[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #446
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/446/changes
Changes:
[jdeolive] GEOS-2509, upgraded h2 version
[jdeolive] cleaned up extension dependencies, added arcsde extension
[...truncated 4797 lines...]
2502/3157K
2506/3157K
2510/3157K
2514/3157K
2518/3157K
2520/3157K
2524/3157K
2528/3157K
2532/3157K
2536/3157K
2540/3157K
2544/3157K
2548/3157K
2551/3157K
2555/3157K
2559/3157K
2560/3157K
2564/3157K
2568/3157K
2572/3157K
2576/3157K
2580/3157K
2584/3157K
2585/3157K
2586/3157K
2588/3157K
2589/3157K
2592/3157K
2595/3157K
2599/3157K
2599/3157K
2603/3157K
2606/3157K
2610/3157K
2614/3157K
2617/3157K
2619/3157K
2620/3157K
2624/3157K
2628/3157K
2632/3157K
2633/3157K
2637/3157K
2641/3157K
2645/3157K
2649/3157K
2649/3157K
2650/3157K
2653/3157K
2657/3157K
2661/3157K
2662/3157K
2666/3157K
2670/3157K
2672/3157K
2676/3157K
2680/3157K
2680/3157K
2681/3157K
2684/3157K
2688/3157K
2690/3157K
2694/3157K
2697/3157K
2701/3157K
2705/3157K
2707/3157K
2711/3157K
2713/3157K
2714/3157K
2718/3157K
2721/3157K
2725/3157K
2729/3157K
2733/3157K
2737/3157K
2741/3157K
2744/3157K
2748/3157K
2752/3157K
2756/3157K
2760/3157K
2764/3157K
2768/3157K
2772/3157K
2776/3157K
2780/3157K
2784/3157K
2788/3157K
2792/3157K
2796/3157K
2800/3157K
2804/3157K
2808/3157K
2811/3157K
2815/3157K
2819/3157K
2823/3157K
2827/3157K
2830/3157K
2834/3157K
2838/3157K
2842/3157K
2842/3157K
2846/3157K
2850/3157K
2854/3157K
2858/3157K
2862/3157K
2866/3157K
2870/3157K
2873/3157K
2875/3157K
2879/3157K
2883/3157K
2887/3157K
2891/3157K
2895/3157K
2899/3157K
2903/3157K
2906/3157K
2910/3157K
2914/3157K
2918/3157K
2922/3157K
2926/3157K
2930/3157K
2934/3157K
2937/3157K
2939/3157K
2942/3157K
2946/3157K
2950/3157K
2954/3157K
2956/3157K
2958/3157K
2962/3157K
2966/3157K
2969/3157K
2973/3157K
2977/3157K
2981/3157K
2985/3157K
2989/3157K
2993/3157K
2997/3157K
3001/3157K
3005/3157K
3009/3157K
3010/3157K
3011/3157K
3014/3157K
3018/3157K
3022/3157K
3026/3157K
3030/3157K
3034/3157K
3038/3157K
3042/3157K
3046/3157K
3047/3157K
3051/3157K
3055/3157K
3059/3157K
3063/3157K
3065/3157K
3069/3157K
3073/3157K
3077/3157K
3078/3157K
3082/3157K
3086/3157K
3090/3157K
3094/3157K
3098/3157K
3102/3157K
3106/3157K
3110/3157K
3112/3157K
3116/3157K
3120/3157K
3124/3157K
3128/3157K
3132/3157K
3136/3157K
3140/3157K
3144/3157K
3145/3157K
3149/3157K
3150/3157K
3154/3157K
3157/3157K
3157K downloaded
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) com.esri:jsde_sdk:jar:9.2
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=com.esri -DartifactId=jsde_sdk -Dversion=9.2 -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=com.esri -DartifactId=jsde_sdk -Dversion=9.2 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.extension:arcsde:jar:1.7.1-SNAPSHOT
    2) com.esri:jsde_sdk:jar:9.2
2) com.esri:jsde_jpe_sdk:jar:9.2
      mvn install:install-file -DgroupId=com.esri -DartifactId=jsde_jpe_sdk -Dversion=9.2 -Dpackaging=jar -Dfile=/path/to/file
      mvn deploy:deploy-file -DgroupId=com.esri -DartifactId=jsde_jpe_sdk -Dversion=9.2 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
2 required artifacts are missing.
for artifact:
from the specified remote repositories:
  maven-restlet (http://maven.restlet.org),
  central (http://repo1.maven.org/maven2),
  refractions (http://lists.refractions.net/m2/),
  geotools (http://maven.geotools.fr/repository/),
  mortbay (http://www.mortbay.org/maven2/release)
[INFO] Total time: 9 minutes 34 seconds
[INFO] Finished at: Fri Dec 12 00:49:14 EST 2008
[INFO] Final Memory: 39M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/447/changes
[...truncated 3485 lines...]
  at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.loadFeatureCollection(KMLUtils.java:492)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:169)
  ... 51 more
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.223 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.185 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.206 sec
Results :
Tests run: 127, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.1-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.1-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.1-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.1-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.1-SNAPSHOT/wms-1.7.1-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.1-SNAPSHOT/wms-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.1-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.1-SNAPSHOT/wms-1.7.1-SNAPSHOT-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.opengeo:geowebcache:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.opengeo:geowebcache:1.0-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.1-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.1-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.1-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.1-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/1.7.1-SNAPSHOT/gwc-1.7.1-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/1.7.1-SNAPSHOT/gwc-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.1-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/1.7.1-SNAPSHOT/gwc-1.7.1-SNAPSHOT-sources.jar
[INFO] Building Web Application Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/webapp/data
[INFO] snapshot org.geotools:gt-postgis:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 108 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/classes
[INFO] Compiling 6 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/surefire-reports
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.972 sec
Running org.vfny.geoserver.jetty.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.029 sec
Running org.vfny.geoserver.jetty.SpringContextTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.398 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.327 sec
Results :
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT-sources.jar
[INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/minimal
     [copy] Copying 14 files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/webapp/data
     [copy] Copied 12 empty directories to 9 empty directories under http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/webapp/data
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.1-SNAPSHOT/web-1.7.1-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.1-SNAPSHOT/web-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.1-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.1-SNAPSHOT/web-1.7.1-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web] in [http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/geoserver\]
[INFO] Processing war project
[INFO] Webapp assembled in[865 msecs]
[INFO] Building war: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/geoserver.war
[INFO] Building Community Space
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/target/community-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/pom.xml to /home/tomcat/.m2/repository/org/geoserver/community/1.7.1-SNAPSHOT/community-1.7.1-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/target/community-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/community/1.7.1-SNAPSHOT/community-1.7.1-SNAPSHOT-tests.jar
[INFO] Building GeoServer Extensions
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/target/extension-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/pom.xml to /home/tomcat/.m2/repository/org/geoserver/extension/1.7.1-SNAPSHOT/extension-1.7.1-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/target/extension-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/1.7.1-SNAPSHOT/extension-1.7.1-SNAPSHOT-tests.jar
[INFO] Building ArcSDE DataStore Extension
[INFO] snapshot org.geotools:gt-arcsde:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:arcsde-plugin:2.5-SNAPSHOT: checking for updates from refractions
Downloading: http://maven.geotools.fr/repository//com.esri/poms/jsde_sdk-9.2.pom
Downloading: http://lists.refractions.net/m2//com/esri/jsde_sdk/9.2/jsde_sdk-9.2.pom
Downloading: http://www.mortbay.org/maven2/release/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.pom
Downloading: http://maven.restlet.org/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.pom
Downloading: http://repo1.maven.org/maven2/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.pom
Downloading: http://maven.geotools.fr/repository//com.esri/poms/jsde_jpe_sdk-9.2.pom
Downloading: http://lists.refractions.net/m2//com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.pom
Downloading: http://www.mortbay.org/maven2/release/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.pom
Downloading: http://maven.restlet.org/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.pom
Downloading: http://repo1.maven.org/maven2/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.pom
Downloading: http://maven.geotools.fr/repository//com.esri/jars/jsde_sdk-9.2.jar
Downloading: http://lists.refractions.net/m2//com/esri/jsde_sdk/9.2/jsde_sdk-9.2.jar
Downloading: http://www.mortbay.org/maven2/release/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.jar
Downloading: http://maven.restlet.org/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.jar
Downloading: http://repo1.maven.org/maven2/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.jar
Downloading: http://maven.geotools.fr/repository//com.esri/jars/jsde_jpe_sdk-9.2.jar
Downloading: http://lists.refractions.net/m2//com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.jar
Downloading: http://www.mortbay.org/maven2/release/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.jar
Downloading: http://maven.restlet.org/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.jar
Downloading: http://repo1.maven.org/maven2/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.jar
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
  Path to dependency:
for artifact:
[INFO] Total time: 3 minutes 21 seconds
[INFO] Finished at: Fri Dec 12 01:26:24 EST 2008
[INFO] Final Memory: 40M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/448/changes
Changes:
[jdeolive] disabling arcsde
[...truncated 3503 lines...]
[INFO] [jar:jar]
clean:
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.075 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.399 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.331 sec
Results :
[INFO] [jar:jar]
config:
[INFO] Webapp assembled in[709 msecs]
[INFO] Building H2 DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target
[INFO] snapshot org.geotools:gt-jdbc-h2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-jdbc-core:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/surefire-reports
T E S T S
Running org.geoserver.h2.H2DataStoreInitializerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.959 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/1.7.1-SNAPSHOT/h2-1.7.1-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/1.7.1-SNAPSHOT/h2-1.7.1-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.1-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/1.7.1-SNAPSHOT/h2-1.7.1-SNAPSHOT-sources.jar
[INFO] Building SQL Server DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target
[INFO] snapshot org.geotools:gt-jdbc-sqlserver:2.5-SNAPSHOT: checking for updates from refractions
Downloading: http://maven.geotools.fr/repository//com.microsoft/poms/sqljdbc-1.2.pom
Downloading: http://lists.refractions.net/m2//com/microsoft/sqljdbc/1.2/sqljdbc-1.2.pom
Downloading: http://www.mortbay.org/maven2/release/com/microsoft/sqljdbc/1.2/sqljdbc-1.2.pom
Downloading: http://maven.restlet.org/com/microsoft/sqljdbc/1.2/sqljdbc-1.2.pom
Downloading: http://repo1.maven.org/maven2/com/microsoft/sqljdbc/1.2/sqljdbc-1.2.pom
Downloading: http://maven.geotools.fr/repository//com.microsoft/jars/sqljdbc-1.2.jar
Downloading: http://lists.refractions.net/m2//com/microsoft/sqljdbc/1.2/sqljdbc-1.2.jar
Downloading: http://www.mortbay.org/maven2/release/com/microsoft/sqljdbc/1.2/sqljdbc-1.2.jar
Downloading: http://maven.restlet.org/com/microsoft/sqljdbc/1.2/sqljdbc-1.2.jar
Downloading: http://repo1.maven.org/maven2/com/microsoft/sqljdbc/1.2/sqljdbc-1.2.jar
[ERROR] BUILD ERROR
Missing:
1) com.microsoft:sqljdbc:jar:1.2
      mvn install:install-file -DgroupId=com.microsoft -DartifactId=sqljdbc -Dversion=1.2 -Dpackaging=jar -Dfile=/path/to/file
      mvn deploy:deploy-file -DgroupId=com.microsoft -DartifactId=sqljdbc -Dversion=1.2 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.extension:sqlserver:jar:1.7.1-SNAPSHOT
    2) com.microsoft:sqljdbc:jar:1.2
1 required artifact is missing.
for artifact:
[INFO] Total time: 3 minutes 15 seconds
[INFO] Finished at: Fri Dec 12 01:32:58 EST 2008
[INFO] Final Memory: 41M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/449/changes
