[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x #241
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/241/changes&gt;
Changes:
[aaime] GEOS-3769, GeoServer leaks permgen memory on redeploys
[...truncated 20999 lines...]
  PARAMETER["central_meridian", -93.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["scale_factor", 0.9996],
  PARAMETER["false_easting", 500000.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["Easting", EAST],
  AXIS["Northing", NORTH],
  AUTHORITY["EPSG","32615"]]-->
        <LatLonBoundingBox maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
        <Style>
          <Name>Default</Name>
          <Title>Default Styler</Title>
          <Abstract/>
          <LegendURL height="20" width="20">
            <Format>image/png</Format>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Polygons&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
      <Layer queryable="1">
        <Name>cite:Ponds</Name>
        <Title>Ponds</Title>
        <Abstract>abstract about Ponds</Abstract>
        <KeywordList>
          <Keyword>Ponds</Keyword>
        </KeywordList>
        <SRS>EPSG:4326</SRS>
        <!--WKT definition of this CRS:
GEOGCS["WGS 84",
  DATUM["World Geodetic System 1984",
    SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
    AUTHORITY["EPSG","6326"]],
  PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
  UNIT["degree", 0.017453292519943295],
  AXIS["Geodetic longitude", EAST],
  AXIS["Geodetic latitude", NORTH],
  AUTHORITY["EPSG","4326"]]-->
        <BoundingBox SRS="EPSG:4326" maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
        <Style>
          <Name>Ponds</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Ponds&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>sf:PrimitiveGeoFeature</Name>
        <Title>PrimitiveGeoFeature</Title>
        <Abstract>abstract about PrimitiveGeoFeature</Abstract>
        <KeywordList>
          <Keyword>PrimitiveGeoFeature</Keyword>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=PrimitiveGeoFeature&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cite:RoadSegments</Name>
        <Title>RoadSegments</Title>
        <Abstract>abstract about RoadSegments</Abstract>
        <KeywordList>
          <Keyword>RoadSegments</Keyword>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Name>RoadSegments</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=RoadSegments&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cdf:Seven</Name>
        <Title>Seven</Title>
        <Abstract>abstract about Seven</Abstract>
        <KeywordList>
          <Keyword>Seven</Keyword>
        </KeywordList>
        <SRS>EPSG:32615</SRS>
PROJCS["WGS 84 / UTM zone 15N",
  GEOGCS["WGS 84",
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Transverse Mercator", AUTHORITY["EPSG","9807"]],
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Seven&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cite:Streams</Name>
        <Title>Streams</Title>
        <Abstract>abstract about Streams</Abstract>
        <KeywordList>
          <Keyword>Streams</Keyword>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Name>Streams</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Streams&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cdf:Updates</Name>
        <Title>Updates</Title>
        <Abstract>abstract about Updates</Abstract>
        <KeywordList>
          <Keyword>Updates</Keyword>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Updates&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
</WMT_MS_Capabilities>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.416 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.307 sec
Results :
Failed tests:
  testRemoteOWSGet(org.vfny.geoserver.wms.responses.map.png.GetMapTest)
Tests run: 165, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 5 minutes 16 seconds
[INFO] Finished at: Fri Jan 15 13:41:41 EST 2010
[INFO] Final Memory: 42M/113M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/242/changes&gt;
Changes:
[aaime] GEOS-3770, Logging filter will make Wicket file uploads fail
[...truncated 471 lines...]
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.logging.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.041 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.125 sec
Running org.geoserver.security.SecureCatalogImplTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.277 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
15 Jan 14:53:55 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
15 Jan 14:53:55 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
15 Jan 14:53:55 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.177 sec
Running org.vfny.geoserver.crs.OvverideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.466 sec
Running org.geoserver.security.DataAccessRuleDAOTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.071 sec
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.089 sec
Running org.geoserver.catalog.SchemaMappingTest
15 Jan 14:53:57 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
15 Jan 14:53:57 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
15 Jan 14:53:57 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.884 sec
Running org.geoserver.catalog.ResourcePoolTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.677 sec
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.catalog.impl.CatalogBuilderTest
Jan 15, 2010 2:54:00 PM org.geotools.referencing.operation.projection.TransverseMercator.Inverse transform
WARNING: Possible use of "Transverse_Mercator (Inverse transform)" projection outside its valid area.
Latitude 2541°05.9'N is out of range (±90°).
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.741 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.security.DataAccessRuleTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.466 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.45 sec
Running org.geoserver.ows.URLManglersTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.44 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 50, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.037 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Running org.geoserver.catalog.impl.CascadeRemovalReporterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: -1.98 sec
Results :
Tests run: 231, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/main/target/main-2.0.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/main/target/main-2.0.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/main/target/main-2.0.2-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/main/target/main-2.0.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/main/2.0.2-SNAPSHOT/main-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/main/target/main-2.0.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/main/2.0.2-SNAPSHOT/main-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/main/target/main-2.0.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/main/2.0.2-SNAPSHOT/main-2.0.2-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs/target&gt;
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] snapshot org.geotools:gt-imagemosaic:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] Compiling 37 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs/target/classes&gt;
[INFO] [resources:testResources]
[INFO] snapshot org.geoserver:main:2.0.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:main:2.0.2-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:testCompile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs/target/test-classes&gt;
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs/target/surefire-reports&gt;
T E S T S
Running org.vfny.geoserver.wcs.WCS10SmokeTest
Jan 15, 2010 2:54:14 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.172 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs/target/wcs-2.0.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs/target/wcs-2.0.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs/target/wcs-2.0.2-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs/target/wcs-2.0.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs/2.0.2-SNAPSHOT/wcs-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs/target/wcs-2.0.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs/2.0.2-SNAPSHOT/wcs-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs/target/wcs-2.0.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs/2.0.2-SNAPSHOT/wcs-2.0.2-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service 1.1 Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target&gt;
[INFO] [javacc:jjtree {execution: jjtree}]
Java Compiler Compiler Version 4.0 (Tree Builder)
(type "jjtree" with no arguments for help)
Warning: Output directory "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset&quot;&gt; does not exist. Creating the directory.
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset/rangeset.jjt&gt; . . .
Warning: Duplicate option setting for "VISITOR" will be ignored.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/Node.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/SimpleNode.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTRangeSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldId.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisId.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTInterpolation.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTKey.java&quot;&gt; does not exist. Will create one.
Annotated grammar generated successfully in <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj&gt;
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type "javacc" with no arguments for help)
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj&gt; . . .
File "TokenMgrError.java" does not exist. Will create one.
File "ParseException.java" does not exist. Will create one.
File "Token.java" does not exist. Will create one.
File "SimpleCharStream.java" does not exist. Will create one.
Parser generated successfully.
[INFO] snapshot org.geotools.ogc:net.opengis.wcs:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wcs:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 53 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/classes&gt;
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wcs.DescribeCoverageTest
Jan 15, 2010 2:54:33 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Jan 15, 2010 2:54:35 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Jan 15, 2010 2:54:38 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/./target/mock3995data&gt;
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 7.665 sec <<< FAILURE!
Running org.geoserver.wcs.kvp.GetCoverageReaderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.402 sec <<< FAILURE!
Running org.geoserver.wcs.kvp.BoundingBoxKvpParserTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.213 sec
Running org.geoserver.wcs.GetCoverageTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
15 Jan 14:54:39 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri Jan 15 14:54:39 EST 2010]; root of context hierarchy
15 Jan 14:54:40 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
15 Jan 14:54:40 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
15 Jan 14:54:40 WARN [org.geoserver] - No 'workspaces' directory found, unable to load any stores.
15 Jan 14:54:40 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name 'geoServerLoader': java.lang.NullPointerException
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.598 sec <<< FAILURE!
Running org.geoserver.wcs.xml.GetCapabilitiesXmlParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.168 sec
Running org.geoserver.wcs.GetCoverageMultipartEncodingTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.442 sec <<< FAILURE!
Running org.geoserver.wcs.xml.GetCoverageXmlParserTest
class [Ljava.lang.Double;: [Ljava.lang.Double;@5dd915
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.159 sec
Running org.geoserver.wcs.kvp.RangeSubsetKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.025 sec
Running org.geoserver.wcs.WCSDisabledTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.031 sec <<< FAILURE!
Running org.geoserver.wcs.xml.DescribeCoverageXmlParserTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.244 sec
Running org.geoserver.wcs.GetCapabilitiesTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.208 sec <<< FAILURE!
Results :
Tests in error:
  testDisabledServiceResponse(org.geoserver.wcs.WCSDisabledTest)
  testEnabledServiceResponse(org.geoserver.wcs.WCSDisabledTest)
Tests run: 27, Failures: 0, Errors: 7, Skipped: 0
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wcs1_1/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 1 minute 26 seconds
[INFO] Finished at: Fri Jan 15 14:54:50 EST 2010
[INFO] Final Memory: 40M/113M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/243/changes&gt;
