See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/152/>
[...truncated 21176 lines...]
16/189K
18/189K
19/189K
23/189K
27/189K
30/189K
34/189K
34/189K
38/189K
42/189K
46/189K
50/189K
51/189K
55/189K
55/189K
58/189K
61/189K
65/189K
65/189K
69/189K
73/189K
74/189K
75/189K
79/189K
79/189K
83/189K
83/189K
87/189K
87/189K
90/189K
91/189K
94/189K
98/189K
102/189K
106/189K
110/189K
114/189K
118/189K
122/189K
126/189K
130/189K
130/189K
134/189K
134/189K
137/189K
141/189K
142/189K
143/189K
146/189K
149/189K
153/189K
157/189K
161/189K
161/189K
165/189K
169/189K
173/189K
177/189K
181/189K
185/189K
189/189K
189K downloaded
Downloading: http://dev.mapfish.org/maven/repository/org/json/json/20080701/json-20080701.jar
4/36K
8/36K
12/36K
16/36K
20/36K
24/36K
28/36K
32/36K
36/36K
36/36K
36K downloaded
Downloading: http://dev.mapfish.org/maven/repository/org/jyaml/jyaml/1.3/jyaml-1.3.jar
4/57K
8/57K
12/57K
16/57K
20/57K
24/57K
28/57K
32/57K
36/57K
40/57K
44/57K
47/57K
51/57K
55/57K
57/57K
57K downloaded
Downloading: http://dev.mapfish.org/maven/repository/ch/thus/pvalsecc/0.9.2/pvalsecc-0.9.2.jar
4/83K
8/83K
12/83K
16/83K
20/83K
24/83K
28/83K
32/83K
36/83K
40/83K
44/83K
48/83K
52/83K
56/83K
60/83K
62/83K
66/83K
66/83K
69/83K
73/83K
77/83K
81/83K
83/83K
83K downloaded
Downloading: http://dev.mapfish.org/maven/repository/org/mapfish/geo/mapfish-geo-lib/1.2-SNAPSHOT/mapfish-geo-lib-1.2-20090817.094015-3.jar
4/13K
8/13K
12/13K
13/13K
13K downloaded
Downloading: http://dev.mapfish.org/maven/repository/com/vividsolutions/jts/jtsio/1.8/jtsio-1.8.jar
4/31K
8/31K
12/31K
16/31K
20/31K
24/31K
28/31K
31/31K
31K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/printing/target/classes>
[INFO] [resources:testResources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/printing/target/printing-2.0.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/printing/target/printing-2.0.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/printing/target/printing-2.0.1-SNAPSHOT-sources.jar>
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/printing/target/printing-2.0.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.0.1-SNAPSHOT/printing-2.0.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/printing/target/printing-2.0.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.0.1-SNAPSHOT/printing-2.0.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/printing/target/printing-2.0.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.0.1-SNAPSHOT/printing-2.0.1-SNAPSHOT-sources.jar
[INFO] Building HTTP Proxy Extension
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/proxy/target>
[INFO] [resources:resources]
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/proxy/target/classes>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/proxy/target/proxy-2.0.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/proxy/target/proxy-2.0.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/proxy/target/proxy-2.0.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/proxy/target/proxy-2.0.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/community/proxy/2.0.1-SNAPSHOT/proxy-2.0.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/proxy/target/proxy-2.0.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/proxy/2.0.1-SNAPSHOT/proxy-2.0.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/community/proxy/target/proxy-2.0.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/proxy/2.0.1-SNAPSHOT/proxy-2.0.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer Web Application
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/app/target>
[INFO] [config:clean {execution: configClean}]
clean:
[delete] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/app/src/main/webapp/data>
[INFO] snapshot org.geotools:gt-directory:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-directory:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 9 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/app/target/classes>
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/app/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/app/target/surefire-reports>
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
Dec 5, 2009 2:04:50 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 9.342 sec <<< FAILURE!
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.03 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.035 sec
Results :
Tests in error:
Tests run: 12, Failures: 0, Errors: 1, Skipped: 0
05 Dec 02:04:54 ERROR [layer.TileLayerDispatcher] - Configuration GeoServer Catalog Listener contained no layers.
05 Dec 02:04:54 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
05 Dec 02:04:54 ERROR [layer.TileLayerDispatcher] - Configuration <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/app/null/../resources> contained no layers.
05 Dec 02:04:54 ERROR [layer.TileLayerDispatcher] - Error reading service information from <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/app/null/../resources>: Error parsing file <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/app/null/../resources/geowebcache\.xml>
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/app/target/surefire-reports> for the individual test results.
[INFO] Total time: 8 minutes 16 seconds
[INFO] Finished at: Sat Dec 05 02:04:54 EST 2009
[INFO] Final Memory: 48M/136M
