See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/331/changes
Changes:
[jdeolive] GEOT-2174 added a callback to CatalogListener which lets listeners know when the catalog has been reloaded
[aaime] GEOS-2341 GeoServer incorrectly caluates bounding box on PostGIS table
[aaime] Imports cleanup
[...truncated 387 lines...]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-cql:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt-cql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-validation:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt-validation:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-data:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt-data:2.5-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 233 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/classes
[INFO] [resources:testResources]
[INFO] snapshot org.geoserver:ows:1.7.1-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geoserver:ows:1.7.1-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geoserver:data:1.7.1-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geoserver:data:1.7.1-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:testCompile]
[INFO] Compiling 26 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/surefire-reports
T E S T S
Running org.geoserver.security.decorators.ReadOnlyDataAccessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.57 sec
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.073 sec
Running org.geoserver.catalog.impl.InfoObjectProxyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.security.SecureCatalogImplTest
Nov 10, 2008 8:12:15 PM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Rule *.*.r=* is overriding another rule targetting the same resource
WARNING: Rule *.*.w=* is overriding another rule targetting the same resource
WARNING: Rule *.*.r=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.w=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.r=READER is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.bases.w=MILITARY
WARNING: Layer topp is unknown in rule + topp.states.w=WRITER
WARNING: Layer topp is unknown in rule + topp.bases.r=MILITARY
WARNING: Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.landmarks.w=WRITER
WARNING: Layer topp is unknown in rule + topp.states.r=READER
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.399 sec
Running org.geoserver.template.GeoServerTemplateLoaderTest
Nov 10, 2008 8:12:17 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'sf'
INFO: Disposing datastore 'cite'
INFO: Disposing datastore 'cgf'
INFO: Disposing datastore 'cdf'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.367 sec
Running org.geoserver.vfny.global.TolerantStartupTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
10 Nov 20:12:17 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Mon Nov 10 20:12:17 EST 2008]; root of context hierarchy
10 Nov 20:12:17 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
10 Nov 20:12:17 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
10 Nov 20:12:17 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/./target/mock44532data
10 Nov 20:12:17 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
10 Nov 20:12:17 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
10 Nov 20:12:17 INFO [geoserver.catalog] - Default namespace: 'gs'
10 Nov 20:12:17 INFO [geoserver.catalog] - Loaded style 'Default'
10 Nov 20:12:17 INFO [geoserver.catalog] - Loaded style 'Buildings'
10 Nov 20:12:17 INFO [geoserver.catalog] - Processed data store 'cite', enabled
10 Nov 20:12:17 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
10 Nov 20:12:17 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
10 Nov 20:12:17 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Mon Nov 10 20:12:17 EST 2008]; root of context hierarchy
10 Nov 20:12:17 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
10 Nov 20:12:17 INFO [geoserver.global] - Done disposing datastores.
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.135 sec <<< FAILURE!
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.config.LegacyConfigurationImporterTest
Nov 10, 2008 8:12:17 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.087 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.161 sec
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Nov 10, 2008 8:12:18 PM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
Nov 10, 2008 8:12:18 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.777 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 39, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
Nov 10, 2008 8:12:19 PM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.095 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.config.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Results :
Failed tests:
testContextStartup(org.geoserver.vfny.global.TolerantStartupTest)
Tests run: 93, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 3 seconds
[INFO] Finished at: Mon Nov 10 20:12:19 EST 2008
[INFO] Final Memory: 31M/56M
