[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #584
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/584/changes
Changes:
[jdeolive] added dependencyManagement entry for jettison
[...truncated 4026 lines...]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.3-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.3-SNAPSHOT/wms-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.3-SNAPSHOT/wms-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.3-SNAPSHOT/wms-1.7.3-SNAPSHOT-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
Downloading: http://repo.opengeo.org//org/codehaus/jettison/jettison/1.0.1/jettison-1.0.1.pom
Downloading: http://maven.geotools.fr/repository//org.codehaus.jettison/poms/jettison-1.0.1.pom
Downloading: http://lists.refractions.net/m2//org/codehaus/jettison/jettison/1.0.1/jettison-1.0.1.pom
Downloading: http://www.mortbay.org/maven2/release/org/codehaus/jettison/jettison/1.0.1/jettison-1.0.1.pom
Downloading: http://maven.restlet.org/org/codehaus/jettison/jettison/1.0.1/jettison-1.0.1.pom
Downloading: http://repo1.maven.org/maven2/org/codehaus/jettison/jettison/1.0.1/jettison-1.0.1.pom
2/2K
2K downloaded
Downloading: http://repo.opengeo.org//org/codehaus/jettison/jettison/1.0.1/jettison-1.0.1.jar
Downloading: http://maven.geotools.fr/repository//org.codehaus.jettison/jars/jettison-1.0.1.jar
Downloading: http://lists.refractions.net/m2//org/codehaus/jettison/jettison/1.0.1/jettison-1.0.1.jar
Downloading: http://www.mortbay.org/maven2/release/org/codehaus/jettison/jettison/1.0.1/jettison-1.0.1.jar
Downloading: http://maven.restlet.org/org/codehaus/jettison/jettison/1.0.1/jettison-1.0.1.jar
Downloading: http://repo1.maven.org/maven2/org/codehaus/jettison/jettison/1.0.1/jettison-1.0.1.jar
1/55K
4/55K
8/55K
12/55K
12/55K
16/55K
20/55K
24/55K
28/55K
29/55K
33/55K
37/55K
41/55K
45/55K
47/55K
51/55K
55/55K
55K downloaded
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.3-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.3-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/1.7.3-SNAPSHOT/gwc-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/1.7.3-SNAPSHOT/gwc-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/1.7.3-SNAPSHOT/gwc-1.7.3-SNAPSHOT-sources.jar
[INFO] Building Web Application Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/webapp/data
[INFO] snapshot org.geotools:gt-postgis:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 108 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/classes
[INFO] Compiling 6 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/surefire-reports
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.935 sec
Running org.vfny.geoserver.jetty.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.054 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.043 sec
Running org.vfny.geoserver.jetty.SpringContextTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.735 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.398 sec
Results :
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.3-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.3-SNAPSHOT-sources.jar
[INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/minimal
     [copy] Copying 14 files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/webapp/data
     [copy] Copied 12 empty directories to 9 empty directories under http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/webapp/data
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.3-SNAPSHOT/web-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.3-SNAPSHOT/web-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/web-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.3-SNAPSHOT/web-1.7.3-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web] in [http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/geoserver\]
[INFO] Processing war project
[INFO] Webapp assembled in[1404 msecs]
[INFO] Building war: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/geoserver.war
[INFO] Building Community Space
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/target/community-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/pom.xml to /home/tomcat/.m2/repository/org/geoserver/community/1.7.3-SNAPSHOT/community-1.7.3-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/community/target/community-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/community/1.7.3-SNAPSHOT/community-1.7.3-SNAPSHOT-tests.jar
[INFO] Building GeoServer Extensions
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/target/extension-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/pom.xml to /home/tomcat/.m2/repository/org/geoserver/extension/1.7.3-SNAPSHOT/extension-1.7.3-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/target/extension-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/1.7.3-SNAPSHOT/extension-1.7.3-SNAPSHOT-tests.jar
[INFO] Building ArcSDE DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/arcsde/target
[INFO] snapshot org.geotools:gt-arcsde:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:arcsde-plugin:2.5-SNAPSHOT: checking for updates from refractions
Downloading: http://maven.geotools.fr/repository//com.esri/poms/jsde_sdk-9.2.pom
Downloading: http://lists.refractions.net/m2//com/esri/jsde_sdk/9.2/jsde_sdk-9.2.pom
Downloading: http://www.mortbay.org/maven2/release/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.pom
Downloading: http://maven.restlet.org/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.pom
Downloading: http://repo1.maven.org/maven2/com/esri/jsde_sdk/9.2/jsde_sdk-9.2.pom
Downloading: http://maven.geotools.fr/repository//com.esri/poms/jsde_jpe_sdk-9.2.pom
Downloading: http://lists.refractions.net/m2//com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.pom
Downloading: http://www.mortbay.org/maven2/release/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.pom
Downloading: http://maven.restlet.org/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.pom
Downloading: http://repo1.maven.org/maven2/com/esri/jsde_jpe_sdk/9.2/jsde_jpe_sdk-9.2.pom
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/arcsde/target/arcsde-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/arcsde/target/arcsde-1.7.3-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/arcsde/target/arcsde-1.7.3-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/arcsde/target/arcsde-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/1.7.3-SNAPSHOT/arcsde-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/arcsde/target/arcsde-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/1.7.3-SNAPSHOT/arcsde-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/arcsde/target/arcsde-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/1.7.3-SNAPSHOT/arcsde-1.7.3-SNAPSHOT-sources.jar
[INFO] Building H2 DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target
[INFO] snapshot org.geotools:gt-jdbc-h2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-jdbc-core:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/test-classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
error: error reading /home/tomcat/.m2/repository/org/geotools/ogc/org.w3.xlink/2.5-SNAPSHOT/org.w3.xlink-2.5-SNAPSHOT.jar; error in opening zip file
[INFO] Total time: 4 minutes 7 seconds
[INFO] Finished at: Sat Jan 24 02:43:37 EST 2009
[INFO] Final Memory: 39M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/585/changes
