See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/140/>
[...truncated 26610 lines...]
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
30 Nov 14:06:10 ERROR [geoserver.rest] - No such workspace: foo
org.geoserver.rest.RestletException
at org.geoserver.catalog.rest.WorkspaceFinder.findTarget(WorkspaceFinder.java:33)
at org.restlet.Finder.handle(Finder.java:268)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:79)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1058)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1025)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:467)
at org.geoserver.catalog.rest.WorkspaceTest.testDelete(WorkspaceTest.java:152)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:125)
30 Nov 14:06:10 ERROR [geoserver.rest] - Workspace not empty
at org.geoserver.catalog.rest.WorkspaceResource.handleObjectDelete(WorkspaceResource.java:150)
at org.geoserver.rest.ReflectiveResource.handleDelete(ReflectiveResource.java:219)
at org.restlet.Finder.handle(Finder.java:300)
at org.springframework.web.servlet.FrameworkServlet.doDelete(FrameworkServlet.java:531)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:715)
at org.geoserver.test.GeoServerAbstractTestSupport.deleteAsServletResponse(GeoServerAbstractTestSupport.java:666)
at org.geoserver.catalog.rest.WorkspaceTest.testDeleteNonEmptyForbidden(WorkspaceTest.java:156)
30 Nov 14:06:10 ERROR [geoserver.rest] - Can't change the name of a workspace.
at org.geoserver.catalog.rest.WorkspaceResource.handleObjectPut(WorkspaceResource.java:129)
at org.geoserver.rest.ReflectiveResource.handlePut(ReflectiveResource.java:188)
at org.restlet.Finder.handle(Finder.java:298)
at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:521)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:712)
at org.geoserver.test.GeoServerAbstractTestSupport.putAsServletResponse(GeoServerAbstractTestSupport.java:563)
at org.geoserver.test.GeoServerAbstractTestSupport.putAsServletResponse(GeoServerAbstractTestSupport.java:551)
at org.geoserver.catalog.rest.WorkspaceTest.testPutNameChangeForbidden(WorkspaceTest.java:189)
30 Nov 14:06:10 ERROR [geoserver.rest] - No such workspace: nonExistant
at org.geoserver.catalog.rest.WorkspaceTest.testPutNonExistant(WorkspaceTest.java:205)
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.622 sec
Results :
Failed tests:
testCreateFeatureType(org.geoserver.catalog.rest.JDBCTest)
Tests in error:
testCreateDataStore(org.geoserver.catalog.rest.JDBCTest)
testCreateGeometrylessFeatureType(org.geoserver.catalog.rest.JDBCTest)
Tests run: 143, Failures: 1, Errors: 2, Skipped: 0
30 Nov 14:06:11 ERROR [geotools.jdbc] - There's code using JDBC based datastore and not disposing them. This may lead to temporary loss of database connections. Please make sure all data access code calls DataStore.dispose() before freeing all references to it
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/restconfig/target/surefire-reports> for the individual test results.
[INFO] Total time: 10 minutes 7 seconds
[INFO] Finished at: Mon Nov 30 14:06:11 EST 2009
[INFO] Final Memory: 54M/144M
