[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #307
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/307/changes
Changes:
[aaime] GEOS-2322 RuntimeException on Rollback
[...truncated 12180 lines...]
  traverseXlinkExpiry = null
04 Nov 10:46:09 WARN [geotools.xml] - org.geotools.data.crs.ReprojectFeatureResults@anonymised.com (org.geotools.data.crs.ReprojectFeatureResults) is not of type [Lorg.opengis.feature.simple.SimpleFeature;
04 Nov 10:46:09 INFO [geoserver.wfs] -
Request: getVersions
Request: getFeature
  handle = null
  service = wfs
  version = 1.1.0
  baseUrl = http://localhost:80/geoserver/
  providedVersion = 1.1.0
  query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: null, sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://cite.opengeospatial.org/gmlsf\}WithGMLProperties])]
  maxFeatures = null
  outputFormat = text/xml; subtype=gml/3.1.1
  resultType = results
  traverseXlinkDepth = null
04 Nov 10:46:09 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Tue Nov 04 10:46:08 EST 2008]; root of context hierarchy
04 Nov 10:46:09 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
04 Nov 10:46:09 INFO [geoserver.global] - Done disposing datastores.
04 Nov 10:46:09 INFO [geoserver.catalog] - Disposing datastore 'cite'
04 Nov 10:46:09 INFO [geoserver.catalog] - Disposing datastore 'cgf'
04 Nov 10:46:09 INFO [geoserver.catalog] - Disposing datastore 'cdf'
04 Nov 10:46:09 INFO [geoserver.catalog] - Disposing datastore 'sf'
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.911 sec
Results :
Tests run: 68, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.1-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.1-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.1-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.1-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.1-SNAPSHOT/wfs11-1.7.1-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.1-SNAPSHOT/wfs11-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.1-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.1-SNAPSHOT/wfs11-1.7.1-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.5-SNAPSHOT: checking for updates from refractions
6722662/447b
447b downloaded
[INFO] snapshot org.geotools:gt-postgis-versioned:2.5-SNAPSHOT: checking for updates from refractions
6566/1K
6568/1K
6569/1K
1K downloaded
[INFO] snapshot org.geotools:gt-postgis:2.5-SNAPSHOT: checking for updates from refractions
6570/1K
6572/1K
6575/1K
6575/1K
1K downloaded
6577/47K
6578/47K
6581/47K
6584/47K
6585/47K
6587/47K
6591/47K
6592/47K
6595/47K
6599/47K
6601/47K
6602/47K
6605/47K
6609/47K
6613/47K
6617/47K
6621/47K
6622/47K
47K downloaded
6624/66K
6625/66K
6628/66K
6630/66K
6634/66K
6634/66K
6635/66K
6638/66K
6639/66K
6641/66K
6642/66K
6646/66K
6649/66K
6651/66K
6655/66K
6658/66K
6659/66K
6663/66K
6663/66K
6665/66K
6666/66K
6668/66K
6669/66K
6671/66K
6672/66K
6675/66K
6678/66K
6679/66K
6680/66K
6682/66K
6683/66K
6686/66K
6689/66K
66K downloaded
6691/82K
6692/82K
6693/82K
6695/82K
6696/82K
6698/82K
6701/82K
6702/82K
6705/82K
6706/82K
6710/82K
6710/82K
6714/82K
6716/82K
6719/82K
6723/82K
6725/82K
6726/82K
6727/82K
6729/82K
6730/82K
6732/82K
6733/82K
6737/82K
6741/82K
6745/82K
6746/82K
6747/82K
6749/82K
6750/82K
6753/82K
6757/82K
6760/82K
6761/82K
6763/82K
6764/82K
6767/82K
6770/82K
6772/82K
82K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 54 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 8 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/surefire-reports
T E S T S
Running org.geoserver.wfsv.security.ReadOnlyVersioningDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.611 sec
Running org.geoserver.wfsv.HistoryRelatedTest
Nov 4, 2008 10:46:50 AM org.geoserver.test.GeoServerAbstractTestSupport runTest
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testValidateInvalidRequest since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetFeatureBeforeAfter since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection10Reproject since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection11Reproject since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testLog10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testLog11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testLog10Html since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11Html since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11Reverse since test data is not available
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.079 sec
Running org.geoserver.wfsv.LogOrderTest
WARNING: Skipping class org.geoserver.wfsv.LogOrderTest.testLogForward since test data is not available
WARNING: Skipping class org.geoserver.wfsv.LogOrderTest.testLogBackwards since test data is not available
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testValidateInvalidRequest since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesPost10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesGet10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesPost11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesGet11 since test data is not available
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.wfsv.security.ReadOnlyVersioningFeatureStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.049 sec
Running org.geoserver.wfsv.RollbackTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.028 sec <<< FAILURE!
Results :
Tests in error:
  testRollbackWfs11(org.geoserver.wfsv.RollbackTest)
  testRollbackWfs10(org.geoserver.wfsv.RollbackTest)
  testInvalidRollback(org.geoserver.wfsv.RollbackTest)
Tests run: 27, Failures: 0, Errors: 3, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/surefire-reports for the individual test results.
[INFO] Total time: 6 minutes 50 seconds
[INFO] Finished at: Tue Nov 04 10:46:50 EST 2008
[INFO] Final Memory: 35M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/308/changes
