[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #378
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/378/changes
Changes:
[jdeolive] GEOS-2333, service enabled checks for services
[...truncated 3500 lines...]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.1-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.1-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.1-SNAPSHOT/wms-1.7.1-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.1-SNAPSHOT/wms-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.1-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.1-SNAPSHOT/wms-1.7.1-SNAPSHOT-sources.jar
[INFO] Building Web Application Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/webapp/data
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-postgis:2.5-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 108 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 6 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/surefire-reports
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.279 sec
Running org.vfny.geoserver.jetty.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.077 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Running org.vfny.geoserver.jetty.SpringContextTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.382 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.359 sec
Results :
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT-sources.jar
[INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/minimal
     [copy] Copying 14 files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/webapp/data
     [copy] Copied 12 empty directories to 9 empty directories under http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/webapp/data
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.1-SNAPSHOT/web-1.7.1-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.1-SNAPSHOT/web-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.1-SNAPSHOT/web-1.7.1-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web] in [http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/geoserver\]
[INFO] Processing war project
[INFO] Webapp assembled in[2267 msecs]
[INFO] Building war: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/geoserver.war
[INFO] Building Community Space
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/target/community-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/pom.xml to /home/tomcat/.m2/repository/org/geoserver/community/1.7.1-SNAPSHOT/community-1.7.1-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/target/community-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/community/1.7.1-SNAPSHOT/community-1.7.1-SNAPSHOT-tests.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target
[INFO] snapshot org.opengeo:geowebcache:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.opengeo:geowebcache:1.0-SNAPSHOT: checking for updates from refractions
[INFO] Nothing to compile - all classes are up to date
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-0.1.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-0.1-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-0.1-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-0.1.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/0.1/gwc-0.1.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-0.1-tests.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/0.1/gwc-0.1-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-0.1-sources.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/0.1/gwc-0.1-sources.jar
[INFO] Building GeoServer Extensions
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/target/extension-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/pom.xml to /home/tomcat/.m2/repository/org/geoserver/extension/1.7.1-SNAPSHOT/extension-1.7.1-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/target/extension-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/1.7.1-SNAPSHOT/extension-1.7.1-SNAPSHOT-tests.jar
[INFO] Building H2 DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target
[INFO] snapshot org.geotools:gt-jdbc-h2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-jdbc-core:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/surefire-reports
T E S T S
Running org.geoserver.h2.H2DataStoreInitializerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.606 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/1.7.1-SNAPSHOT/h2-1.7.1-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/1.7.1-SNAPSHOT/h2-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/1.7.1-SNAPSHOT/h2-1.7.1-SNAPSHOT-sources.jar
[INFO] Building SQL Server DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target
[INFO] snapshot org.geotools:gt-jdbc-sqlserver:2.5-SNAPSHOT: checking for updates from refractions
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.1-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.1-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.1-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.1-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/sqlserver/1.7.1-SNAPSHOT/sqlserver-1.7.1-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/sqlserver/1.7.1-SNAPSHOT/sqlserver-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.1-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/sqlserver/1.7.1-SNAPSHOT/sqlserver-1.7.1-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/wfsv/target
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis-versioned:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 54 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/wfsv/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/wfsv/src/main/java/org/geoserver/wfsv/DefaultVersioningWebFeatureService.java :[46,7] org.geoserver.wfsv.DefaultVersioningWebFeatureService is not abstract and does not override abstract method getServiceInfo() in org.geoserver.wfs.WebFeatureService
[INFO] Total time: 9 minutes 28 seconds
[INFO] Finished at: Fri Nov 21 21:49:28 EST 2008
[INFO] Final Memory: 40M/63M
woops, bad Justin. fixing.
Changes:
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.1-SNAPSHOT-sources.jar [INFO] [install:install]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target [INFO] [cobertura:clean {execution: default}]
clean:
   [delete] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/webapp/data [INFO] [resources:resources]
[INFO] Compiling 108 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/classes [INFO] [resources:testResources]
[INFO] Compiling 6 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/test-classes [INFO] [surefire:test]
T E S T S
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT.jar [INFO] [jar:test-jar {execution: default}]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT-tests.jar [INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT-sources.jar [INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/minimal [copy] Copying 14 files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/webapp/data [copy] Copied 12 empty directories to 9 empty directories under http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/webapp/data [INFO] [install:install]
[INFO] Assembling webapp[web] in [http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/geoserver\] [INFO] Processing war project
[INFO] Building war: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/geoserver.war [INFO] ------------------------------------------------------------------------
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/target [INFO] [cobertura:clean {execution: default}]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/target/community-1.7.1-SNAPSHOT-tests.jar [INFO] Preparing source:jar
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target [INFO] [cobertura:clean {execution: default}]
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-0.1.jar [INFO] [jar:test-jar {execution: default}]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-0.1-tests.jar [INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-0.1-sources.jar [INFO] [install:install]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/target [INFO] [cobertura:clean {execution: default}]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/target/extension-1.7.1-SNAPSHOT-tests.jar [INFO] Preparing source:jar
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target [INFO] [cobertura:clean {execution: default}]
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/classes [INFO] [resources:testResources]
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/test-classes [INFO] [surefire:test]
T E S T S
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT.jar [INFO] [jar:test-jar {execution: default}]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT-tests.jar [INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT-sources.jar [INFO] [install:install]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target [INFO] [cobertura:clean {execution: default}]
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.1-SNAPSHOT.jar [INFO] [jar:test-jar {execution: default}]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.1-SNAPSHOT-tests.jar [INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.1-SNAPSHOT-sources.jar [INFO] [install:install]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/wfsv/target [INFO] [cobertura:clean {execution: default}]
[INFO] Compiling 54 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/wfsv/target/classes [INFO] ------------------------------------------------------------------------
Justin Deoliveira
OpenGeo - http://opengeo.org
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/379/changes
