[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #194
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/194/changes
Changes:
[groldan] comment out testDescribeLayerVersion110, we don't support 1.1.0 at all, just 1.1.1
[arneke] GEOS-2225 (2nd attempt) Do not filter vector features on whether they are visible far out, does not work with regionating.
[arneke] Undoing commit 10224, included too many files by accident
[arneke] GEOS-2225 Do not filter vector features on whether they are visible far out, does not work with regionating.
[...truncated 9294 lines...]
  traverseXlinkExpiry = null
15 Sep 23:41:43 WARN [geotools.xml] - org.geotools.data.crs.ReprojectFeatureResults@anonymised.com (org.geotools.data.crs.ReprojectFeatureResults) is not of type [Lorg.opengis.feature.simple.SimpleFeature;
15 Sep 23:41:43 INFO [geoserver.wfs] -
Request: getFeature
  handle = null
  service = WFS
  version = 1.1.0
  baseUrl = http://localhost:80/geoserver/
  providedVersion = 1.1.0
  query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: [string2], function: null, filter: null, sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://www.opengis.net/cite/data\}Other])]
  maxFeatures = null
  outputFormat = text/xml; subtype=gml/3.1.1
  resultType = results
  traverseXlinkDepth = null
15 Sep 23:41:43 WARN [geotools.xml] - org.geoserver.wfs.FeatureBoundsFeatureCollection@anonymised.com (org.geoserver.wfs.FeatureBoundsFeatureCollection) is not of type [Lorg.opengis.feature.simple.SimpleFeature;
Request: getVersions
15 Sep 23:41:43 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Feature type sf:new unknown
  at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.read(GetFeatureKvpRequestReader.java:98)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:997)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:383)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:191)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:936)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:903)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:440)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:421)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:634)
  at org.geoserver.wfs.v1_1.GetFeatureTest.testAfterFeatureTypeAdded(GetFeatureTest.java:339)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:124)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
15 Sep 23:41:43 INFO [geoserver.catalog] - Disposing datastore 'cgf'
15 Sep 23:41:43 INFO [geoserver.catalog] - Disposing datastore 'cite'
15 Sep 23:41:43 INFO [geoserver.catalog] - Disposing datastore 'sf'
15 Sep 23:41:43 INFO [geoserver.catalog] - Disposing datastore 'cdf'
15 Sep 23:41:43 WARN [geoserver.logging] - log4jConfigFile 'TEST_LOGGING.properties' couldn't be found in the data dir, so GeoServer will install the various logging config file into the data dir, and then try to find it again.
15 Sep 23:41:43 WARN [geoserver.logging] - Still couldn't find log4jConfigFile 'TEST_LOGGING.properties'. Using DEFAULT_LOGGING.properties instead.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
15 Sep 23:41:43 INFO [geoserver.catalog] - Default namespace: 'gs'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded style 'Ponds'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded style 'Bridges'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded style 'Forests'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded style 'Default'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded style 'Buildings'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded style 'Streams'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded style 'Lakes'
15 Sep 23:41:43 INFO [geoserver.catalog] - Processed data store 'sf', enabled
15 Sep 23:41:43 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
15 Sep 23:41:43 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
15 Sep 23:41:43 INFO [geoserver.catalog] - Processed data store 'cite', enabled
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'sf:new'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
15 Sep 23:41:43 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
15 Sep 23:41:44 INFO [geoserver.catalog] - Loaded feature type 'sf:WithGMLProperties'
15 Sep 23:41:44 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
15 Sep 23:41:44 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
15 Sep 23:41:44 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
15 Sep 23:41:44 INFO [geoserver.confg] - Loading service 'wfs'
15 Sep 23:41:44 INFO [geoserver.wfs] -
Request: getFeature
  handle = null
  service = wfs
  version = 1.1.0
  query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: null, sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://cite.opengeospatial.org/gmlsf\}new])]
  maxFeatures = null
15 Sep 23:41:44 WARN [geotools.xml] - org.geotools.data.crs.ReprojectFeatureResults@anonymised.com (org.geotools.data.crs.ReprojectFeatureResults) is not of type [Lorg.opengis.feature.simple.SimpleFeature;
Request: getFeature
  handle = null
  service = wfs
  version = 1.1.0
  query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: null, sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://cite.opengeospatial.org/gmlsf\}WithGMLProperties])]
  maxFeatures = null
15 Sep 23:41:44 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Mon Sep 15 23:41:42 EDT 2008]; root of context hierarchy
15 Sep 23:41:44 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
15 Sep 23:41:44 INFO [geoserver.global] - Done disposing datastores.
15 Sep 23:41:44 INFO [geoserver.catalog] - Disposing datastore 'cite'
15 Sep 23:41:44 INFO [geoserver.catalog] - Disposing datastore 'cdf'
15 Sep 23:41:44 INFO [geoserver.catalog] - Disposing datastore 'cgf'
15 Sep 23:41:44 INFO [geoserver.catalog] - Disposing datastore 'sf'
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.104 sec
Results :
Tests run: 67, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.0-SNAPSHOT/wfs11-1.7.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.0-SNAPSHOT/wfs11-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.0-SNAPSHOT/wfs11-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis-versioned:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis:2.5-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 47 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 5 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/surefire-reports
T E S T S
Running org.geoserver.wfsv.HistoryRelatedTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.314 sec <<< FAILURE!
Running org.geoserver.wfsv.LogOrderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.038 sec <<< FAILURE!
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.054 sec <<< FAILURE!
Running org.geoserver.wfsv.RollbackTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.035 sec <<< FAILURE!
Results :
Tests in error:
  testRollbackWfs11(org.geoserver.wfsv.RollbackTest)
  testRollbackWfs10(org.geoserver.wfsv.RollbackTest)
Tests run: 5, Failures: 0, Errors: 5, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 19 seconds
[INFO] Finished at: Mon Sep 15 23:41:50 EDT 2008
[INFO] Final Memory: 34M/63M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/195/changes
