See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/389/changes
Changes:
[jdeolive] GEOS-2407, adding oracleng extension
[aaime] Disabling labeller-ng
[dwinslow] Allow placemark templates to access type metadata (GEOS-2423)
[aaime] Fixing persistence/loading issues with the new mosaic native acceleration parameter
[...truncated 563 lines...]
at org.geoserver.vfny.global.TolerantStartupTest.testContextStartup(TolerantStartupTest.java:43)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:125)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:123456" from authority "European Petroleum Survey Group" found for object of type "CoordinateReferenceSystem".
at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:949)
at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createCoordinateReferenceSystem(DirectEpsgFactory.java:2000)
at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:781)
at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:798)
at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:638)
at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:729)
at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
at org.geotools.referencing.CRS.decode(CRS.java:420)
at org.geotools.referencing.CRS.decode(CRS.java:348)
at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:994)
... 31 more
24 Nov 20:32:16 ERROR [geoserver.global] - Could not load feature type cite:BasicPolygons
java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:123456" from authority "European Petroleum Survey Group" found for object of type "CoordinateReferenceSystem".
at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:998)
at org.vfny.geoserver.global.FeatureTypeInfo.toDTO(FeatureTypeInfo.java:522)
at org.vfny.geoserver.global.Data.toDTO(Data.java:1604)
at org.vfny.geoserver.global.Config.getData(Config.java:107)
at org.geoserver.vfny.global.TolerantStartupTest.testContextStartup(TolerantStartupTest.java:44)
... 31 more
24 Nov 20:32:16 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Mon Nov 24 20:32:16 EST 2008]; root of context hierarchy
24 Nov 20:32:16 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
24 Nov 20:32:16 INFO [geoserver.global] - Done disposing datastores.
Nov 24, 2008 8:32:16 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.14 sec
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
24 Nov 20:32:16 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
24 Nov 20:32:16 INFO [geoserver.catalog] - Default namespace: 'gs'
24 Nov 20:32:16 INFO [geoserver.catalog] - Loaded style 'Default'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.config.LegacyConfigurationImporterTest
Nov 24, 2008 8:32:16 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.099 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.16 sec <<< FAILURE!
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Nov 24, 2008 8:32:16 PM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Rule *.*.r=* is overriding another rule targetting the same resource
WARNING: Rule *.*.w=* is overriding another rule targetting the same resource
WARNING: Rule *.*.r=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.w=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.r=READER is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.bases.w=MILITARY
WARNING: Layer topp is unknown in rule + topp.states.w=WRITER
WARNING: Layer topp is unknown in rule + topp.bases.r=MILITARY
WARNING: Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.landmarks.w=WRITER
WARNING: Layer topp is unknown in rule + topp.states.r=READER
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
INFO: Disposing datastore 'cdf'
INFO: Disposing datastore 'cgf'
INFO: Disposing datastore 'sf'
Nov 24, 2008 8:32:17 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.719 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 39, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.027 sec
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
Nov 24, 2008 8:32:17 PM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.083 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.config.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Results :
Tests in error:
testFeatureCollection(org.geoserver.template.FeatureWrapperTest)
testFeatureSimple(org.geoserver.template.FeatureWrapperTest)
testFeatureDynamic(org.geoserver.template.FeatureWrapperTest)
Tests run: 93, Failures: 0, Errors: 3, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/surefire-reports for the individual test results.
[INFO] Total time: 49 seconds
[INFO] Finished at: Mon Nov 24 20:32:17 EST 2008
[INFO] Final Memory: 28M/63M
