See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/21/changes
Changes:
[aaime] Updated sources for changes in geoapi interfaces. To build you'll have to rebuild gt2 with 'mvn -U install' before going to build GeoServer'
[lreed] Various WPS clean ups and reorganizations.
[dwinslow] Port patch for allowing wfs requests that do not specify the version when wfs11 is not around.
[lreed] Changed WPS Execute response to allow GML encoding.
[dwinslow] Don't separate the caching options within the feature type configuration page (GEOS-2023).
[...truncated 7264 lines...]
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.259 sec
Results :
Tests run: 67, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.0-SNAPSHOT/wfs11-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.0-SNAPSHOT/wfs11-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.0-SNAPSHOT/wfs11-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.5-SNAPSHOT: checking for updates from refractions
5294200/447b
447b downloaded
[INFO] snapshot org.geotools:gt-postgis-versioned:2.5-SNAPSHOT: checking for updates from refractions
5171/1K
5173/1K
5174/1K
1K downloaded
[INFO] snapshot org.geotools:gt-postgis:2.5-SNAPSHOT: checking for updates from refractions
5175/1K
5177/1K
5180/1K
5180/1K
1K downloaded
5182/47K
5183/47K
5185/47K
5186/47K
5187/47K
5189/47K
5190/47K
5192/47K
5193/47K
5194/47K
5196/47K
5197/47K
5199/47K
5200/47K
5201/47K
5203/47K
5204/47K
5206/47K
5207/47K
5209/47K
5210/47K
5211/47K
5213/47K
5214/47K
5216/47K
5217/47K
5218/47K
5220/47K
5221/47K
5223/47K
5224/47K
5226/47K
5227/47K
5228/47K
47K downloaded
5229/65K
5230/65K
5232/65K
5233/65K
5235/65K
5236/65K
5237/65K
5239/65K
5242/65K
5243/65K
5244/65K
5246/65K
5247/65K
5249/65K
5250/65K
5252/65K
5253/65K
5254/65K
5256/65K
5257/65K
5259/65K
5260/65K
5261/65K
5263/65K
5264/65K
5266/65K
5267/65K
5269/65K
5270/65K
5271/65K
5273/65K
5274/65K
5276/65K
5277/65K
5278/65K
5280/65K
5281/65K
5283/65K
5284/65K
5285/65K
5287/65K
5288/65K
5290/65K
5291/65K
5293/65K
5293/65K
65K downloaded
5295/82K
5296/82K
5298/82K
5299/82K
5300/82K
5302/82K
5303/82K
5305/82K
5307/82K
5309/82K
5310/82K
5312/82K
5315/82K
5316/82K
5317/82K
5319/82K
5320/82K
5322/82K
5323/82K
5324/82K
5326/82K
5327/82K
5329/82K
5330/82K
5331/82K
5333/82K
5334/82K
5336/82K
5337/82K
5339/82K
5340/82K
5341/82K
5343/82K
5344/82K
5346/82K
5347/82K
5348/82K
5350/82K
5353/82K
5354/82K
5356/82K
5357/82K
5358/82K
5360/82K
5361/82K
5363/82K
5364/82K
5365/82K
5367/82K
5368/82K
5370/82K
5371/82K
5372/82K
5375/82K
5376/82K
82K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 47 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 5 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/surefire-reports
T E S T S
Running org.geoserver.wfsv.HistoryRelatedTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.403 sec <<< FAILURE!
Running org.geoserver.wfsv.LogOrderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.056 sec <<< FAILURE!
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.027 sec <<< FAILURE!
Running org.geoserver.wfsv.RollbackTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.045 sec <<< FAILURE!
Results :
Tests in error:
testRollbackWfs11(org.geoserver.wfsv.RollbackTest)
testRollbackWfs10(org.geoserver.wfsv.RollbackTest)
Tests run: 5, Failures: 0, Errors: 5, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/surefire-reports for the individual test results.
[INFO] Total time: 6 minutes 53 seconds
[INFO] Finished at: Sun Jul 06 01:07:15 EDT 2008
[INFO] Final Memory: 34M/63M
Failed to send e-mail to lreed because no e-mail address is known, and no default e-mail domain is configured
