[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #762
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/762/changes
Changes:
[jdeolive] GEOS-2752, reading base map styles with trailing commas
[...truncated 1485 lines...]
324/410K
328/410K
332/410K
336/410K
340/410K
344/410K
348/410K
352/410K
356/410K
360/410K
364/410K
368/410K
372/410K
376/410K
380/410K
384/410K
388/410K
392/410K
396/410K
400/410K
404/410K
408/410K
410/410K
410K downloaded
Downloading: http://repo.opengeo.org//org/geotools/gt-property/2.5-SNAPSHOT/gt-property-2.5-20090314.060214-20.jar
4/19K
8/19K
12/19K
16/19K
19/19K
19K downloaded
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml2/2.5-SNAPSHOT/gt-xsd-gml2-2.5-20090314.060214-20.jar
4/61K
8/61K
12/61K
16/61K
20/61K
22/61K
26/61K
30/61K
34/61K
38/61K
42/61K
46/61K
50/61K
54/61K
58/61K
61/61K
61K downloaded
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-core/2.5-SNAPSHOT/gt-xsd-core-2.5-20090314.060214-20.jar
4/257K
8/257K
12/257K
16/257K
20/257K
24/257K
28/257K
32/257K
36/257K
40/257K
44/257K
46/257K
50/257K
54/257K
58/257K
62/257K
66/257K
70/257K
74/257K
78/257K
82/257K
86/257K
90/257K
94/257K
98/257K
99/257K
103/257K
107/257K
111/257K
115/257K
119/257K
123/257K
127/257K
131/257K
135/257K
139/257K
143/257K
147/257K
151/257K
155/257K
159/257K
163/257K
167/257K
171/257K
175/257K
179/257K
183/257K
187/257K
191/257K
195/257K
199/257K
203/257K
207/257K
211/257K
215/257K
219/257K
223/257K
227/257K
231/257K
235/257K
239/257K
243/257K
247/257K
248/257K
252/257K
256/257K
257/257K
257K downloaded
Downloading: http://repo.opengeo.org//org/geotools/gt-graph/2.5-SNAPSHOT/gt-graph-2.5-20090314.060214-20.jar
4/159K
8/159K
8/159K
11/159K
15/159K
19/159K
23/159K
27/159K
31/159K
35/159K
39/159K
43/159K
47/159K
47/159K
49/159K
53/159K
57/159K
61/159K
65/159K
69/159K
73/159K
77/159K
81/159K
85/159K
89/159K
93/159K
97/159K
101/159K
105/159K
109/159K
113/159K
117/159K
121/159K
125/159K
129/159K
133/159K
137/159K
141/159K
145/159K
149/159K
153/159K
157/159K
159/159K
159K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 20 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/classes
[INFO] [resources:testResources]
[INFO] Using default encoding to copy filtered resources.
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc/2.5-SNAPSHOT/gt-jdbc-2.5-20090314.060214-20.jar
3/138K
6/138K
10/138K
14/138K
15/138K
16/138K
19/138K
20/138K
23/138K
25/138K
26/138K
27/138K
29/138K
32/138K
35/138K
39/138K
43/138K
47/138K
47/138K
51/138K
55/138K
59/138K
59/138K
61/138K
62/138K
63/138K
64/138K
66/138K
67/138K
71/138K
72/138K
75/138K
76/138K
78/138K
79/138K
80/138K
81/138K
83/138K
84/138K
86/138K
86/138K
88/138K
91/138K
92/138K
93/138K
94/138K
98/138K
102/138K
106/138K
110/138K
114/138K
118/138K
122/138K
126/138K
130/138K
134/138K
138/138K
138K downloaded
[INFO] [compiler:testCompile]
[INFO] Compiling 7 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target/test-classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/src/test/java/org/geoserver/data/test/MockData.java :[714,49] cannot find symbol
symbol : method getLower(int)
location: interface org.opengis.coverage.grid.GridEnvelope
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/src/test/java/org/geoserver/data/test/MockData.java :[715,49] cannot find symbol
symbol : method getUpper(int)
[INFO] Total time: 25 seconds
[INFO] Finished at: Sat Mar 14 17:40:50 EDT 2009
[INFO] Final Memory: 29M/53M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/763/changes
Changes:
[jdeolive] setting geoapi version to 2.2-M2
[...truncated 200 lines...]
421/454K
425/454K
429/454K
433/454K
437/454K
441/454K
445/454K
449/454K
453/454K
454/454K
454K downloaded
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/target/geoserver-1.7.3-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/pom.xml to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.7.3-SNAPSHOT/geoserver-1.7.3-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/target/geoserver-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.7.3-SNAPSHOT/geoserver-1.7.3-SNAPSHOT-tests.jar
[INFO] Building GeoServer Maven Plugins
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/target/maven-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/1.7.3-SNAPSHOT/maven-1.7.3-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/target/maven-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/1.7.3-SNAPSHOT/maven-1.7.3-SNAPSHOT-tests.jar
[INFO] Building Plugins configuration files
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/build-configs/target
[INFO] [resources:resources]
[INFO] Nothing to compile - all classes are up to date
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/build-configs/target/build-configs-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/build-configs/target/build-configs-1.7.3-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/build-configs/target/build-configs-1.7.3-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/build-configs/target/build-configs-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.3-SNAPSHOT/build-configs-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/build-configs/target/build-configs-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.3-SNAPSHOT/build-configs-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/build-configs/target/build-configs-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.3-SNAPSHOT/build-configs-1.7.3-SNAPSHOT-sources.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.3-SNAPSHOT.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.3-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.3-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.3-SNAPSHOT/config-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.3-SNAPSHOT/config-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/config/target/config-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.3-SNAPSHOT/config-1.7.3-SNAPSHOT-sources.jar
[INFO] [plugin:updateRegistry]
[INFO] Building GeoServer Maven Archetypes
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/target
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/target/archetype-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/1.7.3-SNAPSHOT/archetype-1.7.3-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/target/archetype-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/1.7.3-SNAPSHOT/archetype-1.7.3-SNAPSHOT-tests.jar
[INFO] Building GeoServer WFS Output Format Archetype
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/1.7.3-SNAPSHOT/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/1.7.3-SNAPSHOT/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/1.7.3-SNAPSHOT/geoserver-archetype-wfsoutputformat-1.7.3-SNAPSHOT-sources.jar
[INFO] Building Core Platform Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target
[INFO] Compiling 9 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/surefire-reports
T E S T S
Running org.geoserver.platform.GeoServerExtensionsTest
Mar 14, 2009 9:40:23 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.119 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.3-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.3-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.3-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.3-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.3-SNAPSHOT/platform-1.7.3-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.3-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.3-SNAPSHOT/platform-1.7.3-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/platform/target/platform-1.7.3-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.3-SNAPSHOT/platform-1.7.3-SNAPSHOT-sources.jar
[INFO] Building Data Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/data/target
[INFO] snapshot org.geotools:gt-epsg-hsql:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-coverage:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:xsd:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:extension:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-graph:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] Total time: 22 seconds
[INFO] Finished at: Sat Mar 14 21:40:26 EDT 2009
[INFO] Final Memory: 30M/53M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/764/changes
[...truncated 54 lines...]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/target
[INFO] snapshot org.geotools:gt-api:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:library:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:modules:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:geotools:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-referencing:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-metadata:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-main:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
T E S T S
Mar 15, 2009 4:54:08 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.115 sec
Results :
[INFO] [jar:jar]
[INFO] Total time: 16 seconds
[INFO] Finished at: Sun Mar 15 16:54:11 EDT 2009
[INFO] Final Memory: 30M/56M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/765/changes
