See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/40/changes
Changes:
[lreed] WPS add case insensitive describe process 'all' test.
[aaime] Data regionation v2 ready for review
[...truncated 2565 lines...]
</gml:boundedBy>
<topp:revision>1</topp:revision>
<topp:date>2008-07-15T16:42:08.622-04:00</topp:date>
<topp:message>Version enabling archsites</topp:message>
<topp:bbox>
<gml:Polygon srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
<gml:exterior>
<gml:LinearRing>
<gml:posList>-103.87241500202342 44.381622486951365 -103.82532710432608 44.381622486951365 -103.82532710432608 44.45652100092533 -103.87241500202342 44.45652100092533 -103.87241500202342 44.381622486951365</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</topp:bbox>
</topp:changesets>
</gml:featureMembers>
</wfs:FeatureCollection>
net.opengis.wfs.impl.TransactionTypeImpl@anonymised.com (handle: null, service: <unset>, version: <unset>, baseUrl: null, providedVersion: null) (lockId: null, group: [wfs:update=net.opengis.wfs.impl.UpdateElementTypeImpl@anonymised.com (filter: [ archsites.1 ], handle: null, inputFormat: <unset>, srsName: null, typeName: {http://www.openplans.org/topp\}archsites), wfs:insert=net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com (feature: [org.geotools.feature.simple.SimpleFeatureImpl@anonymised.com], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null), wfs:delete=net.opengis.wfs.impl.DeleteElementTypeImpl@anonymised.com (filter: [ archsites.2 ], handle: null, typeName: {http://www.openplans.org/topp\}archsites)], releaseAction: <unset>)
<wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:ows="http://www.opengis.net/ows" xmlns:topp="http://www.openplans.org/topp" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" releaseAction="ALL" service="WFS" version="1.1.0" xsi:schemaLocation="http://www.openplans.org/topp http://localhost:80/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=topp:archsites http://www.opengis.net/wfs http://localhost:80/geoserver/schemas/wfs/1.1.0/wfs.xsd">
<wfs:Insert idgen="GenerateNew" inputFormat="text/xml; subtype=gml/3.1.1">
<topp:archsites gml:id="archsites.5">
<gml:boundedBy>
<gml:Envelope srsName="http://www.opengis.net/gml/srs/epsg.xml#26713">
<gml:lowerCorner>604000.0 4930000.0</gml:lowerCorner>
<gml:upperCorner>604000.0 4930000.0</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
<topp:cat>2</topp:cat>
<topp:str1>Alien crash site</topp:str1>
<topp:the_geom>
<gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#26713">
<gml:pos>604000.0 4930000.0</gml:pos>
</gml:Point>
</topp:the_geom>
</topp:archsites>
</wfs:Insert>
<wfs:Update inputFormat="x-application/gml:3" typeName="topp:archsites">
<wfs:Property>
<wfs:Name>str1</wfs:Name>
<wfs:Value>Signature Rock, updated</wfs:Value>
</wfs:Property>
<ogc:Filter>
<ogc:FeatureId fid="archsites.1"/>
</ogc:Filter>
</wfs:Update>
<wfs:Delete typeName="topp:archsites">
<ogc:Filter>
<ogc:FeatureId fid="archsites.2"/>
</ogc:Filter>
</wfs:Delete>
</wfs:Transaction>
net.opengis.wfs.impl.TransactionTypeImpl@anonymised.com (handle: null, service: <unset>, version: <unset>, baseUrl: null, providedVersion: null) (lockId: null, group: [wfs:update=net.opengis.wfs.impl.UpdateElementTypeImpl@anonymised.com (filter: [ archsites.1 ], handle: null, inputFormat: <unset>, srsName: null, typeName: {http://www.openplans.org/topp\}archsites), wfs:insert=net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com (feature: [org.geotools.feature.simple.SimpleFeatureImpl@anonymised.com], handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null), wfs:delete=net.opengis.wfs.impl.DeleteElementTypeImpl@anonymised.com (filter: [ archsites.5 ], handle: null, typeName: {http://www.openplans.org/topp\}archsites)], releaseAction: <unset>)
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.891 sec
Running org.geoserver.wfsv.LogOrderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.297 sec
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:gml="http://www.opengis.net/wfsv" xmlns:topp="http://www.openplans.org/topp" attributeFormDefault="unqualified" elementFormDefault="qualified" targetNamespace="http://www.openplans.org/topp" version="1.0">
<xs:import namespace="http://www.opengis.net/wfsv" schemaLocation="http://localhost:80/geoserver/schemas/wfs/1.0.0/WFS-versioning.xsd"/>
<xs:complexType xmlns="http://www.w3.org/2001/XMLSchema" name="archsites_Type" xmlns:xs="http://www.w3.org/2001/XMLSchema">
<xs:complexContent>
<xs:extension base="wfsv:AbstractVersionedFeatureType">
<xs:sequence>
<xs:element minOccurs="0" name="cat" nillable="true" type="xs:long"/>
<xs:element minOccurs="0" name="str1" nillable="true">
<xs:simpleType>
<xs:restriction base="xs:string">
<xs:maxLength value="2147483647"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element minOccurs="0" name="the_geom" nillable="true" type="gml:PointPropertyType"/>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
<xs:element name="archsites" substitutionGroup="wfsv:_VersionedFeature" type="topp:archsites_Type"/>
</xs:schema>
<xs:complexContent>
<xs:sequence>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:element>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:schema>
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:gml="http://www.opengis.net/gml" xmlns:topp="http://www.openplans.org/topp" xmlns:wfsv="http://www.opengis.net/wfsv" elementFormDefault="qualified" targetNamespace="http://www.openplans.org/topp">
<xsd:import namespace="http://www.opengis.net/wfsv" schemaLocation="http://localhost:80/geoserver/wfs/schemas/wfs/1.1.0/wfsv.xsd"/>
<xsd:complexType name="archsitesType">
<xsd:complexContent>
<xsd:extension base="wfsv:AbstractVersionedFeatureType">
<xsd:sequence>
<xsd:element maxOccurs="1" minOccurs="0" name="cat" nillable="true" type="xsd:long"/>
<xsd:element maxOccurs="1" minOccurs="0" name="str1" nillable="true" type="xsd:string"/>
<xsd:element maxOccurs="1" minOccurs="0" name="the_geom" nillable="true" type="gml:PointPropertyType"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name="archsites" substitutionGroup="wfsv:_VersionedFeature" type="topp:archsitesType"/>
</xsd:schema>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.501 sec
Running org.geoserver.wfsv.RollbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.84 sec
Results :
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/wfsv-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/wfsv-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Map Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-render:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-wfs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-wms:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-xml:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 140 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 33 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/test-classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[105,30] cannot find symbol
symbol : class TileLevel
location: class org.vfny.geoserver.wms.responses.map.kml.TileLevelTest
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/CachedHierarchyRegionatingStrategyTest.java :[29,54] cannot find symbol
symbol : method getWorldBounds()
location: class org.vfny.geoserver.wms.responses.map.kml.CachedHierarchyRegionatingStrategy
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/CachedHierarchyRegionatingStrategyTest.java :[44,61] cannot find symbol
symbol : method expandToTile(org.geotools.geometry.jts.ReferencedEnvelope)
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/CachedHierarchyRegionatingStrategyTest.java :[52,63] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/CachedHierarchyRegionatingStrategyTest.java :[60,63] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/CachedHierarchyRegionatingStrategyTest.java :[69,89] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[39,8] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[39,83] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[39,25] cannot find symbol
symbol : variable TileLevel
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[60,12] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[60,30] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[62,45] inconvertible types
found : <nulltype>
required: int
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[75,8] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[75,83] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[75,25] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[87,8] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[87,83] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[87,25] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/src/test/java/org/vfny/geoserver/wms/responses/map/kml/TileLevelTest.java :[109,54] cannot find symbol
[INFO] Total time: 2 minutes 49 seconds
[INFO] Finished at: Tue Jul 15 16:42:32 EDT 2008
[INFO] Final Memory: 34M/63M
Failed to send e-mail to lreed because no e-mail address is known, and no default e-mail domain is configured
