See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/812/changes
started
ERROR: svn: PROPFIND request failed on '/geoserver/branches/1.7.x/src'
svn: svn.codehaus.org
org.tmatesoft.svn.core.SVNException: svn: PROPFIND request failed on '/geoserver/branches/1.7.x/src'
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:49)
at org.tmatesoft.svn.core.internal.io.dav.DAVUtil.findStartingProperties(DAVUtil.java:124)
at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.fetchRepositoryUUID(DAVConnection.java:88)
at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.testConnection(DAVRepository.java:85)
at hudson.scm.SubversionSCM$DescriptorImpl.checkRepositoryPath(SubversionSCM.java:1220)
at hudson.scm.SubversionSCM.repositoryLocationsExist(SubversionSCM.java:1281)
at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:336)
at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:300)
at hudson.model.AbstractProject.checkout(AbstractProject.java:558)
at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:215)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:181)
at hudson.model.Run.run(Run.java:659)
at hudson.model.Build.run(Build.java:101)
at hudson.model.ResourceController.execute(ResourceController.java:70)
at hudson.model.Executor.run(Executor.java:65)
