See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/154/changes
Changes:
[groldan] updated README for cite module
[...truncated 10994 lines...]
version = 1.0.0
baseUrl = http://localhost:80/geoserver/
providedVersion = 1.0.0
typeName = [{http://www.openplans.org/topp\}archsites]
outputFormat = XMLSCHEMA
versioned = true
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:gml="http://www.opengis.net/wfsv" xmlns:topp="http://www.openplans.org/topp" attributeFormDefault="unqualified" elementFormDefault="qualified" targetNamespace="http://www.openplans.org/topp" version="1.0">
<xs:import namespace="http://www.opengis.net/wfsv" schemaLocation="http://localhost:80/geoserver/schemas/wfs/1.0.0/WFS-versioning.xsd"/>
<xs:complexType xmlns="http://www.w3.org/2001/XMLSchema" name="archsites_Type" xmlns:xs="http://www.w3.org/2001/XMLSchema">
<xs:complexContent>
<xs:extension base="wfsv:AbstractVersionedFeatureType">
<xs:sequence>
<xs:element minOccurs="0" name="cat" nillable="true" type="xs:long"/>
<xs:element minOccurs="0" name="str1" nillable="true">
<xs:simpleType>
<xs:restriction base="xs:string">
<xs:maxLength value="2147483647"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element minOccurs="0" name="the_geom" nillable="true" type="gml:PointPropertyType"/>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
<xs:element name="archsites" substitutionGroup="wfsv:_VersionedFeature" type="topp:archsites_Type"/>
</xs:schema>
30 Aug 05:42:14 INFO [geoserver.wfs] -
Request: describeVersionedFeatureType
handle = null
service = WFSV
version = 1.1.0
providedVersion = 1.1.0
outputFormat = text/xml; subtype=gml/3.1.1
versioned = true
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:gml="http://www.opengis.net/gml" xmlns:topp="http://www.openplans.org/topp" xmlns:wfsv="http://www.opengis.net/wfsv" elementFormDefault="qualified" targetNamespace="http://www.openplans.org/topp">
<xsd:import namespace="http://www.opengis.net/wfsv" schemaLocation="http://localhost:80/geoserver/wfs/schemas/wfs/1.1.0/wfsv.xsd"/>
<xsd:complexType name="archsitesType">
<xsd:complexContent>
<xsd:extension base="wfsv:AbstractVersionedFeatureType">
<xsd:sequence>
<xsd:element maxOccurs="1" minOccurs="0" name="cat" nillable="true" type="xsd:long"/>
<xsd:element maxOccurs="1" minOccurs="0" name="str1" nillable="true" type="xsd:string"/>
<xsd:element maxOccurs="1" minOccurs="0" name="the_geom" nillable="true" type="gml:PointPropertyType"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name="archsites" substitutionGroup="wfsv:_VersionedFeature" type="topp:archsitesType"/>
</xsd:schema>
handle = null
service = wfsv
version = 1.1.0
versioned = true
30 Aug 05:42:14 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Sat Aug 30 05:42:11 EDT 2008]; root of context hierarchy
30 Aug 05:42:14 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
30 Aug 05:42:14 INFO [geoserver.global] - Done disposing datastores.
30 Aug 05:42:14 INFO [geoserver.catalog] - Disposing datastore 'spearfish'
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.907 sec
Running org.geoserver.wfsv.RollbackTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
30 Aug 05:42:14 INFO [geoserver.catalog] - Loaded namespace 'topp' (http://www.openplans.org/topp)
30 Aug 05:42:14 INFO [geoserver.catalog] - Loaded namespace 'it.geosolutions' (http://www.geo-solutions.it)
30 Aug 05:42:14 INFO [geoserver.catalog] - Default namespace: 'topp'
30 Aug 05:42:14 INFO [geoserver.catalog] - Loaded style 'line'
30 Aug 05:42:14 INFO [geoserver.catalog] - Loaded style 'raster'
30 Aug 05:42:14 INFO [geoserver.catalog] - Loaded style 'polygon'
30 Aug 05:42:14 INFO [geoserver.catalog] - Loaded style 'point'
30 Aug 05:42:16 INFO [geoserver.catalog] - Processed data store 'spearfish', enabled
30 Aug 05:42:16 INFO [geoserver.catalog] - Processed coverage store 'dem', enabled
30 Aug 05:42:16 INFO [geoserver.catalog] - Loaded feature type 'topp:changesets'
30 Aug 05:42:16 INFO [geoserver.catalog] - Loaded feature type 'topp:roads'
30 Aug 05:42:16 INFO [geoserver.catalog] - Loaded feature type 'topp:restricted'
30 Aug 05:42:17 INFO [geoserver.catalog] - Loaded feature type 'topp:archsites'
30 Aug 05:42:17 INFO [geoserver.confg] - Loading service 'wfs'
30 Aug 05:42:17 WARN [geotools.xml] - cvc-complex-type.2.4.a: Invalid content was found starting with element 'topp:archsites'. One of '{"http://www.opengis.net/gml":\_Feature\}' is expected.
30 Aug 05:42:17 INFO [geoserver.wfs] -
Request: transaction
handle = Updating Signature rock label
service = WFSV
version = 1.1.0
lockId = null
group = [wfs:insert=net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com (feature: [org.geotools.feature.simple.SimpleFeatureImpl@anonymised.com], handle: null, idgen: GenerateNew, inputFormat: text/xml; subtype=gml/3.1.1, srsName: null), wfs:update=net.opengis.wfs.impl.UpdateElementTypeImpl@anonymised.com (filter: [ archsites.1 ], handle: null, inputFormat: x-application/gml:3, srsName: null, typeName: {http://www.openplans.org/topp\}archsites), wfs:delete=net.opengis.wfs.impl.DeleteElementTypeImpl@anonymised.com (filter: [ archsites.2 ], handle: null, typeName: {http://www.openplans.org/topp\}archsites)]
insert = [net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com (feature: [org.geotools.feature.simple.SimpleFeatureImpl@anonymised.com], handle: null, idgen: GenerateNew, inputFormat: text/xml; subtype=gml/3.1.1, srsName: null)]
update = [net.opengis.wfs.impl.UpdateElementTypeImpl@anonymised.com (filter: [ archsites.1 ], handle: null, inputFormat: x-application/gml:3, srsName: null, typeName: {http://www.openplans.org/topp\}archsites)]
delete = [net.opengis.wfs.impl.DeleteElementTypeImpl@anonymised.com (filter: [ archsites.2 ], handle: null, typeName: {http://www.openplans.org/topp\}archsites)]
native =
releaseAction = ALL
<wfs:TransactionResponse xmlns:wfs="http://www.opengis.net/wfs" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:ows="http://www.opengis.net/ows" xmlns:topp="http://www.openplans.org/topp" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs http://localhost:80/geoserver/schemas/wfs/1.1.0/wfs.xsd">
<wfs:TransactionSummary>
<wfs:totalInserted>1</wfs:totalInserted>
<wfs:totalUpdated>1</wfs:totalUpdated>
<wfs:totalDeleted>1</wfs:totalDeleted>
</wfs:TransactionSummary>
<wfs:TransactionResults/>
<wfs:InsertResults>
<wfs:Feature>
<ogc:FeatureId fid="archsites.5"/>
</wfs:Feature>
</wfs:InsertResults>
</wfs:TransactionResponse>
Request: getVersions
Request: getFeature
handle = null
service = WFSV
version = 1.1.0
query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: null, sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://www.openplans.org/topp\}archsites])]
maxFeatures = null
outputFormat = GML2
resultType = results
traverseXlinkDepth = null
traverseXlinkExpiry = null
handle = Rolling back previous changes
service = WFSV
version = 1.1.0
lockId = null
group = [wfs:native=net.opengis.wfsv.impl.RollbackTypeImpl@anonymised.com (safeToIgnore: false, vendorId: TOPP) (filter: null, handle: null, toFeatureVersion: 1, typeName: {http://www.openplans.org/topp\}archsites, user: )]
insert =
update =
delete =
native = [net.opengis.wfsv.impl.RollbackTypeImpl@anonymised.com (safeToIgnore: false, vendorId: TOPP) (filter: null, handle: null, toFeatureVersion: 1, typeName: {http://www.openplans.org/topp\}archsites, user: )]
releaseAction = ALL
30 Aug 05:42:17 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Sat Aug 30 05:42:14 EDT 2008]; root of context hierarchy
30 Aug 05:42:17 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
30 Aug 05:42:17 INFO [geoserver.global] - Done disposing datastores.
30 Aug 05:42:17 INFO [geoserver.catalog] - Disposing datastore 'spearfish'
30 Aug 05:42:18 INFO [geoserver.catalog] - Loaded namespace 'topp' (http://www.openplans.org/topp)
30 Aug 05:42:18 INFO [geoserver.catalog] - Loaded namespace 'it.geosolutions' (http://www.geo-solutions.it)
30 Aug 05:42:18 INFO [geoserver.catalog] - Default namespace: 'topp'
30 Aug 05:42:18 INFO [geoserver.catalog] - Loaded style 'line'
30 Aug 05:42:18 INFO [geoserver.catalog] - Loaded style 'raster'
30 Aug 05:42:18 INFO [geoserver.catalog] - Loaded style 'polygon'
30 Aug 05:42:18 INFO [geoserver.catalog] - Loaded style 'point'
30 Aug 05:42:19 INFO [geoserver.catalog] - Processed data store 'spearfish', enabled
30 Aug 05:42:19 INFO [geoserver.catalog] - Processed coverage store 'dem', enabled
30 Aug 05:42:19 INFO [geoserver.catalog] - Loaded feature type 'topp:changesets'
30 Aug 05:42:19 INFO [geoserver.catalog] - Loaded feature type 'topp:roads'
30 Aug 05:42:19 INFO [geoserver.catalog] - Loaded feature type 'topp:restricted'
30 Aug 05:42:20 INFO [geoserver.catalog] - Loaded feature type 'topp:archsites'
30 Aug 05:42:20 INFO [geoserver.confg] - Loading service 'wfs'
30 Aug 05:42:20 WARN [geotools.xml] - cvc-complex-type.3.1: Value 'WFSV' of attribute 'service' of element 'wfs:Transaction' is not valid with respect to the corresponding attribute use. Attribute 'service' has a fixed value of 'WFS'.
30 Aug 05:42:20 WARN [geotools.xml] - cvc-complex-type.2.4.a: Invalid content was found starting with element 'topp:archsites'. One of '{"http://www.opengis.net/gml":\_Feature\}' is expected.
30 Aug 05:42:20 INFO [geoserver.wfs] -
service = WFSV
version = 1.0.0
lockId = null
group = [wfs:insert=net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com (feature: [org.geotools.feature.simple.SimpleFeatureImpl@anonymised.com], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null), wfs:update=net.opengis.wfs.impl.UpdateElementTypeImpl@anonymised.com (filter: [ archsites.1 ], handle: null, inputFormat: <unset>, srsName: null, typeName: {http://www.openplans.org/topp\}archsites), wfs:delete=net.opengis.wfs.impl.DeleteElementTypeImpl@anonymised.com (filter: [ archsites.2 ], handle: null, typeName: {http://www.openplans.org/topp\}archsites)]
insert = [net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com (feature: [org.geotools.feature.simple.SimpleFeatureImpl@anonymised.com], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null)]
update = [net.opengis.wfs.impl.UpdateElementTypeImpl@anonymised.com (filter: [ archsites.1 ], handle: null, inputFormat: <unset>, srsName: null, typeName: {http://www.openplans.org/topp\}archsites)]
native =
releaseAction = ALL
Request: getFeature
handle = null
service = WFS
version = 1.0.0
query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: Filter.INCLUDE, sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://www.openplans.org/topp\}archsites])]
maxFeatures = null
outputFormat = GML2
service = WFS
version = 1.0.0
lockId = null
insert =
update =
delete =
releaseAction = ALL
30 Aug 05:42:20 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Sat Aug 30 05:42:18 EDT 2008]; root of context hierarchy
30 Aug 05:42:20 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
30 Aug 05:42:20 INFO [geoserver.global] - Done disposing datastores.
30 Aug 05:42:20 INFO [geoserver.catalog] - Disposing datastore 'spearfish'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.138 sec
Results :
Failed tests:
testGetFeatureBeforeAfter(org.geoserver.wfsv.HistoryRelatedTest)
testVersionedFeatureCollection10(org.geoserver.wfsv.HistoryRelatedTest)
testVersionedFeatureCollection11(org.geoserver.wfsv.HistoryRelatedTest)
testLog10(org.geoserver.wfsv.HistoryRelatedTest)
testLog11(org.geoserver.wfsv.HistoryRelatedTest)
testLog10Html(org.geoserver.wfsv.HistoryRelatedTest)
testGetDiff11(org.geoserver.wfsv.HistoryRelatedTest)
testGetDiff10(org.geoserver.wfsv.HistoryRelatedTest)
testGetDiff11Reverse(org.geoserver.wfsv.HistoryRelatedTest)
Tests run: 18, Failures: 9, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 47 seconds
[INFO] Finished at: Sat Aug 30 05:42:20 EDT 2008
[INFO] Final Memory: 32M/63M
