[Geoserver-devel] Build failed in Hudson: geoserver-1.7.x #940
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/940/
[...truncated 3569 lines...]
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor125.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
<ServiceExceptionReport version="1.1.1"> <ServiceException code="InvalidParameterValue" locator="info_format">
      Invalid format 'unknown/format', supported formats are [text/plain, text/html, application/vnd.ogc.gml]
</ServiceException>
</ServiceExceptionReport>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.858 sec
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
16 May 22:44:27 ERROR [geoserver.ows] -
java.io.IOException
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:126)
  at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:614)
  at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:712)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1012)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:979)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:449)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:430)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:704)
  at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testBogusRegionator(GeoSearchKMLTest.java:92)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:123)
  ... 44 more
Caused by: java.lang.RuntimeException: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:173)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:133)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  ... 46 more
Caused by: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.loadFeatureCollection(KMLUtils.java:484)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:169)
  ... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.337 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.225 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.19 sec
Results :
Tests run: 144, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.5-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.5-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.5-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.5-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.5-SNAPSHOT/wms-1.7.5-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.5-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.5-SNAPSHOT/wms-1.7.5-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/wms/target/wms-1.7.5-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.5-SNAPSHOT/wms-1.7.5-SNAPSHOT-sources.jar
[INFO] Building Geoserver REST Support Code
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/rest/target
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 22 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/rest/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 11 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/rest/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/rest/target/surefire-reports
T E S T S
Running org.geoserver.rest.ReflectiveResourceTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.624 sec
Running org.geoserver.rest.format.FormatTest
May 16, 2009 10:44:36 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.621 sec
Running org.geoserver.rest.RESTDispatcherTest
16 May 22:44:38 ERROR [geoserver.rest] - error
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.407 sec
Running org.geoserver.rest.format.ReflectiveHTMLFormatTest
<html>
  <body>
  This is a generic template for Foo.
  <br>
  Properties:
  <ul>
    <li>prop3: 3.0
    <li>prop1: one
    <li>prop2: 2
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.162 sec
Running org.geoserver.rest.MapResourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Running org.geoserver.rest.IndexRestletTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.323 sec
Results :
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/rest/target/rest-1.7.5-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/rest/target/rest-1.7.5-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/rest/target/rest-1.7.5-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/rest/target/rest-1.7.5-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/rest/1.7.5-SNAPSHOT/rest-1.7.5-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/rest/target/rest-1.7.5-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/rest/1.7.5-SNAPSHOT/rest-1.7.5-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/rest/target/rest-1.7.5-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/rest/1.7.5-SNAPSHOT/rest-1.7.5-SNAPSHOT-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target
[INFO] Nothing to compile - all classes are up to date
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.5-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.5-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.5-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.5-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/1.7.5-SNAPSHOT/gwc-1.7.5-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.5-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/1.7.5-SNAPSHOT/gwc-1.7.5-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/gwc/target/gwc-1.7.5-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/1.7.5-SNAPSHOT/gwc-1.7.5-SNAPSHOT-sources.jar
[INFO] Building Web Application Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/webapp/data
[INFO] snapshot org.geotools:gt-postgis:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-postgis:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-directory:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-directory:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 108 source files to http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/java/org/vfny/geoserver/action/validation/ValidationRunnable.java :[109,35] cannot find symbol
symbol : method getFeatureSources()
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/java/org/vfny/geoserver/action/validation/ValidationRunnable.java :[140,43] cannot find symbol
[INFO] Total time: 2 minutes 52 seconds
[INFO] Finished at: Sat May 16 22:44:44 EDT 2009
[INFO] Final Memory: 39M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/941/
[...truncated 3568 lines...]
</ServiceException>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.893 sec
17 May 16:33:57 ERROR [geoserver.ows] -
java.io.IOException
  ... 44 more
  ... 46 more
  ... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.354 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.173 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.193 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.617 sec
May 17, 2009 4:34:06 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.436 sec
17 May 16:34:08 ERROR [geoserver.rest] - error
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.403 sec
<html>
  <body>
  <br>
  Properties:
  <ul>
    <li>prop3: 3.0
    <li>prop1: one
    <li>prop2: 2
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.155 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.324 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
clean:
[INFO] Total time: 2 minutes 55 seconds
[INFO] Finished at: Sun May 17 16:34:14 EDT 2009
[INFO] Final Memory: 42M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/942/changes
Changes:
[mcr] modifying plugins according to GEOT-2486
[...truncated 3570 lines...]
</ServiceException>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.925 sec
17 May 17:41:00 ERROR [geoserver.ows] -
java.io.IOException
  ... 44 more
  ... 46 more
  ... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.514 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.203 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.196 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.689 sec
May 17, 2009 5:41:09 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.567 sec
17 May 17:41:10 ERROR [geoserver.rest] - error
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.38 sec
<html>
  <body>
  <br>
  Properties:
  <ul>
    <li>prop3: 3.0
    <li>prop1: one
    <li>prop2: 2
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.187 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.299 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
clean:
[INFO] Total time: 2 minutes 51 seconds
[INFO] Finished at: Sun May 17 17:41:15 EDT 2009
Failed to send e-mail to mcr because no e-mail address is known, and no default e-mail domain is configured
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/943/
[...truncated 3567 lines...]
</ServiceException>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.982 sec
17 May 18:33:41 ERROR [geoserver.ows] -
java.io.IOException
  ... 44 more
  ... 46 more
  ... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.412 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.204 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: -0.023 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.205 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.059 sec
May 17, 2009 6:33:50 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.81 sec
17 May 18:33:51 ERROR [geoserver.rest] - error
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.4 sec
<html>
  <body>
  <br>
  Properties:
  <ul>
    <li>prop3: 3.0
    <li>prop1: one
    <li>prop2: 2
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.159 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.027 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.32 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
clean:
[INFO] Total time: 2 minutes 47 seconds
[INFO] Finished at: Sun May 17 18:33:57 EDT 2009
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/944/
</ServiceException>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.945 sec
18 May 08:34:32 ERROR [geoserver.ows] -
java.io.IOException
  ... 44 more
  ... 46 more
  ... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.447 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.224 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.175 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.672 sec
May 18, 2009 8:34:41 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.627 sec
18 May 08:34:43 ERROR [geoserver.rest] - error
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.431 sec
<html>
  <body>
  <br>
  Properties:
  <ul>
    <li>prop3: 3.0
    <li>prop1: one
    <li>prop2: 2
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.165 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.34 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
clean:
[INFO] Total time: 3 minutes 4 seconds
[INFO] Finished at: Mon May 18 08:34:49 EDT 2009
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/945/
</ServiceException>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.9 sec
18 May 14:34:33 ERROR [geoserver.ows] -
java.io.IOException
  ... 44 more
  ... 46 more
  ... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.606 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.185 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.251 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.599 sec
May 18, 2009 2:34:42 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.496 sec
18 May 14:34:43 ERROR [geoserver.rest] - error
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.466 sec
<html>
  <body>
  <br>
  Properties:
  <ul>
    <li>prop3: 3.0
    <li>prop1: one
    <li>prop2: 2
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.163 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.349 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
clean:
[INFO] Finished at: Mon May 18 14:34:50 EDT 2009
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/946/
</ServiceException>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.944 sec
18 May 16:33:14 ERROR [geoserver.ows] -
java.io.IOException
  ... 44 more
  ... 46 more
  ... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.436 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.156 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.229 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.663 sec
May 18, 2009 4:33:23 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.555 sec
18 May 16:33:24 ERROR [geoserver.rest] - error
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.428 sec
<html>
  <body>
  <br>
  Properties:
  <ul>
    <li>prop3: 3.0
    <li>prop1: one
    <li>prop2: 2
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.191 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.305 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
clean:
[INFO] Total time: 2 minutes 45 seconds
[INFO] Finished at: Mon May 18 16:33:29 EDT 2009
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/947/
</ServiceException>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.905 sec
19 May 02:49:48 ERROR [geoserver.ows] -
java.io.IOException
  ... 44 more
  ... 46 more
  ... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.462 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.186 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.032 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.198 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.695 sec
May 19, 2009 2:49:57 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.534 sec
19 May 02:49:58 ERROR [geoserver.rest] - error
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.421 sec
<html>
  <body>
  <br>
  Properties:
  <ul>
    <li>prop3: 3.0
    <li>prop1: one
    <li>prop2: 2
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.164 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.337 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
clean:
[INFO] Total time: 3 minutes 9 seconds
[INFO] Finished at: Tue May 19 02:50:04 EDT 2009
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/948/changes
Changes:
[jgarnett] Patch ValidationRunnable to build up map of featuresources based on provided repository
[...truncated 3574 lines...]
</ServiceException>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.895 sec
19 May 03:26:33 ERROR [geoserver.ows] -
java.io.IOException
  ... 44 more
  ... 46 more
  ... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.396 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.208 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.216 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.619 sec
May 19, 2009 3:26:41 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.528 sec
19 May 03:26:42 ERROR [geoserver.rest] - error
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.414 sec
<html>
  <body>
  <br>
  Properties:
  <ul>
    <li>prop3: 3.0
    <li>prop1: one
    <li>prop2: 2
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.161 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.336 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
clean:
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/java/org/vfny/geoserver/action/validation/ValidationRunnable.java :[45,12] cannot find symbol
symbol : class DataConfig
location: class org.vfny.geoserver.action.validation.ValidationRunnable
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/java/org/vfny/geoserver/action/validation/ValidationRunnable.java :[176,16] cannot find symbol
symbol : class DataStoreConfig
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/java/org/vfny/geoserver/action/validation/ValidationRunnable.java :[176,39] cannot find symbol
[INFO] Total time: 2 minutes 50 seconds
[INFO] Finished at: Tue May 19 03:26:48 EDT 2009
Failed to send e-mail to jgarnett because no e-mail address is known, and no default e-mail domain is configured
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/949/changes
Changes:
[...truncated 3564 lines...]
</ServiceException>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.934 sec
19 May 03:47:31 ERROR [geoserver.ows] -
java.io.IOException
  ... 44 more
  ... 46 more
  ... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.473 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.177 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.638 sec
May 19, 2009 3:47:40 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.617 sec
19 May 03:47:41 ERROR [geoserver.rest] - error
<html>
  <body>
  <br>
  Properties:
  <ul>
    <li>prop3: 3.0
    <li>prop1: one
    <li>prop2: 2
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.17 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.31 sec
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
clean:
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/java/org/vfny/geoserver/action/validation/ValidationRunnable.java :[114,55] unreported exception java.io.IOException; must be caught or declared to be thrown
http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/ws/geoserver_17x/web/src/main/java/org/vfny/geoserver/action/validation/ValidationRunnable.java :[116,119] unreported exception java.io.IOException; must be caught or declared to be thrown
[INFO] Finished at: Tue May 19 03:47:47 EDT 2009
See http://hudson.opengeo.org/hudson/job/geoserver-1.7.x/950/changes
