See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/314/changes
[...truncated 12649 lines...]
[INFO] [resources:testResources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:testCompile]
[INFO] Compiling 5 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/surefire-reports
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
05 Nov 20:34:24 INFO [geoserver.catalog] - Default namespace: 'gs'
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded style 'Ponds'
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded style 'Bridges'
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded style 'Forests'
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded style 'Default'
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded style 'Buildings'
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded style 'Streams'
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
05 Nov 20:34:24 INFO [geoserver.catalog] - Loaded style 'Lakes'
05 Nov 20:34:24 INFO [geoserver.catalog] - Processed data store 'sf', enabled
05 Nov 20:34:24 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
05 Nov 20:34:24 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
05 Nov 20:34:24 INFO [geoserver.catalog] - Processed data store 'cite', enabled
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
05 Nov 20:34:25 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
05 Nov 20:34:25 INFO [geoserver.confg] - Loading service 'wcs'
05 Nov 20:34:25 INFO [geoserver.confg] - Loading service 'wfs'
05 Nov 20:34:25 INFO [geoserver.confg] - Loading service 'wms'
05 Nov 20:34:27 INFO [geoserver.filters] - Created BufferedRequestWrapper with String: "Hello, this is a test" as buffer
05 Nov 20:34:27 INFO [geoserver.filters] - Created BufferedRequestWrapper with String: "LongLongLongLongLongLongLongLongLongLongLongLongLongLongLongLong" as buffer
05 Nov 20:34:27 INFO [geoserver.filters] - Created BufferedRequestWrapper with String: "" as buffer
05 Nov 20:34:27 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Wed Nov 05 20:34:23 EST 2008]; root of context hierarchy
05 Nov 20:34:27 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
05 Nov 20:34:27 INFO [geoserver.global] - Done disposing datastores.
05 Nov 20:34:27 INFO [geoserver.catalog] - Disposing datastore 'cgf'
05 Nov 20:34:27 INFO [geoserver.catalog] - Disposing datastore 'sf'
05 Nov 20:34:27 INFO [geoserver.catalog] - Disposing datastore 'cdf'
05 Nov 20:34:27 INFO [geoserver.catalog] - Disposing datastore 'cite'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.847 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Running org.vfny.geoserver.jetty.SpringContextTest
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded namespace 'sf' (http://cite.opengeospatial.org/gmlsf)
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded namespace 'cdf' (http://www.opengis.net/cite/data)
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded namespace 'cgf' (http://www.opengis.net/cite/geometry)
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
05 Nov 20:34:27 INFO [geoserver.catalog] - Default namespace: 'gs'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded style 'Ponds'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded style 'NamedPlaces'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded style 'RoadSegments'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded style 'Bridges'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded style 'DividedRoutes'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded style 'Forests'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded style 'BasicPolygons'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded style 'Default'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded style 'Buildings'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded style 'Streams'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded style 'MapNeatline'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded style 'Lakes'
05 Nov 20:34:27 INFO [geoserver.catalog] - Processed data store 'sf', enabled
05 Nov 20:34:27 INFO [geoserver.catalog] - Processed data store 'cdf', enabled
05 Nov 20:34:27 INFO [geoserver.catalog] - Processed data store 'cgf', enabled
05 Nov 20:34:27 INFO [geoserver.catalog] - Processed data store 'cite', enabled
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cdf:Deletes'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:Forests'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:Streams'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cgf:Points'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:Ponds'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cdf:Nulls'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:RoadSegments'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cdf:Other'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:NamedPlaces'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPolygons'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:Bridges'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'sf:GenericEntity'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'sf:PrimitiveGeoFeature'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cgf:MPoints'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cdf:Locks'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cgf:MLines'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cdf:Fifteen'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:DividedRoutes'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cdf:Updates'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cgf:Polygons'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:Geometryless'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:Lakes'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:MapNeatline'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cgf:Lines'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cdf:Inserts'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'cdf:Seven'
05 Nov 20:34:27 INFO [geoserver.catalog] - Loaded feature type 'sf:AggregateGeoFeature'
05 Nov 20:34:27 INFO [geoserver.confg] - Loading service 'wcs'
05 Nov 20:34:27 INFO [geoserver.confg] - Loading service 'wfs'
05 Nov 20:34:27 INFO [geoserver.confg] - Loading service 'wms'
05 Nov 20:34:27 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Wed Nov 05 20:34:27 EST 2008]; root of context hierarchy
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.377 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.356 sec
Results :
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT-sources.jar
[INFO] [config:config {execution: configPackage}]
config:
[ERROR] BUILD ERROR
[INFO] Failed to execute: Executing Ant script: /config.build.xml [config]: Failed to execute.
Unable to locate configuration: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/../../configuration/release
[INFO] Total time: 3 minutes 8 seconds
[INFO] Finished at: Wed Nov 05 20:34:29 EST 2008
[INFO] Final Memory: 38M/63M
