[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #421
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/421/changes
Changes:
[jdeolive] null check in encodeFormatOptions()
[jdeolive] reducing log level of message stating no default regionating strategy set
[...truncated 2017 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
04 Dec 06:42:00 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Unknown namespace [youdontknowme]
  at org.geoserver.wfs.kvp.QNameKvpParser.parseToken(QNameKvpParser.java:54)
  at org.geoserver.ows.FlatKvpParser.parse(FlatKvpParser.java:76)
  at org.geoserver.ows.util.KvpUtils.parse(KvpUtils.java:471)
  at org.geoserver.ows.Dispatcher.parseKVP(Dispatcher.java:1049)
  at org.geoserver.ows.Dispatcher.init(Dispatcher.java:245)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:191)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:957)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:924)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:443)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:424)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:656)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:637)
  at org.geoserver.wfs.GetFeatureTest.testAlienNamespace(GetFeatureTest.java:51)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:125)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.382 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.207 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
Feature type cite:InvalidTypeName unknown
Feature type gs:InvalidTypeName unknown
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.569 sec
Running org.geoserver.wfs.LockFeatureTest
04 Dec 06:42:02 ERROR [geoserver.wfs] - Transaction failed
org.geoserver.wfs.WFSTransactionException: Transaction does not have authorization for Locks:Locks.0
  at org.geoserver.wfs.DeleteElementHandler.execute(DeleteElementHandler.java:188)
  at org.geoserver.wfs.Transaction.execute(Transaction.java:333)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:108)
  at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:182)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy11.transaction(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:582)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:211)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:570)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:545)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:722)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:705)
  at org.geoserver.wfs.LockFeatureTest.testDeleteWithoutLockId(LockFeatureTest.java:105)
  at sun.reflect.GeneratedMethodAccessor159.invoke(Unknown Source)
Caused by: org.geotools.data.FeatureLockException: Transaction does not have authorization for Locks:Locks.0
  at org.geotools.data.InProcessLockingManager.assertAccess(InProcessLockingManager.java:285)
  at org.geotools.data.InProcessLockingManager$1.remove(InProcessLockingManager.java:323)
  at org.geotools.data.FilteringFeatureWriter.remove(FilteringFeatureWriter.java:88)
  at org.geotools.data.AbstractFeatureStore.removeFeatures(AbstractFeatureStore.java:315)
  at org.vfny.geoserver.global.GeoServerFeatureStore.removeFeatures(GeoServerFeatureStore.java:94)
  at org.geoserver.wfs.DeleteElementHandler.execute(DeleteElementHandler.java:176)
  ... 62 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.382 sec
Running org.geoserver.wfs.response.ShapeZipTest
Dec 4, 2008 6:42:02 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.89 sec <<< FAILURE!
Running org.geoserver.wfs.GetFeatureWithLockTest
04 Dec 06:42:03 ERROR [geoserver.wfs] - Transaction failed
org.geoserver.wfs.WFSTransactionException: update error
  at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:239)
  at sun.reflect.GeneratedMethodAccessor161.invoke(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor160.invoke(Unknown Source)
  at org.geoserver.wfs.GetFeatureWithLockTest.testUpdateLockedFeatureWithoutLockId(GetFeatureWithLockTest.java:128)
  at org.geotools.data.InProcessLockingManager$1.write(InProcessLockingManager.java:332)
  at org.geotools.data.FilteringFeatureWriter.write(FilteringFeatureWriter.java:106)
  at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:160)
  at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:102)
  at org.vfny.geoserver.global.GeoServerFeatureStore.modifyFeatures(GeoServerFeatureStore.java:129)
  at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:229)
  ... 64 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.689 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.349 sec
Running org.geoserver.wfs.kvp.FilterKvpParserTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Results :
Tests in error:
  testCharset(org.geoserver.wfs.response.ShapeZipTest)
Tests run: 72, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 20 seconds
[INFO] Finished at: Thu Dec 04 06:42:04 EST 2008
[INFO] Final Memory: 32M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/422/changes
[...truncated 2016 lines...]
04 Dec 07:49:10 ERROR [geoserver.ows] -
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.35 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.149 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.373 sec
04 Dec 07:49:12 ERROR [geoserver.wfs] - Transaction failed
  ... 62 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.182 sec
Dec 4, 2008 7:49:12 AM java.util.prefs.FileSystemPreferences$7 run
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.361 sec <<< FAILURE!
04 Dec 07:49:13 ERROR [geoserver.wfs] - Transaction failed
  ... 64 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.591 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.336 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Results :
Tests in error:
[INFO] Total time: 1 minute 54 seconds
[INFO] Finished at: Thu Dec 04 07:49:14 EST 2008
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/423/changes
Changes:
[jdeolive] GEOS-2470, passing through format_options
04 Dec 21:41:46 ERROR [geoserver.ows] -
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.376 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.152 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.326 sec
04 Dec 21:41:47 ERROR [geoserver.wfs] - Transaction failed
  ... 62 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.207 sec
Dec 4, 2008 9:41:48 PM java.util.prefs.FileSystemPreferences$7 run
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.354 sec <<< FAILURE!
04 Dec 21:41:48 ERROR [geoserver.wfs] - Transaction failed
  ... 64 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.576 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.367 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Results :
Tests in error:
[INFO] Total time: 2 minutes 7 seconds
[INFO] Finished at: Thu Dec 04 21:41:49 EST 2008
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/424/changes
