[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x #251
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/251/changes&gt;
Changes:
[jdeolive] GEOS-3621, adding purge parameter to style DELETE operation
[...truncated 21757 lines...]
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Polygons&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
      <Layer queryable="1">
        <Name>cite:Ponds</Name>
        <Title>Ponds</Title>
        <Abstract>abstract about Ponds</Abstract>
        <KeywordList>
          <Keyword>Ponds</Keyword>
        </KeywordList>
        <SRS>EPSG:4326</SRS>
        <!--WKT definition of this CRS:
GEOGCS["WGS 84",
  DATUM["World Geodetic System 1984",
    SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
    AUTHORITY["EPSG","6326"]],
  PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
  UNIT["degree", 0.017453292519943295],
  AXIS["Geodetic longitude", EAST],
  AXIS["Geodetic latitude", NORTH],
  AUTHORITY["EPSG","4326"]]-->
        <LatLonBoundingBox maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
        <BoundingBox SRS="EPSG:4326" maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
        <Style>
          <Name>Ponds</Name>
          <Title>Default Styler</Title>
          <Abstract/>
          <LegendURL height="20" width="20">
            <Format>image/png</Format>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Ponds&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>sf:PrimitiveGeoFeature</Name>
        <Title>PrimitiveGeoFeature</Title>
        <Abstract>abstract about PrimitiveGeoFeature</Abstract>
        <KeywordList>
          <Keyword>PrimitiveGeoFeature</Keyword>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Name>Default</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=PrimitiveGeoFeature&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cite:RoadSegments</Name>
        <Title>RoadSegments</Title>
        <Abstract>abstract about RoadSegments</Abstract>
        <KeywordList>
          <Keyword>RoadSegments</Keyword>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Name>RoadSegments</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=RoadSegments&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cdf:Seven</Name>
        <Title>Seven</Title>
        <Abstract>abstract about Seven</Abstract>
        <KeywordList>
          <Keyword>Seven</Keyword>
        </KeywordList>
        <SRS>EPSG:32615</SRS>
PROJCS["WGS 84 / UTM zone 15N",
  GEOGCS["WGS 84",
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Transverse Mercator", AUTHORITY["EPSG","9807"]],
  PARAMETER["central_meridian", -93.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["scale_factor", 0.9996],
  PARAMETER["false_easting", 500000.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["Easting", EAST],
  AXIS["Northing", NORTH],
  AUTHORITY["EPSG","32615"]]-->
        <Style>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Seven&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cite:Streams</Name>
        <Title>Streams</Title>
        <Abstract>abstract about Streams</Abstract>
        <KeywordList>
          <Keyword>Streams</Keyword>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Name>Streams</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Streams&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cdf:Updates</Name>
        <Title>Updates</Title>
        <Abstract>abstract about Updates</Abstract>
        <KeywordList>
          <Keyword>Updates</Keyword>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Updates&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
</WMT_MS_Capabilities>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.837 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.331 sec
Results :
Failed tests:
  testVector(org.vfny.geoserver.wms.responses.map.kml.KMLTest)
  testVectorWithFeatureId(org.vfny.geoserver.wms.responses.map.kml.KMLTest)
  testVectorWithRemoteLayer(org.vfny.geoserver.wms.responses.map.kml.KMLTest)
  testMissingGraphic(org.vfny.geoserver.wms.responses.map.kml.KMLTest)
  testRemoteOWSUserStyleGet(org.vfny.geoserver.wms.responses.map.png.GetMapTest)
  testOutput(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
  testDataRegionator(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
  testGeometryRegionator(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
  testRandomRegionator(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
  testBigGeometries(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
  testStrategyChangesStuff(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
  testDuplicateAttribute(org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest)
Tests in error:
  test(org.vfny.geoserver.wms.responses.map.kml.KMZMapProducerTest)
  testRasterPlacemark(org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest)
  testTransformer(org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest)
Tests run: 165, Failures: 12, Errors: 3, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 3 minutes 11 seconds
[INFO] Finished at: Wed Jan 20 11:44:31 EST 2010
[INFO] Final Memory: 42M/112M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/252/changes&gt;
Changes:
[aaime] GEOS-3779, DispatcherCallback.finishedCallback won't be called if there are issues writing out the output
[...truncated 21755 lines...]
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Name>Ponds</Name>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.37 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.38 sec
Results :
Failed tests:
Tests in error:
[INFO] Total time: 3 minutes 42 seconds
[INFO] Finished at: Wed Jan 20 13:43:04 EST 2010
[INFO] Final Memory: 43M/115M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/253/changes&gt;
Changes:
[aaime] Avoid unecessary extra buffering, the servlet response already provides one level of output buffering
[aaime] GEOS-3752, Avoid using File.deleteOnExit in production code
[aaime] Use weak references, a soft hash map with 0 hard references still keeps some hard reference around, even if for a limited time
[...truncated 21758 lines...]
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Name>Ponds</Name>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.505 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.334 sec
Results :
Failed tests:
Tests in error:
[INFO] Total time: 3 minutes 6 seconds
[INFO] Finished at: Thu Jan 21 10:44:27 EST 2010
[INFO] Final Memory: 42M/115M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/254/changes&gt;
Changes:
[aaime] Whoops, forgot to upgrade mockrunner, the current 0.3.1 version is buggy vs flushBuffers, upgrading to the 0.3.6 which is also in use in GeoTools
[...truncated 21194 lines...]
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Name>Ponds</Name>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.868 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.258 sec
Results :
Failed tests:
Tests run: 165, Failures: 1, Errors: 0, Skipped: 0
[INFO] Total time: 3 minutes 54 seconds
[INFO] Finished at: Thu Jan 21 11:53:45 EST 2010
[INFO] Final Memory: 42M/111M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/255/changes&gt;
Changes:
[aaime] GEOS-3012, don't run remote ows tests by default
[...truncated 24730 lines...]
                            <gsml:value codeSpace="some:uri">x</gsml:value>
                        </gsml:CGI_TermValue>
                    </gsml:outcropCharacter>
                    <gsml:composition>
                        <gsml:CompositionPart>
                            <gsml:proportion>
                                <gsml:CGI_TermValue>
                                    <gsml:value codeSpace="some:uri">significant</gsml:value>
                            </gsml:proportion>
                            <gsml:role>interbedded component</gsml:role>
                        </gsml:CompositionPart>
                    </gsml:composition>
                    <gsml:composition>
                            <gsml:proportion>
                                    <gsml:value codeSpace="some:uri">minor</gsml:value>
                            </gsml:proportion>
                    </gsml:composition>
                </gsml:GeologicUnit>
            </gsml:specification>
        </gsml:MappedFeature>
        <gsml:MappedFeature gml:id="mf3">
            <gml:name>CLIFTON FORMATION</gml:name>
            <gsml:observationMethod>
                    <gsml:value codeSpace="http://urn.opengis.net">urn:ogc:def:nil:OGC::missing</gsml:value>
            </gsml:observationMethod>
            <gsml:shape>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.2 52.5 -1.2 52.6 -1.1 52.6 -1.1 52.5 -1.2 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </gsml:shape>
            <gsml:specification>
                <gsml:GeologicUnit xlink:href="#gu.25678"/>
    </gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 10, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 7.95 sec <<< FAILURE!
Running org.geoserver.test.XYGeomTest
Jan 21, 2010 2:42:52 PM org.geoserver.test.XYGeomTest testDescribeFeatureType
INFO: WFS DescribeFeatureType response:
<xsd:schema elementFormDefault="qualified" targetNamespace="http://test"
    xmlns:test="http://test" xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot;&gt;
    <xsd:include schemaLocation="<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/app-schema-mock12499data/featureTypes/test_PointFeature/GeometrylessTest.xsd&quot;/&gt;&gt;
</xsd:schema>
Jan 21, 2010 2:42:52 PM org.geoserver.test.XYGeomTest testGetFeature
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="2"
    timeStamp="2010-01-21T14:42:52.329-05:00"
    xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:ogc="http://www.opengis.net/ogc&quot;
    xmlns:ows="http://www.opengis.net/ows&quot; xmlns:test="http://test"
    xmlns:wfs="http://www.opengis.net/wfs&quot;
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://test <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/app-schema-mock12499data/featureTypes/test_PointFeature/GeometrylessTest.xsd&gt; http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMembers>
        <test:PointFeature gml:id="mf1">
            <test:loc/>
        </test:PointFeature>
        <test:PointFeature gml:id="mf2">
            <test:loc/>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.039 sec
Running org.geoserver.test.SRSWfsTest
Jan 21, 2010 2:42:58 PM org.geoserver.test.SRSWfsTest testGetFeatureContent
INFO: WFS GetFeature&typename=ex:geomContainer response:
    timeStamp="2010-01-21T14:42:58.899-05:00"
    xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/app-schema-mock12501data/featureTypes/ex_geomContainer/NestedGeometry.xsd&gt; http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfs.xsd&quot;&gt;
        <ex:geomContainer gml:id="1">
            <ex:geom>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                <ex:nestedGeom gml:id="nested.2">
                    <ex:geom>
                        <gml:Point>
                            <gml:pos>42.58 31.29</gml:pos>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
        <ex:geomContainer gml:id="2">
            <ex:geom>
                <gml:Point>
                </gml:Point>
            </ex:geom>
            <ex:nestedFeature>
                <ex:nestedGeom gml:id="nested.1">
                    <ex:geom>
                        <gml:Polygon>
                            <gml:exterior>
                                <gml:LinearRing>
                                </gml:LinearRing>
                            </gml:exterior>
                        </gml:Polygon>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Jan 21, 2010 2:43:00 PM org.geoserver.test.SRSWfsTest testReproject
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326 response:
    timeStamp="2010-01-21T14:43:00.032-05:00"
            <ex:geom>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.1999999999634965 52.5 -1.1999999999634965 52.6 -1.099999999966089 52.59999999999999 -1.099999999966089 52.5 -1.1999999999634965 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                        <gml:Point>
                            <gml:pos>42.58000004047607 31.29</gml:pos>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
            <ex:geom>
                <gml:Point>
                </gml:Point>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                        <gml:Polygon>
                            <gml:exterior>
                                <gml:LinearRing>
                                </gml:LinearRing>
                            </gml:exterior>
                        </gml:Polygon>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Jan 21, 2010 2:43:00 PM org.geoserver.test.SRSWfsTest testFilters
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326&featureid=1response:
<wfs:FeatureCollection numberOfFeatures="1"
    timeStamp="2010-01-21T14:43:00.146-05:00"
            <ex:geom>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                        </gml:LinearRing>
                    </gml:exterior>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.176 sec
Results :
Failed tests:
  testGetFeatureContent(org.geoserver.test.FeatureChainingWfsTest)
Tests run: 24, Failures: 1, Errors: 0, Skipped: 0
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                        <gml:Point>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 7 minutes 1 second
[INFO] Finished at: Thu Jan 21 14:43:00 EST 2010
[INFO] Final Memory: 50M/127M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/256/changes&gt;
