See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/724/changes
Changes:
[jdeolive] GEOS-2619, resurrecting schema.xml
[...truncated 155 lines...]
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.3-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.3-SNAPSHOT/config-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.3-SNAPSHOT/config-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.3-SNAPSHOT/config-1.7.3-SNAPSHOT-sources.jar
[INFO] [plugin:updateRegistry]
[INFO] Building GeoServer Maven Archetypes
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/target/archetype-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/1.7.3-SNAPSHOT/archetype-1.7.3-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/target/archetype-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/1.7.3-SNAPSHOT/archetype-1.7.3-SNAPSHOT-tests.jar
[INFO] Building GeoServer WFS Output Format Archetype
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] No sources to compile
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/1.7.3-SNAPSHOT/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/1.7.3-SNAPSHOT/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/1.7.3-SNAPSHOT/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT-sources.jar
[INFO] Building Core Platform Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target
[INFO] Compiling 9 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/surefire-reports
T E S T S
Running org.geoserver.platform.GeoServerExtensionsTest
Feb 28, 2009 12:40:16 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.116 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.3-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.3-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.3-SNAPSHOT/platform-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.3-SNAPSHOT/platform-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.3-SNAPSHOT/platform-1.7.3-SNAPSHOT-sources.jar
[INFO] Building Data Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target
[INFO] snapshot org.geotools:gt-epsg-hsql:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-coverage:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:xsd:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:extension:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-graph:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] Compiling 20 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/classes
[INFO] Compiling 7 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/surefire-reports
T E S T S
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.184 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.05 sec
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.271 sec
Results :
Tests run: 31, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/data-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/data-1.7.3-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/data-1.7.3-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/data-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.3-SNAPSHOT/data-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/data-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.3-SNAPSHOT/data-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/data-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.3-SNAPSHOT/data-1.7.3-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target
[INFO] snapshot org.geotools.ogc:net.opengis.ows:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:ogc:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] Compiling 74 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/classes
[INFO] Compiling 16 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/surefire-reports
T E S T S
Running org.geoserver.ows.util.RequestUtilsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.032 sec
Running org.geoserver.ows.DispatcherTest
log4j:WARN No appenders could be found for logger (org.springframework.context.support.FileSystemXmlApplicationContext).
log4j:WARN Please initialize the log4j system properly.
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.608 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.182 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Results :
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/ows-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/ows-1.7.3-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/ows-1.7.3-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/ows-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.3-SNAPSHOT/ows-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/ows-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.3-SNAPSHOT/ows-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/ows/target/ows-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.3-SNAPSHOT/ows-1.7.3-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target
[INFO] snapshot org.geotools:gt-cql:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt-cql:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt-validation:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:2.5-SNAPSHOT: checking for updates from maven-restlet
[INFO] snapshot org.geotools:gt-data:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] Compiling 239 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/main/src/main/java/org/geoserver/catalog/util/LegacyCatalogImporter.java :[526,70] createSchemaLocator() has protected access in org.geotools.xml.XSD
[INFO] Total time: 37 seconds
[INFO] Finished at: Sat Feb 28 00:40:36 EST 2009
[INFO] Final Memory: 33M/63M
