[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #373
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/373/changes
Changes:
[aaime] GEOS-2399 Need a way to specify the encoding of shapefiles generated with SHAPE-ZIP output format
[...truncated 1607 lines...]
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:69)
  ... 48 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
  at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:125)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  ... 50 more
20 Nov 21:25:52 ERROR [geoserver.ows] -
java.io.IOException
  at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:71)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:711)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:957)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:924)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:570)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:545)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:722)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:705)
  at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorPost(GetCapabilitiesTest.java:176)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:125)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  ... 48 more
  ... 50 more
java.io.IOException
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:443)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:424)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:656)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:637)
  at org.geoserver.wcs.GetCapabilitiesTest.testSectionsBogus(GetCapabilitiesTest.java:183)
  ... 48 more
Caused by: org.vfny.geoserver.wcs.WcsException: Unknown section Bogus
  at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:172)
  ... 50 more
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.559 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/wcs1_1-1.7.1-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/wcs1_1-1.7.1-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] [javacc:jjtree {execution: jjtree}]
[INFO] Nothing to process - all grammars in http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset are up to date.
[INFO] [javacc:javacc {execution: javacc}]
[INFO] Nothing to process - all grammars in http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/generated-sources/jjtree are up to date.
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/wcs1_1-1.7.1-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/wcs1_1-1.7.1-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/1.7.1-SNAPSHOT/wcs1_1-1.7.1-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/wcs1_1-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/1.7.1-SNAPSHOT/wcs1_1-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs1_1/target/wcs1_1-1.7.1-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/1.7.1-SNAPSHOT/wcs1_1-1.7.1-SNAPSHOT-sources.jar
[INFO] Building Validation Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/validation/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 6 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/validation/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/validation/target/validation-1.7.1-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/validation/target/validation-1.7.1-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/validation/target/validation-1.7.1-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/validation/target/validation-1.7.1-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/validation/1.7.1-SNAPSHOT/validation-1.7.1-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/validation/target/validation-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/validation/1.7.1-SNAPSHOT/validation-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/validation/target/validation-1.7.1-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/validation/1.7.1-SNAPSHOT/validation-1.7.1-SNAPSHOT-sources.jar
[INFO] Building Web Feature Service Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs/target
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 167 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs/src/main/java/org/geoserver/wfs/response/ShapeZipOutputFormat.java :[165,14] cannot find symbol
symbol : method getFormatOptions()
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs/src/main/java/org/geoserver/wfs/response/ShapeZipOutputFormat.java :[165,48] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs/src/main/java/org/geoserver/wfs/response/ShapeZipOutputFormat.java :[166,33] cannot find symbol
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs/src/main/java/org/geoserver/wfs/kvp/GetFeatureKvpRequestReader.java :[213,15] cannot find symbol
[INFO] Total time: 1 minute 51 seconds
[INFO] Finished at: Thu Nov 20 21:26:02 EST 2008
[INFO] Final Memory: 36M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/374/changes
