[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #741
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/741/changes
Changes:
[jdeolive] Added release artifact descriptor for restconfig extension
[jdeolive] changed group id of restconfig
[jdeolive] set svn:ignore
[jdeolive] GEOS-2497, profile for restconfig extension
[jdeolive] GEOS-2497, moved restconfig to extension from community
[...truncated 4792 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Error: Could not find mediaLib accelerator wrapper classes. Continuing in pure Java mode.
Occurs in: com.sun.media.jai.mlib.MediaLibAccessor
java.lang.NoClassDefFoundError: com/sun/medialib/mlib/Image
  at com.sun.media.jai.mlib.MediaLibAccessor$1.run(MediaLibAccessor.java:248)
  at java.security.AccessController.doPrivileged(Native Method)
  at com.sun.media.jai.mlib.MediaLibAccessor.setUseMlib(MediaLibAccessor.java:245)
  at com.sun.media.jai.mlib.MediaLibAccessor.useMlib(MediaLibAccessor.java:177)
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:357)
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:315)
  at com.sun.media.jai.mlib.MlibWarpRIF.create(MlibWarpRIF.java:65)
  at sun.reflect.GeneratedMethodAccessor130.invoke(Unknown Source)
  at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
  at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
  at javax.media.jai.ThreadSafeOperationRegistry.invokeFactory(ThreadSafeOperationRegistry.java:473)
  at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
  at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
  at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
  at javax.media.jai.RenderedOp.getMinX(RenderedOp.java:2161)
  at org.geotools.coverage.processing.operation.Resampler2D.reproject(Resampler2D.java:650)
  at org.geotools.coverage.processing.operation.Resample.doOperation(Resample.java:207)
  at org.vfny.geoserver.util.WCSUtils.scale(WCSUtils.java:225)
  at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:335)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy16.getCoverage(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:582)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:211)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1012)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:979)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:449)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:430)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:704)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:666)
  at org.geoserver.catalog.rest.CoverageTest.testPostAsXML(CoverageTest.java:143)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
./target/mock49152data/temp/wcs/gs_usa_1236296694350816000.outputFormat
05 Mar 18:44:55 ERROR [geoserver.rest] - No such coverage: wcs,BlueMarble,NonExistant
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.051 sec
Running org.geoserver.catalog.rest.CoverageStoreFileUploadTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.872 sec
Running org.geoserver.catalog.rest.CoverageStoreTest
05 Mar 18:45:01 ERROR [geoserver.rest] - No such coverage store: wcs,nonExistant
05 Mar 18:45:02 ERROR [geoserver.rest] - No such coverage store: wcs,nonExistant
05 Mar 18:45:02 ERROR [geoserver.rest] - coveragestore not empty
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.027 sec
Running org.geoserver.catalog.rest.LayerGroupTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.267 sec
Running org.geoserver.catalog.rest.NamespaceTest
05 Mar 18:45:19 ERROR [geoserver.rest] - No such namespace: none
05 Mar 18:45:20 ERROR [geoserver.rest] - No such namespace: newExistant
05 Mar 18:45:21 ERROR [geoserver.rest] - No such namespace: foo
05 Mar 18:45:21 ERROR [geoserver.rest] - No such namespace: nonExistant
05 Mar 18:45:21 ERROR [geoserver.rest] - Namespace not empty
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.531 sec
Running org.geoserver.catalog.rest.FeatureTypeTest
05 Mar 18:45:24 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Feature type sf:pdsa unknown
  at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.read(GetFeatureKvpRequestReader.java:101)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1087)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:428)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:208)
  at org.geoserver.catalog.rest.FeatureTypeTest.testPostAsXML(FeatureTypeTest.java:87)
05 Mar 18:45:25 ERROR [geoserver.ows] -
  at org.geoserver.catalog.rest.FeatureTypeTest.testPostAsJSON(FeatureTypeTest.java:119)
05 Mar 18:45:27 ERROR [geoserver.rest] - No such feature type: sf,sf,NonExistant
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.565 sec
Running org.geoserver.catalog.rest.DataStoreTest
05 Mar 18:45:36 ERROR [geoserver.rest] - No such datastore: sf,nonExistant
05 Mar 18:45:36 ERROR [geoserver.rest] - datastore not empty
05 Mar 18:45:37 ERROR [geoserver.rest] - Can't change name of data store.
05 Mar 18:45:37 ERROR [geoserver.rest] - No such datastore: sf,nonExistant
05 Mar 18:45:38 ERROR [geoserver.rest] - Can't change workspace of data store.
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.112 sec
Running org.geoserver.catalog.rest.LayerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.752 sec
Running org.geoserver.catalog.rest.StyleTest
05 Mar 18:45:51 ERROR [geoserver.rest] - Can't delete style referenced by existing layers.
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.188 sec
Running org.geoserver.catalog.rest.WorkspaceTest
05 Mar 18:45:58 ERROR [geoserver.rest] - No such workspace: none
05 Mar 18:45:59 ERROR [geoserver.rest] - No such workspace: newExistant
05 Mar 18:46:00 ERROR [geoserver.rest] - No such workspace: foo
05 Mar 18:46:00 ERROR [geoserver.rest] - Workspace not empty
05 Mar 18:46:01 ERROR [geoserver.rest] - Can't change the name of a workspace.
05 Mar 18:46:01 ERROR [geoserver.rest] - No such workspace: nonExistant
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.655 sec
Results :
Tests in error:
  testGet(org.geoserver.catalog.rest.DataStoreFileUploadTest)
Tests run: 138, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/restconfig/target/surefire-reports for the individual test results.
[INFO] Total time: 5 minutes 41 seconds
[INFO] Finished at: Thu Mar 05 18:46:02 EST 2009
[INFO] Final Memory: 44M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/742/changes
