[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #919
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/919/
[...truncated 6433 lines...]
12/78K
16/78K
20/78K
24/78K
28/78K
32/78K
36/78K
40/78K
44/78K
48/78K
52/78K
56/78K
60/78K
64/78K
68/78K
72/78K
76/78K
78/78K
78K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/classes
[INFO] [resources:testResources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:testCompile]
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/surefire-reports
T E S T S
Running org.geoserver.h2.H2DataStoreInitializerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.57 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.5-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.5-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.5-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.5-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/1.7.5-SNAPSHOT/h2-1.7.5-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.5-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/1.7.5-SNAPSHOT/h2-1.7.5-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/h2/target/h2-1.7.5-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/h2/1.7.5-SNAPSHOT/h2-1.7.5-SNAPSHOT-sources.jar
[INFO] Building SQL Server DataStore Extension
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target
[INFO] [resources:resources]
[INFO] snapshot org.geotools:gt-jdbc-sqlserver:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc-sqlserver:2.5-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc-sqlserver/2.5-SNAPSHOT/gt-jdbc-sqlserver-2.5-20090508.060149-58.pom
3/3K
3K downloaded
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc-sqlserver/2.5-SNAPSHOT/gt-jdbc-sqlserver-2.5-20090508.060149-58.jar
4/7K
7/7K
7K downloaded
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.5-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.5-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.5-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.5-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/sqlserver/1.7.5-SNAPSHOT/sqlserver-1.7.5-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.5-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/sqlserver/1.7.5-SNAPSHOT/sqlserver-1.7.5-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/sqlserver/target/sqlserver-1.7.5-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/sqlserver/1.7.5-SNAPSHOT/sqlserver-1.7.5-SNAPSHOT-sources.jar
[INFO] Building Oracle DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/oracle/target
[INFO] snapshot org.geotools:gt-jdbc-oracle:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc-oracle:2.5-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc-oracle/2.5-SNAPSHOT/gt-jdbc-oracle-2.5-20090508.060149-58.pom
3/3K
3K downloaded
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc-oracle/2.5-SNAPSHOT/gt-jdbc-oracle-2.5-20090508.060149-58.jar
4/57K
8/57K
12/57K
16/57K
20/57K
24/57K
28/57K
32/57K
36/57K
40/57K
44/57K
48/57K
52/57K
56/57K
57/57K
57K downloaded
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/oracle/target/oracle-1.7.5-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/oracle/target/oracle-1.7.5-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/oracle/target/oracle-1.7.5-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/oracle/target/oracle-1.7.5-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/1.7.5-SNAPSHOT/oracle-1.7.5-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/oracle/target/oracle-1.7.5-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/1.7.5-SNAPSHOT/oracle-1.7.5-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/oracle/target/oracle-1.7.5-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/1.7.5-SNAPSHOT/oracle-1.7.5-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/wfsv/target
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.5-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wfsv/2.5-SNAPSHOT/net.opengis.wfsv-2.5-20090508.060149-59.pom
1/1K
1K downloaded
[INFO] snapshot org.geotools:gt-postgis-versioned:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-postgis-versioned:2.5-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-postgis-versioned/2.5-SNAPSHOT/gt-postgis-versioned-2.5-20090508.060149-58.pom
4/4K
4/4K
4K downloaded
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wfsv/2.5-SNAPSHOT/net.opengis.wfsv-2.5-20090508.060149-59.jar
4/47K
8/47K
12/47K
16/47K
20/47K
24/47K
28/47K
32/47K
36/47K
40/47K
44/47K
47/47K
47K downloaded
Downloading: http://repo.opengeo.org//org/geotools/gt-postgis-versioned/2.5-SNAPSHOT/gt-postgis-versioned-2.5-20090508.060149-58.jar
4/66K
8/66K
12/66K
16/66K
20/66K
24/66K
28/66K
32/66K
36/66K
40/66K
44/66K
48/66K
52/66K
56/66K
60/66K
64/66K
66/66K
66K downloaded
[INFO] Compiling 54 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/wfsv/target/classes
[INFO] Compiling 8 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/wfsv/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/wfsv/target/surefire-reports
T E S T S
Running org.geoserver.wfsv.security.ReadOnlyVersioningDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.628 sec
Running org.geoserver.wfsv.HistoryRelatedTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.186 sec <<< FAILURE!
Running org.geoserver.wfsv.LogOrderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.078 sec <<< FAILURE!
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.047 sec <<< FAILURE!
Running org.geoserver.wfsv.security.ReadOnlyVersioningFeatureStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.027 sec
Running org.geoserver.wfsv.RollbackTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.026 sec <<< FAILURE!
Results :
Tests in error:
  testRollbackWfs11(org.geoserver.wfsv.RollbackTest)
  testRollbackWfs10(org.geoserver.wfsv.RollbackTest)
  testInvalidRollback(org.geoserver.wfsv.RollbackTest)
Tests run: 10, Failures: 0, Errors: 6, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/extension/wfsv/target/surefire-reports for the individual test results.
[INFO] Total time: 4 minutes 3 seconds
[INFO] Finished at: Fri May 08 04:19:01 EDT 2009
[INFO] Final Memory: 45M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/920/
[...truncated 4022 lines...]
[INFO] [jar:jar]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.632 sec
08 May 04:30:12 ERROR [data.postgis] - Could not version enable: archsites
java.io.IOException: This feature type (archsites) is associated to an unsupported fid mapper: class org.geotools.data.jdbc.fidmapper.NullFIDMapper
The supported fid mapper classes are: [class org.geotools.data.jdbc.fidmapper.BasicFIDMapper, class org.geotools.data.jdbc.fidmapper.MultiColumnFIDMapper, class org.geotools.data.postgis.fidmapper.PostGISAutoIncrementFIDMapper]
  at org.geotools.data.postgis.VersionedPostgisDataStore.enableVersioning(VersionedPostgisDataStore.java:1052)
  at org.geotools.data.postgis.VersionedPostgisDataStore.setVersioned(VersionedPostgisDataStore.java:387)
  at org.geotools.data.postgis.VersionedPostgisDataStoreFactory.createDataStore(VersionedPostgisDataStoreFactory.java:155)
  at org.vfny.geoserver.util.DataStoreUtils.getDataStore(DataStoreUtils.java:75)
  at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:181)
  at org.geoserver.catalog.impl.DataStoreInfoImpl.getDataStore(DataStoreInfoImpl.java:29)
  at org.geoserver.catalog.util.LegacyCatalogImporter.importDataStores(LegacyCatalogImporter.java:356)
  at org.geoserver.catalog.util.LegacyCatalogImporter.importCatalog(LegacyCatalogImporter.java:301)
  at org.geoserver.catalog.util.LegacyCatalogImporter.imprt(LegacyCatalogImporter.java:151)
  at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:119)
  at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:81)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
  at java.security.AccessController.doPrivileged(Native Method)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
  at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
  at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
  at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
  at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
  at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
  at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
  at org.geoserver.test.GeoServerAbstractTestSupport.oneTimeSetUp(GeoServerAbstractTestSupport.java:170)
  at org.geoserver.wfsv.WFSVTestSupport.oneTimeSetUp(WFSVTestSupport.java:38)
  at org.geoserver.wfsv.HistoryRelatedTest.oneTimeSetUp(HistoryRelatedTest.java:21)
  at org.geoserver.test.OneTimeSetupTest$OneTimeTestSetup.setUp(OneTimeSetupTest.java:51)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:20)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
08 May 04:30:18 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSTransactionException: {http://www.openplans.org/topp\}archsites is read-only
  at org.geoserver.wfs.Transaction.execute(Transaction.java:272)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:108)
  at org.geoserver.wfsv.DefaultVersioningWebFeatureService.transaction(DefaultVersioningWebFeatureService.java:186)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy13.transaction(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:583)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:212)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1012)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:979)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:634)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:581)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:561)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:770)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:753)
  at org.geoserver.wfsv.HistoryRelatedTest.oneTimeSetUp(HistoryRelatedTest.java:56)
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 16.799 sec <<< FAILURE!
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.295 sec <<< FAILURE!
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.749 sec <<< FAILURE!
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.057 sec <<< FAILURE!
Results :
Failed tests:
Tests in error:
Tests run: 10, Failures: 1, Errors: 5, Skipped: 0
[INFO] Total time: 3 minutes 59 seconds
[INFO] Finished at: Fri May 08 04:30:21 EDT 2009
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/921/
