[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x #130
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/130/changes&gt;
Changes:
[groldan] merge back patch for GEOS-3677
[arneke] GWC Adding transaction listener, will truncate cache on WFS-T events
[...truncated 20435 lines...]
          <Title>Default Styler</Title>
          <Abstract/>
          <LegendURL height="20" width="20">
            <Format>image/png</Format>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Ponds&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
      <Layer queryable="1">
        <Name>sf:PrimitiveGeoFeature</Name>
        <Title>PrimitiveGeoFeature</Title>
        <Abstract>abstract about PrimitiveGeoFeature</Abstract>
        <KeywordList>
          <Keyword>PrimitiveGeoFeature</Keyword>
        </KeywordList>
        <SRS>EPSG:4326</SRS>
        <!--WKT definition of this CRS:
GEOGCS["WGS 84",
  DATUM["World Geodetic System 1984",
    SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
    AUTHORITY["EPSG","6326"]],
  PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
  UNIT["degree", 0.017453292519943295],
  AXIS["Geodetic longitude", EAST],
  AXIS["Geodetic latitude", NORTH],
  AUTHORITY["EPSG","4326"]]-->
        <LatLonBoundingBox maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
        <BoundingBox SRS="EPSG:4326" maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
        <Style>
          <Name>Default</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=PrimitiveGeoFeature&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cite:RoadSegments</Name>
        <Title>RoadSegments</Title>
        <Abstract>abstract about RoadSegments</Abstract>
        <KeywordList>
          <Keyword>RoadSegments</Keyword>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Name>RoadSegments</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=RoadSegments&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cdf:Seven</Name>
        <Title>Seven</Title>
        <Abstract>abstract about Seven</Abstract>
        <KeywordList>
          <Keyword>Seven</Keyword>
        </KeywordList>
        <SRS>EPSG:32615</SRS>
PROJCS["WGS 84 / UTM zone 15N",
  GEOGCS["WGS 84",
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Transverse Mercator", AUTHORITY["EPSG","9807"]],
  PARAMETER["central_meridian", -93.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["scale_factor", 0.9996],
  PARAMETER["false_easting", 500000.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["Easting", EAST],
  AXIS["Northing", NORTH],
  AUTHORITY["EPSG","32615"]]-->
        <Style>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Seven&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cite:Streams</Name>
        <Title>Streams</Title>
        <Abstract>abstract about Streams</Abstract>
        <KeywordList>
          <Keyword>Streams</Keyword>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Name>Streams</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Streams&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cdf:Updates</Name>
        <Title>Updates</Title>
        <Abstract>abstract about Updates</Abstract>
        <KeywordList>
          <Keyword>Updates</Keyword>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Updates&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
</WMT_MS_Capabilities>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.332 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.202 sec
Results :
Tests run: 166, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/wms-2.0.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/wms-2.0.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/wms-2.0.1-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/wms-2.0.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.0.1-SNAPSHOT/wms-2.0.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/wms-2.0.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.0.1-SNAPSHOT/wms-2.0.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/wms-2.0.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.0.1-SNAPSHOT/wms-2.0.1-SNAPSHOT-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/gwc/target&gt;
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] snapshot org.geowebcache:geowebcache:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:geowebcache:1.2-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/gwc/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/gwc/src/main/java/org/geoserver/gwc/GWCTransactionListener.java&gt;:\[15,25\] package org.geoserver.wfs does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/gwc/src/main/java/org/geoserver/gwc/GWCTransactionListener.java&gt;:\[16,25\] package org.geoserver.wfs does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/gwc/src/main/java/org/geoserver/gwc/GWCTransactionListener.java&gt;:\[17,25\] package org.geoserver.wfs does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/gwc/src/main/java/org/geoserver/gwc/GWCTransactionListener.java&gt;:\[19,47\] cannot find symbol
symbol: class TransactionListener
public class GWCTransactionListener implements TransactionListener {
<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/gwc/src/main/java/org/geoserver/gwc/GWCTransactionListener.java&gt;:\[30,32\] cannot find symbol
symbol : class TransactionEvent
location: class org.geoserver.gwc.GWCTransactionListener
<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/gwc/src/main/java/org/geoserver/gwc/GWCTransactionListener.java&gt;:\[30,63\] cannot find symbol
symbol : class WFSException
[INFO] Total time: 3 minutes 51 seconds
[INFO] Finished at: Fri Nov 27 12:40:24 EST 2009
[INFO] Final Memory: 42M/116M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/131/changes&gt;
