[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #540
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/540/changes
Changes:
[jdeolive] GEOS-1189, hooked up featureBounding configuration parameter to GML3 encoding
[...truncated 3065 lines...]
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
<gml:Point srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:pos>500050.0 500050.0</gml:pos>
</gml:Point>
</cdf:pointProperty>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.10">
<cdf:boundedBy>
<gml:Polygon srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:exterior>
<gml:LinearRing>
<gml:posList>500000.0 500000.0 500000.0 500100.0 500100.0 500100.0 500100.0 500000.0 500000.0 500000.0</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.11">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.12">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.13">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.14">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
</gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.21 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.359 sec
Running org.geoserver.wfs.v1_1.WFSXmlTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.257 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.797 sec
Running org.geoserver.wfs.v1_1.GMLOutputFormatTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.595 sec
Running org.geoserver.wfs.v1_1.GeometrylessTest
<wfs:GetFeature service="WFS" xmlns:wfs="http://www.opengis.net/wfs&quot; version="1.1.0" outputFormat="GML2" xmlns:topp="http://www.openplans.org/topp&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd&quot;&gt;&lt;wfs:Query typeName="cite:Geometryless" srsName="EPSG:900913"/></wfs:GetFeature>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.365 sec
Running org.geoserver.wfs.v1_1.TransactionTest
15 Jan 22:36:02 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: No such property: {http://www.opengis.net/wfs\}INVALID
  at org.geoserver.wfs.UpdateElementHandler.checkValidity(UpdateElementHandler.java:110)
  at org.geoserver.wfs.Transaction.execute(Transaction.java:229)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:108)
  at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:182)
  at sun.reflect.GeneratedMethodAccessor153.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy11.transaction(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor152.invoke(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:582)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:211)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:957)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:924)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:570)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:545)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:722)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:705)
  at org.geoserver.wfs.v1_1.TransactionTest.testUpdateWithInvalidProperty(TransactionTest.java:544)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:125)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.179 sec
Running org.geoserver.wfs.v1_1.GetFeatureTest
15 Jan 22:36:03 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Feature type sf:new unknown
  at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.read(GetFeatureKvpRequestReader.java:101)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1068)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:428)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:208)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:443)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:424)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:656)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:637)
  at org.geoserver.wfs.v1_1.GetFeatureTest.testAfterFeatureTypeAdded(GetFeatureTest.java:339)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
Tests run: 17, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 1.033 sec <<< FAILURE!
Results :
Failed tests:
  testWfs11(org.geoserver.wfs.v1_1.SrsNameTest)
  testPostWithBoundsEnabled(org.geoserver.wfs.v1_1.GetFeatureTest)
Tests in error:
  testGetFeatureWithProjectedBoxGet(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testGetFeatureWithProjectedBoxPost(org.geoserver.wfs.v1_1.WFSReprojectionTest)
Tests run: 70, Failures: 2, Errors: 2, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 34 seconds
[INFO] Finished at: Thu Jan 15 22:36:03 EST 2009
[INFO] Final Memory: 35M/63M
