&request=GetMap&layers=Dispersed&format=application%2Fvnd.google-earth.kml%2Bxml&version=1.1.1</href>
</Link>
</NetworkLink>
<NetworkLink>
<name>11</name>
<Region>
<Lod>
</Lod>
<LatLonAltBox>
<north>0.0</north>
<east>180.0</east>
<west>90.0</west>
</LatLonAltBox>
</Region>
<Link>
<href>http://localhost:80/geoserver/wms?service=wms&srs=EPSG%3A4326&width=256&styles=Default&height=256&superoverlay=true&transparent=false&bbox=90.0%2C-90.0%2C180.0%2C0.0&request=GetMap&layers=Dispersed&format=application%2Fvnd.google-earth.kml%2Bxml&version=1.1.1</href>
</Link>
</NetworkLink>
<NetworkLink>
<visibility>1</visibility>
<Link>
<href>http://localhost:80/geoserver/wms?format_options=REGIONATEBY%3Aauto%3B&width=256&transparent=false&version=1.1.1&service=wms&srs=EPSG%3A4326&styles=Default&height=256&superoverlay=false&bbox=0.0%2C-90.0%2C180.0%2C90.0&request=GetMap&layers=Dispersed&format=</href>
</Link>
<Region>
<Lod>
</Lod>
<LatLonAltBox>
<north>90.0</north>
<east>180.0</east>
<west>0.0</west>
</LatLonAltBox>
</Region>
</NetworkLink>
</Document>
</kml>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.372 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.189 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.24 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.019 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
Tests run: 8, Failures: 0, Errors: 8, Skipped: 0, Time elapsed: 0.012 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.218 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.065 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
java.io.FileNotFoundException: Template rawValues.ftl not found.
at freemarker.template.Configuration.getTemplate(Configuration.java:489)
at freemarker.template.Configuration.getTemplate(Configuration.java:452)
at org.vfny.geoserver.wms.responses.featureInfo.FeatureTemplate.lookupTemplate(FeatureTemplate.java:295)
at org.vfny.geoserver.wms.responses.featureInfo.FeatureTemplate.execute(FeatureTemplate.java:263)
at org.vfny.geoserver.wms.responses.featureInfo.FeatureTemplate.template(FeatureTemplate.java:214)
at org.vfny.geoserver.wms.responses.featureInfo.FeatureTemplate.template(FeatureTemplate.java:251)
at org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest.testRawValue(FeatureTemplateTest.java:57)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor128.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 4, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.21 sec <<< FAILURE!
Results :
Tests in error:
testOutput(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
testDataRegionator(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
testGeometryRegionator(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
testRandomRegionator(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
testBogusRegionator(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
testBigGeometries(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
testStrategyChangesStuff(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
testDuplicateAttribute(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
testRawValue(org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest)
testAlternateLookup(org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest)
Tests run: 138, Failures: 0, Errors: 11, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 3 minutes 6 seconds
[INFO] Finished at: Tue Jul 07 07:41:41 EDT 2009
[INFO] Final Memory: 41M/63M
