See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/198/changes
Changes:
[jdeolive] GEOS-2208, renaming / backing up feature type directories rather than deleting them
[jdeolive] GEOS-2203, including disabled feature types in master list
[arneke] GWC extension, including xstream jar in zip
[...truncated 9326 lines...]
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:440)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:421)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:634)
at org.geoserver.wfs.v1_1.GetFeatureTest.testAfterFeatureTypeAdded(GetFeatureTest.java:339)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:124)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
16 Sep 19:41:50 INFO [geoserver.catalog] - Disposing datastore 'cgf'
16 Sep 19:41:50 INFO [geoserver.catalog] - Disposing datastore 'cite'
16 Sep 19:41:50 INFO [geoserver.catalog] - Disposing datastore 'sf'
16 Sep 19:41:50 INFO [geoserver.catalog] - Disposing datastore 'cdf'
16 Sep 19:41:50 WARN [geoserver.logging] - log4jConfigFile 'TEST_LOGGING.properties' couldn't be found in the data dir, so GeoServer will install the various logging config file into the data dir, and then try to find it again.
16 Sep 19:41:50 WARN [geoserver.logging] - Still couldn't find log4jConfigFile 'TEST_LOGGING.properties'. Using DEFAULT_LOGGING.properties instead.
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
16 Sep 19:41:50 INFO [geoserver.catalog] - Default namespace: 'gs'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded style 'Ponds'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded style 'Bridges'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded style 'Forests'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded style 'Default'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded style 'Buildings'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded style 'Streams'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded style 'Lakes'
16 Sep 19:41:50 INFO [geoserver.catalog] - Processed data store 'sf', enabled
16 Sep 19:41:50 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
16 Sep 19:41:50 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
16 Sep 19:41:50 INFO [geoserver.catalog] - Processed data store 'cite', enabled
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'sf:new'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'sf:WithGMLProperties'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
16 Sep 19:41:50 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
16 Sep 19:41:50 INFO [geoserver.confg] - Loading service 'wfs'
16 Sep 19:41:50 INFO [geoserver.wfs] -
Request: getVersions
Request: getFeature
handle = null
service = wfs
version = 1.1.0
baseUrl = http://localhost:80/geoserver/
providedVersion = 1.1.0
query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: null, sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://cite.opengeospatial.org/gmlsf\}new])]
maxFeatures = null
outputFormat = text/xml; subtype=gml/3.1.1
resultType = results
traverseXlinkDepth = null
traverseXlinkExpiry = null
16 Sep 19:41:50 WARN [geotools.xml] - org.geotools.data.crs.ReprojectFeatureResults@anonymised.com (org.geotools.data.crs.ReprojectFeatureResults) is not of type [Lorg.opengis.feature.simple.SimpleFeature;
Request: getFeature
handle = null
service = wfs
version = 1.1.0
query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: null, sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://cite.opengeospatial.org/gmlsf\}WithGMLProperties])]
maxFeatures = null
16 Sep 19:41:50 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Tue Sep 16 19:41:48 EDT 2008]; root of context hierarchy
16 Sep 19:41:50 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
16 Sep 19:41:50 INFO [geoserver.global] - Done disposing datastores.
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.346 sec
Results :
Tests run: 67, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.0-SNAPSHOT/wfs11-1.7.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.0-SNAPSHOT/wfs11-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.0-SNAPSHOT/wfs11-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis-versioned:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis:2.5-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 47 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 5 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/surefire-reports
T E S T S
Running org.geoserver.wfsv.HistoryRelatedTest
16 Sep 19:42:29 INFO [geoserver.catalog] - Loaded namespace 'topp' (http://www.openplans.org/topp)
16 Sep 19:42:29 INFO [geoserver.catalog] - Loaded namespace 'it.geosolutions' (http://www.geo-solutions.it)
16 Sep 19:42:29 INFO [geoserver.catalog] - Default namespace: 'topp'
16 Sep 19:42:29 INFO [geoserver.catalog] - Loaded style 'line'
16 Sep 19:42:29 INFO [geoserver.catalog] - Loaded style 'raster'
16 Sep 19:42:29 INFO [geoserver.catalog] - Loaded style 'polygon'
16 Sep 19:42:29 INFO [geoserver.catalog] - Loaded style 'point'
16 Sep 19:42:43 INFO [geoserver.catalog] - Processed data store 'spearfish', enabled
16 Sep 19:42:43 INFO [geoserver.catalog] - Processed coverage store 'dem', enabled
16 Sep 19:42:43 INFO [geoserver.catalog] - Loaded feature type 'topp:changesets'
16 Sep 19:42:43 INFO [geoserver.catalog] - Loaded feature type 'topp:roads'
16 Sep 19:42:44 INFO [geoserver.catalog] - Loaded feature type 'topp:restricted'
16 Sep 19:42:44 INFO [geoserver.catalog] - Loaded feature type 'topp:archsites'
16 Sep 19:42:44 INFO [geoserver.confg] - Loading service 'wfs'
16 Sep 19:42:46 WARN [geotools.xml] - cvc-complex-type.3.1: Value 'WFSV' of attribute 'service' of element 'wfs:Transaction' is not valid with respect to the corresponding attribute use. Attribute 'service' has a fixed value of 'WFS'.
16 Sep 19:42:46 WARN [geotools.xml] - cvc-complex-type.2.4.a: Invalid content was found starting with element 'topp:archsites'. One of '{"http://www.opengis.net/gml":\_Feature\}' is expected.
16 Sep 19:42:47 INFO [geoserver.wfs] -
Request: transaction
handle = Inserting, updating and deleting
service = WFSV
version = 1.0.0
providedVersion = 1.0.0
lockId = null
group = [wfs:insert=net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com (feature: [org.geotools.feature.simple.SimpleFeatureImpl@anonymised.com], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null), wfs:update=net.opengis.wfs.impl.UpdateElementTypeImpl@anonymised.com (filter: [ archsites.1 ], handle: null, inputFormat: <unset>, srsName: null, typeName: {http://www.openplans.org/topp\}archsites), wfs:delete=net.opengis.wfs.impl.DeleteElementTypeImpl@anonymised.com (filter: [ archsites.2 ], handle: null, typeName: {http://www.openplans.org/topp\}archsites)]
insert = [net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com (feature: [org.geotools.feature.simple.SimpleFeatureImpl@anonymised.com], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null)]
update = [net.opengis.wfs.impl.UpdateElementTypeImpl@anonymised.com (filter: [ archsites.1 ], handle: null, inputFormat: <unset>, srsName: null, typeName: {http://www.openplans.org/topp\}archsites)]
delete = [net.opengis.wfs.impl.DeleteElementTypeImpl@anonymised.com (filter: [ archsites.2 ], handle: null, typeName: {http://www.openplans.org/topp\}archsites)]
native =
releaseAction = ALL
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 50.283 sec <<< FAILURE!
Running org.geoserver.wfsv.LogOrderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.731 sec <<< FAILURE!
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.54 sec <<< FAILURE!
Running org.geoserver.wfsv.RollbackTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.053 sec <<< FAILURE!
Results :
Failed tests:
Tests in error:
testRollbackWfs11(org.geoserver.wfsv.RollbackTest)
testRollbackWfs10(org.geoserver.wfsv.RollbackTest)
Tests run: 5, Failures: 1, Errors: 4, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/surefire-reports for the individual test results.
[INFO] Total time: 3 minutes 16 seconds
[INFO] Finished at: Tue Sep 16 19:42:48 EDT 2008
[INFO] Final Memory: 32M/63M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
