[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #56
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/56/changes
[...truncated 2261 lines...]
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy11.transaction(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor150.invoke(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:528)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:194)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:925)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:892)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:567)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:542)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:701)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:684)
  at org.geoserver.wfs.v1_1.TransactionTest.testUpdateWithInvalidProperty(TransactionTest.java:544)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:124)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.744 sec
Running org.geoserver.wfs.v1_1.GetFeatureTest
23 Jul 23:16:03 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Feature type sf:new unknown
  at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.read(GetFeatureKvpRequestReader.java:98)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:997)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:383)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:191)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:440)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:421)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:634)
  at org.geoserver.wfs.v1_1.GetFeatureTest.testAfterFeatureTypeAdded(GetFeatureTest.java:339)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.921 sec
Results :
Tests run: 67, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.0-SNAPSHOT/wfs11-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.0-SNAPSHOT/wfs11-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs11/target/wfs11-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfs11/1.7.0-SNAPSHOT/wfs11-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis-versioned:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis:2.5-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 47 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 5 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/surefire-reports
T E S T S
Running org.geoserver.wfsv.HistoryRelatedTest
23 Jul 23:16:18 ERROR [geoserver.wfs] - Transaction failed
org.geoserver.wfs.WFSTransactionException: Error performing insert
  at org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:202)
  at org.geoserver.wfs.Transaction.execute(Transaction.java:333)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:108)
  at org.geoserver.wfsv.DefaultVersioningWebFeatureService.transaction(DefaultVersioningWebFeatureService.java:181)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.geoserver.wfsv.HistoryRelatedTest.oneTimeSetUp(HistoryRelatedTest.java:54)
  at org.geoserver.test.OneTimeSetupTest$OneTimeTestSetup.setUp(OneTimeSetupTest.java:51)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:20)
Caused by: java.lang.IllegalStateException: You can only assign a real id once during a commit
  at org.geotools.filter.identity.FeatureIdImpl.setID(FeatureIdImpl.java:57)
  at org.geotools.data.jdbc.MutableFIDFeature.setID(MutableFIDFeature.java:50)
  at org.geotools.data.postgis.VersionedFeatureWriter.write(VersionedFeatureWriter.java:329)
  at org.geotools.data.AbstractFeatureStore.addFeatures(AbstractFeatureStore.java:268)
  at org.vfny.geoserver.global.GeoServerFeatureStore.addFeatures(GeoServerFeatureStore.java:79)
  at org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:171)
  ... 54 more
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 9.219 sec <<< FAILURE!
Running org.geoserver.wfsv.LogOrderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.48 sec <<< FAILURE!
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.303 sec <<< FAILURE!
Running org.geoserver.wfsv.RollbackTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.05 sec <<< FAILURE!
Results :
Failed tests:
Tests in error:
  testRollbackWfs11(org.geoserver.wfsv.RollbackTest)
  testRollbackWfs10(org.geoserver.wfsv.RollbackTest)
Tests run: 5, Failures: 1, Errors: 4, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfsv/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 52 seconds
[INFO] Finished at: Wed Jul 23 23:16:19 EDT 2008
[INFO] Final Memory: 34M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/57/changes
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.348 sec
23 Jul 23:43:31 ERROR [geoserver.ows] -
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.844 sec
Results :
[INFO] [jar:jar]
T E S T S
23 Jul 23:43:42 ERROR [geoserver.wfs] - Transaction failed
  ... 54 more
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 6.289 sec <<< FAILURE!
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.44 sec <<< FAILURE!
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.402 sec <<< FAILURE!
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.039 sec <<< FAILURE!
Results :
Failed tests:
Tests in error:
[INFO] Total time: 2 minutes 24 seconds
[INFO] Finished at: Wed Jul 23 23:43:44 EDT 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/58/changes
Changes:
[dwinslow] Update to build and pass tests for String->FeatureId change in GeoAPI
[lreed] WPS exclude untransmutable processes.
[...truncated 2297 lines...]
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.459 sec
24 Jul 02:42:12 ERROR [geoserver.ows] -
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.821 sec
Results :
[INFO] [jar:jar]
T E S T S
24 Jul 02:42:28 ERROR [geoserver.wfs] - Transaction failed
  at org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:203)
  at org.geotools.data.AbstractFeatureStore.addFeatures(AbstractFeatureStore.java:271)
  at org.vfny.geoserver.global.GeoServerFeatureStore.addFeatures(GeoServerFeatureStore.java:81)
  at org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:172)
  ... 54 more
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 8.604 sec <<< FAILURE!
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.573 sec <<< FAILURE!
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.242 sec <<< FAILURE!
Results :
Failed tests:
Tests in error:
[INFO] Total time: 2 minutes 55 seconds
[INFO] Finished at: Thu Jul 24 02:42:29 EDT 2008
Failed to send e-mail to lreed because no e-mail address is known, and no default e-mail domain is configured
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/59/changes
Changes:
[dwinslow] Oops, sorry lreed. Updates to work against latest gt2.
[...truncated 2275 lines...]
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.299 sec
25 Jul 02:48:47 ERROR [geoserver.ows] -
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.819 sec
Results :
[INFO] [jar:jar]
T E S T S
25 Jul 02:49:32 ERROR [geoserver.wfs] - Transaction failed
  at org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:200)
  at org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:169)
  ... 54 more
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 6.574 sec <<< FAILURE!
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.484 sec <<< FAILURE!
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.265 sec <<< FAILURE!
Results :
Failed tests:
Tests in error:
[INFO] Total time: 6 minutes 27 seconds
[INFO] Finished at: Fri Jul 25 02:49:33 EDT 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-1.7.x/60/changes
