See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/668/changes
Changes:
[jdeolive] added osgeo repository to pom
[...truncated 2289 lines...]
WARNING: Rule *.*.w=WRITER is overriding another rule targetting the same resource
Feb 15, 2009 7:41:51 PM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Rule *.*.r=READER is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.bases.w=MILITARY
WARNING: Layer topp is unknown in rule + topp.states.w=WRITER
WARNING: Layer topp is unknown in rule + topp.bases.r=MILITARY
WARNING: Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.landmarks.w=WRITER
WARNING: Layer topp is unknown in rule + topp.states.r=READER
WARNING: Rule *.*.r=WRITER is overriding another rule targetting the same resource
WARNING: Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.741 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 39, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.197 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.config.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Results :
Tests run: 98, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.3-SNAPSHOT/main-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.3-SNAPSHOT/main-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.3-SNAPSHOT/main-1.7.3-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-arcgrid:2.5-SNAPSHOT: checking for updates from osgeo
5225/3K
3K downloaded
[INFO] snapshot org.geotools:gt-geotiff:2.5-SNAPSHOT: checking for updates from osgeo
5226/4K
5229/4K
5230/4K
4K downloaded
[INFO] snapshot org.geotools:gt-gtopo30:2.5-SNAPSHOT: checking for updates from osgeo
5234/4K
5234/4K
4K downloaded
[INFO] snapshot org.geotools:gt-image:2.5-SNAPSHOT: checking for updates from osgeo
5238/3K
3K downloaded
[INFO] snapshot org.geotools:gt-imagemosaic:2.5-SNAPSHOT: checking for updates from osgeo
5239/4K
5243/4K
4K downloaded
[INFO] snapshot org.geotools:gt-shapefile:2.5-SNAPSHOT: checking for updates from osgeo
5247/5K
5248/5K
5K downloaded
5252/21K
5256/21K
5260/21K
5261/21K
5265/21K
5269/21K
5270/21K
21K downloaded
5274/21K
5278/21K
5282/21K
5282/21K
5286/21K
5290/21K
5292/21K
21K downloaded
5296/35K
5300/35K
5304/35K
5304/35K
5308/35K
5312/35K
5314/35K
5316/35K
5320/35K
5324/35K
5327/35K
35K downloaded
5331/19K
5335/19K
5339/19K
5340/19K
5344/19K
5347/19K
19K downloaded
5351/24K
5355/24K
5358/24K
5359/24K
5363/24K
5367/24K
5371/24K
5372/24K
24K downloaded
5374/231K
5376/231K
5377/231K
5381/231K
5383/231K
5384/231K
5388/231K
5392/231K
5394/231K
5398/231K
5402/231K
5406/231K
5410/231K
5414/231K
5415/231K
5419/231K
5422/231K
5426/231K
5430/231K
5434/231K
5438/231K
5442/231K
5446/231K
5450/231K
5454/231K
5458/231K
5462/231K
5466/231K
5468/231K
5472/231K
5476/231K
5480/231K
5484/231K
5488/231K
5492/231K
5496/231K
5500/231K
5504/231K
5508/231K
5510/231K
5514/231K
5518/231K
5522/231K
5526/231K
5530/231K
5534/231K
5538/231K
5538/231K
5542/231K
5546/231K
5550/231K
5554/231K
5557/231K
5558/231K
5562/231K
5566/231K
5570/231K
5574/231K
5578/231K
5582/231K
5586/231K
5590/231K
5594/231K
5598/231K
5602/231K
5604/231K
231K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 36 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
org.geotools.xsd:gt-xsd-gml2:jar:2.5-SNAPSHOT
from the specified remote repositories:
maven-restlet (http://maven.restlet.org),
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools),
refractions (http://lists.refractions.net/m2/),
geotools (http://maven.geotools.fr/repository/),
mortbay (http://www.mortbay.org/maven2/release)
Path to dependency:
1) org.geoserver:wcs:jar:1.7.3-SNAPSHOT
2) org.geoserver:main:jar:1.7.3-SNAPSHOT
3) org.geoserver:data:jar:1.7.3-SNAPSHOT
4) org.geotools.xsd:gt-xsd-gml2:jar:2.5-SNAPSHOT
Caused by I/O exception: Server returned HTTP response code: 503 for URL: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-gml2/2.5-SNAPSHOT/gt-xsd-gml2-2.5-SNAPSHOT.jar
[INFO] Total time: 2 minutes 37 seconds
[INFO] Finished at: Sun Feb 15 19:42:20 EST 2009
[INFO] Final Memory: 28M/63M
