See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/646/changes
Changes:
[aaime] Fixing wfs 1.1 path, made testing stronger
[...truncated 2063 lines...]
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
09 Feb 19:41:27 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Unknown namespace [youdontknowme]
at org.geoserver.wfs.kvp.QNameKvpParser.parseToken(QNameKvpParser.java:54)
at org.geoserver.ows.FlatKvpParser.parse(FlatKvpParser.java:76)
at org.geoserver.ows.util.KvpUtils.parse(KvpUtils.java:471)
at org.geoserver.ows.Dispatcher.parseKVP(Dispatcher.java:1049)
at org.geoserver.ows.Dispatcher.init(Dispatcher.java:245)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:191)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1012)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:979)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:449)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:430)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:704)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:666)
at org.geoserver.wfs.GetFeatureTest.testAlienNamespace(GetFeatureTest.java:51)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.354 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.145 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
Feature type cite:InvalidTypeName unknown
Feature type gs:InvalidTypeName unknown
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.319 sec
Running org.geoserver.wfs.LockFeatureTest
09 Feb 19:41:28 ERROR [geoserver.wfs] - Transaction failed
org.geoserver.wfs.WFSTransactionException: Transaction does not have authorization for Locks:Locks.0
at org.geoserver.wfs.DeleteElementHandler.execute(DeleteElementHandler.java:188)
at org.geoserver.wfs.Transaction.execute(Transaction.java:333)
at org.geoserver.wfs.Transaction.transaction(Transaction.java:108)
at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:182)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy11.transaction(Unknown Source)
at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:582)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:211)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:634)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:581)
at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:561)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:770)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:753)
at org.geoserver.wfs.LockFeatureTest.testDeleteWithoutLockId(LockFeatureTest.java:105)
at sun.reflect.GeneratedMethodAccessor177.invoke(Unknown Source)
Caused by: org.geotools.data.FeatureLockException: Transaction does not have authorization for Locks:Locks.0
at org.geotools.data.InProcessLockingManager.assertAccess(InProcessLockingManager.java:285)
at org.geotools.data.InProcessLockingManager$1.remove(InProcessLockingManager.java:323)
at org.geotools.data.FilteringFeatureWriter.remove(FilteringFeatureWriter.java:88)
at org.geotools.data.AbstractFeatureStore.removeFeatures(AbstractFeatureStore.java:315)
at org.vfny.geoserver.global.GeoServerFeatureStore.removeFeatures(GeoServerFeatureStore.java:94)
at org.geoserver.wfs.DeleteElementHandler.execute(DeleteElementHandler.java:176)
... 63 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.321 sec
Running org.geoserver.wfs.response.ShapeZipTest
Feb 9, 2009 7:41:29 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.749 sec
Running org.geoserver.wfs.GetFeatureWithLockTest
09 Feb 19:41:30 ERROR [geoserver.wfs] - Transaction failed
org.geoserver.wfs.WFSTransactionException: update error
at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:239)
at sun.reflect.GeneratedMethodAccessor181.invoke(Unknown Source)
at sun.reflect.GeneratedMethodAccessor180.invoke(Unknown Source)
at org.geoserver.wfs.GetFeatureWithLockTest.testUpdateLockedFeatureWithoutLockId(GetFeatureWithLockTest.java:128)
at org.geotools.data.InProcessLockingManager$1.write(InProcessLockingManager.java:332)
at org.geotools.data.FilteringFeatureWriter.write(FilteringFeatureWriter.java:106)
at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:160)
at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:102)
at org.vfny.geoserver.global.GeoServerFeatureStore.modifyFeatures(GeoServerFeatureStore.java:129)
at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:229)
... 65 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.754 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 4, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.321 sec <<< FAILURE!
Running org.geoserver.wfs.kvp.FilterKvpParserTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Results :
Failed tests:
testGet(org.geoserver.wfs.GetCapabilitiesTest)
Tests run: 78, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wfs/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 57 seconds
[INFO] Finished at: Mon Feb 09 19:41:31 EST 2009
[INFO] Final Memory: 36M/63M
