[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #715
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/715/changes
Changes:
[arneke] GEOS-2644 Adding filter that removes empty attributes from feature info template
[...truncated 619 lines...]
java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:123456" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:1013)
  at org.vfny.geoserver.global.FeatureTypeInfo.toDTO(FeatureTypeInfo.java:523)
  at org.vfny.geoserver.global.Data.toDTO(Data.java:1604)
  at org.vfny.geoserver.global.Config.getData(Config.java:107)
  at org.geoserver.vfny.global.TolerantStartupTest.testContextStartup(TolerantStartupTest.java:44)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:123456" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:949)
  at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:314)
  at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:388)
  at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:781)
  at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:798)
  at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:638)
  at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:729)
  at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
  at org.geotools.referencing.CRS.decode(CRS.java:420)
  at org.geotools.referencing.CRS.decode(CRS.java:348)
  at org.vfny.geoserver.global.FeatureTypeInfo.getSRS(FeatureTypeInfo.java:1009)
  ... 31 more
25 Feb 13:40:55 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Wed Feb 25 13:40:55 EST 2009]; root of context hierarchy
25 Feb 13:40:55 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
25 Feb 13:40:55 INFO [geoserver.global] - Done disposing datastores.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.108 sec
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
25 Feb 13:40:55 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
25 Feb 13:40:55 INFO [geoserver.catalog] - Default namespace: 'gs'
25 Feb 13:40:55 INFO [geoserver.catalog] - Loaded style 'Default'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.config.LegacyConfigurationImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.075 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.208 sec
Running org.geoserver.security.SecureTreeNodeTest
Feb 25, 2009 1:40:55 PM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Rule *.*.r=* is overriding another rule targetting the same resource
WARNING: Rule *.*.w=* is overriding another rule targetting the same resource
WARNING: Rule *.*.r=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.w=WRITER is overriding another rule targetting the same resource
WARNING: Rule *.*.r=READER is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.bases.w=MILITARY
WARNING: Layer topp is unknown in rule + topp.states.w=WRITER
WARNING: Layer topp is unknown in rule + topp.bases.r=MILITARY
WARNING: Rule *.*.w=NO_ONE is overriding another rule targetting the same resource
WARNING: Layer topp is unknown in rule + topp.landmarks.w=WRITER
WARNING: Layer topp is unknown in rule + topp.states.r=READER
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
Feb 25, 2009 1:40:55 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'cite'
INFO: Disposing datastore 'cgf'
INFO: Disposing datastore 'cdf'
INFO: Disposing datastore 'sf'
Feb 25, 2009 1:40:56 PM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.999 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Feb 25, 2009 1:40:56 PM org.geoserver.security.DefaultDataAccessManager buildAuthorizationTree
WARNING: Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 39, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.363 sec
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.172 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.054 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.config.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Results :
Tests run: 98, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.3-SNAPSHOT/main-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.3-SNAPSHOT/main-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/main-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.3-SNAPSHOT/main-1.7.3-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools:gt-arcgrid:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] Compiling 36 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wcs/target/classes
[INFO] [resources:testResources]
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
  org.geotools.ogc:net.opengis.ows:jar:2.5-SNAPSHOT
from the specified remote repositories:
  maven-restlet (http://maven.restlet.org),
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools),
  refractions (http://lists.refractions.net/m2/),
  geotools (http://maven.geotools.fr/repository/),
  mortbay (http://www.mortbay.org/maven2/release)
Path to dependency:
  1) org.geoserver:wcs:jar:1.7.3-SNAPSHOT
  2) org.geoserver:main:jar:1.7.3-SNAPSHOT
  3) org.geoserver:ows:jar:1.7.3-SNAPSHOT
  4) org.geotools.ogc:net.opengis.ows:jar:2.5-SNAPSHOT
Caused by I/O exception: Server returned HTTP response code: 503 for URL: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.ows/2.5-SNAPSHOT/net.opengis.ows-2.5-SNAPSHOT.jar
[INFO] Total time: 1 minute 22 seconds
[INFO] Finished at: Wed Feb 25 13:41:09 EST 2009
[INFO] Final Memory: 33M/63M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/716/changes
