[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #629
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/629/changes
Changes:
[jdeolive] added a builder for catalog objects
[jdeolive] improvements to the xstream persistance
[jdeolive] Added methods for coverage lookups, cleaner implementation of resolve(), sync up with trunk
[jdeolive] added setter for catalog
[...truncated 572 lines...]
  at org.vfny.geoserver.global.Data.toDTO(Data.java:1604)
  at org.vfny.geoserver.global.Config.getData(Config.java:107)
  at org.geoserver.vfny.global.TolerantStartupTest.testContextStartup(TolerantStartupTest.java:43)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:123456" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:949)
  at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:314)
  at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:388)
  at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:781)
  at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:798)
  at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:638)
  at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:729)
  at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
  at org.geotools.referencing.CRS.decode(CRS.java:420)
  at org.geotools.referencing.CRS.decode(CRS.java:348)
  at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:995)
  ... 31 more
04 Feb 09:41:04 ERROR [geoserver.global] - Could not load feature type cite:BasicPolygons
java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:123456" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:999)
  at org.vfny.geoserver.global.FeatureTypeInfo.toDTO(FeatureTypeInfo.java:523)
  at org.geoserver.vfny.global.TolerantStartupTest.testContextStartup(TolerantStartupTest.java:44)
  ... 31 more
04 Feb 09:41:04 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Wed Feb 04 09:41:04 EST 2009]; root of context hierarchy
04 Feb 09:41:04 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
04 Feb 09:41:04 INFO [geoserver.global] - Done disposing datastores.
Feb 4, 2009 9:41:04 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.127 sec
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
04 Feb 09:41:04 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
04 Feb 09:41:04 INFO [geoserver.catalog] - Default namespace: 'gs'
04 Feb 09:41:04 INFO [geoserver.catalog] - Loaded style 'Default'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.config.LegacyConfigurationImporterTest
Feb 4, 2009 9:41:04 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.075 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.202 sec
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Feb 4, 2009 9:41:04 AM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Rule *.*.r=* is overriding another rule targetting the same resource
WARNING: Rule *.*.w=* is overriding another rule targetting the same resource
WARNING: Rule *.*.r=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.w=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.r=READER is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.bases.w=MILITARY
WARNING: Layer topp is unknown in rule + topp.states.w=WRITER
WARNING: Layer topp is unknown in rule + topp.bases.r=MILITARY
WARNING: Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.landmarks.w=WRITER
WARNING: Layer topp is unknown in rule + topp.states.r=READER
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
INFO: Disposing datastore 'cgf'
INFO: Disposing datastore 'sf'
INFO: Disposing datastore 'cdf'
Feb 4, 2009 9:41:05 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.736 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 39, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.031 sec <<< FAILURE!
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
Feb 4, 2009 9:41:05 AM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.191 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.config.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Results :
Failed tests:
  testModifyWorkspace(org.geoserver.catalog.impl.CatalogImplTest)
Tests run: 98, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/surefire-reports for the individual test results.
[INFO] Total time: 48 seconds
[INFO] Finished at: Wed Feb 04 09:41:05 EST 2009
[INFO] Final Memory: 34M/62M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/630/changes
