[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #257
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/257/changes
Changes:
[groldan] added more kml tests
[...truncated 12578 lines...]
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 01:42:18 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 01:42:18 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 01:42:18 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 01:42:18 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'sf:Tiles'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'sf:Dispersed'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'sf:Stacked'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'sf:CenteredPoly'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 01:42:18 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 01:42:18 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 01:42:18 INFO [geoserver.confg] - Loading service 'wcs'
10 Oct 01:42:18 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 01:42:18 EDT 2008]; root of context hierarchy
Oct 10, 2008 1:42:18 AM org.vfny.geoserver.global.Data destroy
INFO: Disposing DataStores at GeoServer shutdown...
INFO: Done disposing datastores.
Oct 10, 2008 1:42:18 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'cite'
INFO: Disposing datastore 'sf'
INFO: Disposing datastore 'cdf'
INFO: Disposing datastore 'cgf'
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.668 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Oct 10, 2008 1:42:18 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock11624data
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Oct 01:42:18 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded style 'Ponds'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded style 'Bridges'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded style 'Forests'
10 Oct 01:42:18 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.212 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Oct 10, 2008 1:42:19 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock11625data
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Oct 01:42:19 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded style 'Ponds'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded style 'Bridges'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded style 'Forests'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 01:42:19 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 01:42:19 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 01:42:19 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 01:42:19 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 01:42:19 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 01:42:19 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 01:42:19 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 01:42:19 INFO [geoserver.confg] - Loading service 'wcs'
10 Oct 01:42:19 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 01:42:18 EDT 2008]; root of context hierarchy
Oct 10, 2008 1:42:19 AM org.vfny.geoserver.global.Data destroy
Oct 10, 2008 1:42:19 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.205 sec
Results :
Failed tests:
  testRasterPlacemark(org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest)
  testReproject(org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest)
  test2(org.geoserver.wms.DefaultWebMapServiceTest)
  test3(org.geoserver.wms.DefaultWebMapServiceTest)
Tests run: 114, Failures: 4, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 57 seconds
[INFO] Finished at: Fri Oct 10 01:42:19 EDT 2008
[INFO] Final Memory: 35M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/258/changes
Changes:
[aaime] GEOS-2277 FeatureTypeInfo attribute list empty when a new layer is configured
[...truncated 15603 lines...]
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 09:47:56 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 09:47:56 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 09:47:56 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 09:47:56 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'sf:Tiles'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'sf:Dispersed'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'sf:Stacked'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'sf:CenteredPoly'
10 Oct 09:47:56 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 09:47:56 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 09:47:56 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 09:47:56 INFO [geoserver.confg] - Loading service 'wcs'
10 Oct 09:47:56 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 09:47:56 EDT 2008]; root of context hierarchy
Oct 10, 2008 9:47:56 AM org.vfny.geoserver.global.Data destroy
Oct 10, 2008 9:47:56 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.572 sec
Oct 10, 2008 9:47:57 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock18061data
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Oct 09:47:57 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded style 'Ponds'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded style 'Bridges'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded style 'Forests'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 09:47:57 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 09:47:57 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 09:47:57 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 09:47:57 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 09:47:57 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 09:47:57 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 09:47:57 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 09:47:57 INFO [geoserver.confg] - Loading service 'wcs'
10 Oct 09:47:57 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 09:47:56 EDT 2008]; root of context hierarchy
Oct 10, 2008 9:47:57 AM org.vfny.geoserver.global.Data destroy
Oct 10, 2008 9:47:57 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.195 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock18062data
10 Oct 09:47:57 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 09:47:57 EDT 2008]; root of context hierarchy
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.343 sec
Results :
Failed tests:
[INFO] Total time: 8 minutes 21 seconds
[INFO] Finished at: Fri Oct 10 09:47:57 EDT 2008
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/259/changes
[...truncated 12570 lines...]
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 11:40:33 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 11:40:33 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 11:40:33 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 11:40:33 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'sf:Tiles'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'sf:Dispersed'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'sf:Stacked'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'sf:CenteredPoly'
10 Oct 11:40:33 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 11:40:33 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 11:40:33 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 11:40:33 INFO [geoserver.confg] - Loading service 'wcs'
10 Oct 11:40:34 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 11:40:33 EDT 2008]; root of context hierarchy
Oct 10, 2008 11:40:34 AM org.vfny.geoserver.global.Data destroy
Oct 10, 2008 11:40:34 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.433 sec
Oct 10, 2008 11:40:34 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock31888data
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Oct 11:40:34 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded style 'Ponds'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded style 'Bridges'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded style 'Forests'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 11:40:34 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 11:40:34 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 11:40:34 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 11:40:34 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 11:40:34 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 11:40:34 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 11:40:34 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 11:40:34 INFO [geoserver.confg] - Loading service 'wcs'
10 Oct 11:40:34 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 11:40:34 EDT 2008]; root of context hierarchy
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.189 sec
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock31889data
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.238 sec
Results :
Failed tests:
[INFO] Total time: 3 minutes 8 seconds
[INFO] Finished at: Fri Oct 10 11:40:34 EDT 2008
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/260/changes
Changes:
[dwinslow] Remove testing dependency on internal order of Map's
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 13:42:21 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 13:42:21 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 13:42:21 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 13:42:21 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'sf:Tiles'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'sf:Dispersed'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'sf:Stacked'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'sf:CenteredPoly'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 13:42:21 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 13:42:21 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 13:42:21 INFO [geoserver.confg] - Loading service 'wcs'
Oct 10, 2008 1:42:21 PM org.vfny.geoserver.global.Data destroy
Oct 10, 2008 1:42:21 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
10 Oct 13:42:21 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 13:42:21 EDT 2008]; root of context hierarchy
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.638 sec
Oct 10, 2008 1:42:21 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock33999data
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Oct 13:42:21 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded style 'Ponds'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded style 'Bridges'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded style 'Forests'
10 Oct 13:42:21 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.226 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock34000data
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.222 sec
Results :
Failed tests:
[INFO] Finished at: Fri Oct 10 13:42:22 EDT 2008
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/261/changes
Changes:
[groldan] exclude only what's the offending test on my side, see what happens with hudson
[groldan] comment out the offending tests as to get the build back until I figure out what's up with the tests
[dwinslow] More order insensitivity for KML tests
[...truncated 12572 lines...]
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 14:42:17 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 14:42:17 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 14:42:17 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 14:42:17 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'sf:Tiles'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'sf:Dispersed'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'sf:Stacked'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'sf:CenteredPoly'
10 Oct 14:42:17 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 14:42:17 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 14:42:17 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 14:42:17 INFO [geoserver.confg] - Loading service 'wcs'
10 Oct 14:42:17 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 14:42:17 EDT 2008]; root of context hierarchy
Oct 10, 2008 2:42:17 PM org.vfny.geoserver.global.Data destroy
Oct 10, 2008 2:42:17 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.469 sec
Oct 10, 2008 2:42:18 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock216data
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Oct 14:42:18 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded style 'Ponds'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded style 'Bridges'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded style 'Forests'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 14:42:18 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 14:42:18 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 14:42:18 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 14:42:18 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 14:42:18 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 14:42:18 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 14:42:18 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 14:42:18 INFO [geoserver.confg] - Loading service 'wcs'
10 Oct 14:42:18 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 14:42:17 EDT 2008]; root of context hierarchy
Oct 10, 2008 2:42:18 PM org.vfny.geoserver.global.Data destroy
Oct 10, 2008 2:42:18 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.175 sec
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock217data
10 Oct 14:42:18 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 14:42:18 EDT 2008]; root of context hierarchy
Results :
Failed tests:
Tests run: 113, Failures: 4, Errors: 0, Skipped: 0
[INFO] Total time: 2 minutes 56 seconds
[INFO] Finished at: Fri Oct 10 14:42:18 EDT 2008
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/262/changes
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 16:33:34 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 16:33:34 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 16:33:34 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 16:33:34 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'sf:Tiles'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'sf:Dispersed'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'sf:Stacked'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 16:33:34 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'sf:CenteredPoly'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 16:33:35 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 16:33:35 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 16:33:35 INFO [geoserver.confg] - Loading service 'wcs'
10 Oct 16:33:35 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 16:33:34 EDT 2008]; root of context hierarchy
Oct 10, 2008 4:33:35 PM org.vfny.geoserver.global.Data destroy
Oct 10, 2008 4:33:35 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.416 sec
Oct 10, 2008 4:33:35 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock35678data
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Oct 16:33:35 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded style 'Ponds'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded style 'Bridges'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded style 'Forests'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 16:33:35 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 16:33:35 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 16:33:35 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 16:33:35 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 16:33:35 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 16:33:35 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 16:33:35 EDT 2008]; root of context hierarchy
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.181 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock35679data
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.213 sec
Results :
Failed tests:
[INFO] Total time: 2 minutes 53 seconds
[INFO] Finished at: Fri Oct 10 16:33:35 EDT 2008
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/263/changes
Changes:
[jdeolive] upgrading version numbers to 1.7.0-RC4
[dwinslow] Fix failures in disabled wms tests (not actually re-enabling since they might be causing problems elsewhere)
[...truncated 12583 lines...]
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 17:42:07 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 17:42:07 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 17:42:07 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 17:42:07 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'sf:Tiles'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'sf:Dispersed'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'sf:Stacked'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'sf:CenteredPoly'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 17:42:07 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 17:42:07 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 17:42:07 INFO [geoserver.confg] - Loading service 'wcs'
10 Oct 17:42:07 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 17:42:07 EDT 2008]; root of context hierarchy
Oct 10, 2008 5:42:07 PM org.vfny.geoserver.global.Data destroy
Oct 10, 2008 5:42:07 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.361 sec
Oct 10, 2008 5:42:07 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock9652data
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Oct 17:42:07 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded style 'Ponds'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded style 'Bridges'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded style 'Forests'
10 Oct 17:42:07 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 17:42:08 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 17:42:08 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 17:42:08 INFO [geoserver.confg] - Loading service 'wcs'
Oct 10, 2008 5:42:08 PM org.vfny.geoserver.global.Data destroy
10 Oct 17:42:08 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 17:42:07 EDT 2008]; root of context hierarchy
Oct 10, 2008 5:42:08 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.176 sec
Oct 10, 2008 5:42:08 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock9653data
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Oct 17:42:08 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded style 'Ponds'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded style 'Bridges'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded style 'Forests'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 17:42:08 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 17:42:08 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 17:42:08 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 17:42:08 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 17:42:08 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 17:42:08 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 17:42:08 EDT 2008]; root of context hierarchy
INFO: Disposing DataStores at GeoServer shutdown...
INFO: Done disposing datastores.
INFO: Disposing datastore 'sf'
INFO: Disposing datastore 'cite'
INFO: Disposing datastore 'cdf'
INFO: Disposing datastore 'cgf'
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.203 sec
Results :
Failed tests:
[INFO] Total time: 2 minutes 43 seconds
[INFO] Finished at: Fri Oct 10 17:42:08 EDT 2008
[INFO] Final Memory: 38M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/264/changes
Changes:
[dwinslow] Increase test verbosity on failure...
[...truncated 12036 lines...]
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
  at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
  at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
  at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
  at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
  at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
  at org.geoserver.test.GeoServerAbstractTestSupport.oneTimeSetUp(GeoServerAbstractTestSupport.java:164)
  at org.geoserver.test.OneTimeSetupTest$OneTimeTestSetup.setUp(OneTimeSetupTest.java:51)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:20)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor111.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
10 Oct 17:51:18 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 17:51:18 WARN [geoserver.catalog] - Ignoring feature type: 'Lakes', error occured loading schema: ./target/mock47610data/cite/Lakes.properties (No such file or directory)
java.io.FileNotFoundException: ./target/mock47610data/cite/Lakes.properties (No such file or directory)
  at java.io.FileInputStream.open(Native Method)
  at java.io.FileInputStream.<init>(FileInputStream.java:106)
  at java.io.FileReader.<init>(FileReader.java:55)
  at org.geotools.data.property.PropertyDataStore.property(PropertyDataStore.java:105)
  at org.geotools.data.property.PropertyDataStore.getSchema(PropertyDataStore.java:93)
  at org.geoserver.catalog.util.LegacyCatalogImporter.readFeatureType(LegacyCatalogImporter.java:456)
  at org.geoserver.catalog.util.LegacyCatalogImporter.imprt(LegacyCatalogImporter.java:158)
  at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:109)
  at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:73)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
  at java.security.AccessController.doPrivileged(Native Method)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
  at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
10 Oct 17:51:18 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 17:51:18 WARN [geoserver.catalog] - Ignoring feature type: 'AggregateGeoFeature', error occured loading schema: ./target/mock47610data/sf/AggregateGeoFeature.properties (No such file or directory)
java.io.FileNotFoundException: ./target/mock47610data/sf/AggregateGeoFeature.properties (No such file or directory)
10 Oct 17:51:18 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 17:51:18 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name 'geoServerLoader': org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'wfsLoader': Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.293 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Oct 10, 2008 5:51:17 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Oct 10, 2008 5:51:17 PM org.vfny.geoserver.global.Data destroy
Oct 10, 2008 5:51:17 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Oct 10, 2008 5:51:17 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock47609data
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
Oct 10, 2008 5:51:18 PM org.vfny.geoserver.global.Data destroy
Oct 10, 2008 5:51:18 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Oct 10, 2008 5:51:18 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock47610data
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.066 sec <<< FAILURE!
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.067 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
Tests run: 7, Failures: 0, Errors: 7, Skipped: 0, Time elapsed: 0.076 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.063 sec <<< FAILURE!
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.176 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Results :
Failed tests:
  testRasterPlacemark(org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest)
  testReproject(org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest)
Tests in error:
  org.vfny.geoserver.wms.responses.map.kml.KMLSuperOverlayTransformerTest
  testOutput(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
  testDataRegionator(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
  testGeometryRegionator(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
  testRandomRegionator(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
  testBogusRegionator(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
  testBigGeometries(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
  testStrategyChangesStuff(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
Tests run: 103, Failures: 2, Errors: 13, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/surefire-reports for the individual test results.
[INFO] Finished at: Fri Oct 10 17:51:19 EDT 2008
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/265/changes
[...truncated 12697 lines...]
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 18:01:30 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 18:01:30 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 18:01:30 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 18:01:30 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'sf:Tiles'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'sf:Dispersed'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'sf:Stacked'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'sf:CenteredPoly'
10 Oct 18:01:30 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 18:01:30 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 18:01:30 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 18:01:30 INFO [geoserver.confg] - Loading service 'wcs'
10 Oct 18:01:31 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 18:01:30 EDT 2008]; root of context hierarchy
Oct 10, 2008 6:01:31 PM org.vfny.geoserver.global.Data destroy
Oct 10, 2008 6:01:31 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.406 sec
Oct 10, 2008 6:01:31 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock5656data
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Oct 18:01:31 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded style 'Ponds'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded style 'Bridges'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded style 'Forests'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 18:01:31 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 18:01:31 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 18:01:31 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 18:01:31 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 18:01:31 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 18:01:31 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 18:01:31 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 18:01:31 INFO [geoserver.confg] - Loading service 'wcs'
10 Oct 18:01:31 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 18:01:31 EDT 2008]; root of context hierarchy
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock5657data
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.208 sec
Results :
Failed tests:
  test2(org.geoserver.wms.DefaultWebMapServiceTest)
  test3(org.geoserver.wms.DefaultWebMapServiceTest)
Tests run: 116, Failures: 4, Errors: 0, Skipped: 0
[INFO] Total time: 2 minutes 48 seconds
[INFO] Finished at: Fri Oct 10 18:01:31 EDT 2008
[INFO] Final Memory: 35M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/266/changes
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded style 'Default'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded style 'Streams'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded style 'Lakes'
10 Oct 18:08:42 INFO [geoserver.catalog] - Processed data store 'sf', enabled
10 Oct 18:08:42 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
10 Oct 18:08:42 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
10 Oct 18:08:42 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'sf:Tiles'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'sf:Dispersed'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'sf:Stacked'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'sf:CenteredPoly'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 18:08:42 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 18:08:42 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 18:08:42 INFO [geoserver.confg] - Loading service 'wcs'
Oct 10, 2008 6:08:42 PM org.vfny.geoserver.global.Data destroy
10 Oct 18:08:42 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 18:08:42 EDT 2008]; root of context hierarchy
Oct 10, 2008 6:08:42 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.169 sec
Oct 10, 2008 6:08:42 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock3643data
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Oct 18:08:42 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded style 'Ponds'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded style 'Bridges'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded style 'Forests'
10 Oct 18:08:42 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.171 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
SEVERE:
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/./target/mock3644data
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
10 Oct 18:08:43 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
10 Oct 18:08:43 INFO [geoserver.confg] - Loading service 'wms'
10 Oct 18:08:43 INFO [geoserver.confg] - Loading service 'wfs'
10 Oct 18:08:43 INFO [geoserver.confg] - Loading service 'wcs'
10 Oct 18:08:43 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Oct 10 18:08:42 EDT 2008]; root of context hierarchy
Oct 10, 2008 6:08:43 PM org.vfny.geoserver.global.Data destroy
Oct 10, 2008 6:08:43 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.43 sec
Results :
Failed tests:
[INFO] Finished at: Fri Oct 10 18:08:43 EDT 2008
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/267/changes
Changes:
[groldan] making the new tests extend GeoServerAbstractTestSupport seems to solve the failures, just a workaround though
started
Updating http://svn.codehaus.org/geoserver/branches/1.7.x/geoserver
U wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/KMLLegendTransformerTest.java
U wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/KMLVectorTransformerTest.java
U wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/KMLNetworkLinkTransformerTest.java
C wms/pom.xml
Fetching 'http://svn.codehaus.org/geoserver/trunk/configuration/minimal’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/minimal
At revision 10368
At revision 10368
no change for http://svn.codehaus.org/geoserver/trunk/configuration/minimal since the previous build
[geoserver_17x] $ /opt/actual/maven-2.0.9/bin/mvn -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M clean install
[INFO] Scanning for projects...
[ERROR] FATAL ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: unknown
POM Location: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/pom.xml
Reason: Parse error reading POM. Reason: unexpected character in markup < (position: START_TAG seen ... make other unrelated tests to fail and I have no idea why -->\r\n<<... @183:3) for project unknown at http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/pom.xml
[INFO] Trace
org.apache.maven.reactor.MavenExecutionException: Parse error reading POM. Reason: unexpected character in markup < (position: START_TAG seen ... make other unrelated tests to fail and I have no idea why -->\r\n<<... @183:3) for project unknown at http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/pom.xml
  at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:378)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:292)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:129)
  at org.apache.maven.cli.MavenCli.main(MavenCli.java:287)
  at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
  at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
  at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
  at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.project.InvalidProjectModelException: Parse error reading POM. Reason: unexpected character in markup < (position: START_TAG seen ... make other unrelated tests to fail and I have no idea why -->\r\n<<... @183:3) for project unknown at http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/pom.xml
  at org.apache.maven.project.DefaultMavenProjectBuilder.readModel(DefaultMavenProjectBuilder.java:1592)
  at org.apache.maven.project.DefaultMavenProjectBuilder.readModel(DefaultMavenProjectBuilder.java:1553)
  at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromSourceFileInternal(DefaultMavenProjectBuilder.java:504)
  at org.apache.maven.project.DefaultMavenProjectBuilder.build(DefaultMavenProjectBuilder.java:198)
  at org.apache.maven.DefaultMaven.getProject(DefaultMaven.java:583)
  at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:461)
  at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:534)
  at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:365)
  ... 11 more
Caused by: org.codehaus.plexus.util.xml.pull.XmlPullParserException: unexpected character in markup < (position: START_TAG seen ... make other unrelated tests to fail and I have no idea why -->\r\n<<... @183:3)
  at org.codehaus.plexus.util.xml.pull.MXParser.nextImpl(MXParser.java:1261)
  at org.codehaus.plexus.util.xml.pull.MXParser.next(MXParser.java:1093)
  at hidden.org.codehaus.plexus.util.xml.Xpp3DomBuilder.build(Xpp3DomBuilder.java:187)
  at hidden.org.codehaus.plexus.util.xml.Xpp3DomBuilder.build(Xpp3DomBuilder.java:94)
  at org.apache.maven.model.io.xpp3.MavenXpp3Reader.parsePlugin(MavenXpp3Reader.java:2955)
  at org.apache.maven.model.io.xpp3.MavenXpp3Reader.parseBuild(MavenXpp3Reader.java:753)
  at org.apache.maven.model.io.xpp3.MavenXpp3Reader.parseModel(MavenXpp3Reader.java:2224)
  at org.apache.maven.model.io.xpp3.MavenXpp3Reader.read(MavenXpp3Reader.java:4422)
  at org.apache.maven.project.DefaultMavenProjectBuilder.readModel(DefaultMavenProjectBuilder.java:1588)
  ... 18 more
[INFO] Total time: 1 second
[INFO] Finished at: Fri Oct 10 21:09:31 EDT 2008
[INFO] Final Memory: 3M/6M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/268/changes
started
ERROR: Failed to update http://svn.codehaus.org/geoserver/branches/1.7.x/geoserver
org.tmatesoft.svn.core.SVNException: svn: This client is too old to work with working copy 'http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms’; please get a newer Subversion client
  at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:49)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNAdminAreaFactory.open(SVNAdminAreaFactory.java:132)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.doOpen(SVNWCAccess.java:344)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.doOpen(SVNWCAccess.java:372)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.open(SVNWCAccess.java:261)
  at org.tmatesoft.svn.core.internal.wc.admin.SVNWCAccess.openAnchor(SVNWCAccess.java:153)
  at org.tmatesoft.svn.core.wc.SVNUpdateClient.doUpdate(SVNUpdateClient.java:145)
  at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:381)
  at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:353)
  at hudson.FilePath.act(FilePath.java:301)
  at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:347)
  at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:300)
  at hudson.model.AbstractProject.checkout(AbstractProject.java:558)
  at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:215)
  at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:181)
  at hudson.model.Run.run(Run.java:659)
  at hudson.model.Build.run(Build.java:101)
  at hudson.model.ResourceController.execute(ResourceController.java:70)
  at hudson.model.Executor.run(Executor.java:65)
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/269/changes
