See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/277/changes>
Changes:
[aaime] Make sure we're using the latest spring-jdbc, acegi imports an older one
[aaime] GEOS-3796, JAIInitializer sets a recycling tile factory even if tile recycling is not enabled
[...truncated 25809 lines...]
[INFO] [resources:testResources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:testCompile]
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/wfsv/target/test-classes>
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/wfsv/target/surefire-reports>
T E S T S
Running org.geoserver.wfsv.security.ReadOnlyVersioningDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.766 sec
Running org.geoserver.wfsv.HistoryRelatedTest
Feb 4, 2010 6:59:27 AM org.geoserver.data.test.LiveDbmsData disableTest
WARNING: Disabling test based on fixture wfsv since the file /home/tomcat/.geoserver/wfsv.properties could not be found
Feb 4, 2010 6:59:27 AM org.geoserver.test.GeoServerAbstractTestSupport runTest
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testValidateInvalidRequest since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetFeatureBeforeAfter since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection10 since test data is not available
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.122 sec
Running org.geoserver.wfsv.LogOrderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Running org.geoserver.wfsv.security.ReadOnlyVersioningFeatureStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.049 sec
Running org.geoserver.wfsv.RollbackTest
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection10Reproject since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection11Reproject since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testLog10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testLog11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testLog10Html since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11Html since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11Reverse since test data is not available
WARNING: Skipping class org.geoserver.wfsv.LogOrderTest.testLogForward since test data is not available
WARNING: Skipping class org.geoserver.wfsv.LogOrderTest.testLogBackwards since test data is not available
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testValidateInvalidRequest since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesPost10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesGet10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesPost11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesGet11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.RollbackTest.testRollbackWfs11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.RollbackTest.testRollbackWfs10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.RollbackTest.testInvalidRollback since test data is not available
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Results :
Tests run: 27, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/wfsv/target/wfsv-2.0.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/wfsv/target/wfsv-2.0.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/wfsv/target/wfsv-2.0.2-SNAPSHOT-sources.jar>
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/wfsv/target/wfsv-2.0.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/wfsv/2.0.2-SNAPSHOT/wfsv-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/wfsv/target/wfsv-2.0.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/wfsv/2.0.2-SNAPSHOT/wfsv-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/wfsv/target/wfsv-2.0.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wfsv/2.0.2-SNAPSHOT/wfsv-2.0.2-SNAPSHOT-sources.jar
[INFO] Building DB2 DataStore Extension
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/db2/target>
[INFO] [resources:resources]
[INFO] snapshot org.geotools.jdbc:gt-jdbc-db2:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-db2:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/db2/target/db2-2.0.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/db2/target/db2-2.0.2-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/db2/target/db2-2.0.2-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/db2/target/db2-2.0.2-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/db2/2.0.2-SNAPSHOT/db2-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/db2/target/db2-2.0.2-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/db2/2.0.2-SNAPSHOT/db2-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/db2/target/db2-2.0.2-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/db2/2.0.2-SNAPSHOT/db2-2.0.2-SNAPSHOT-sources.jar
[INFO] Building ImageMap Output Format
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/imagemap/target>
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/imagemap/target/classes>
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/imagemap/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/imagemap/target/surefire-reports>
T E S T S
Running org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest
Feb 4, 2010 6:59:33 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/imagemap/target/test-classes/org/vfny/geoserver/wms/responses/map/htmlimagemap/test-data>
Feb 4, 2010 6:59:35 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.EncodeHTMLImageMap writeLayers
INFO: Definition Query: Query.ALL
Feb 4, 2010 6:59:35 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapWriter$HTMLImageMapFeatureWriter writeMultiFeature
WARNING: Problems encoding shape: Nothing to encode
Feb 4, 2010 6:59:35 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.EncodeHTMLImageMap encode
INFO: HTML ImageMap generated in 430 ms
Feb 4, 2010 6:59:35 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProduceBasicPolygons
INFO: about to create map ctx for BasicPolygons with bounds ReferencedEnvelope[-2.0 : 2.0, -1.0 : 6.0]
INFO: HTML ImageMap generated in 15 ms
Feb 4, 2010 6:59:35 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProducePolygonsWithHoles
INFO: about to create map ctx for BasicPolygons with bounds ReferencedEnvelope[0.0 : 8.0, 0.0 : 8.0]
INFO: HTML ImageMap generated in -2 ms
Feb 4, 2010 6:59:35 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProducePolygonsWithSkippedHoles
INFO: HTML ImageMap generated in 4 ms
Feb 4, 2010 6:59:35 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProduceReproject
INFO: about to create map ctx for ProjectedPolygon with bounds ReferencedEnvelope[2315725.0 : 2315754.0, 4833303.0 : 4833338.0]
Feb 4, 2010 6:59:36 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.EncodeHTMLImageMap writeLayers
WARNING: UNCAUGHT exception: The coordinate reference system must be the same for all objects.
Feb 4, 2010 6:59:36 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProduceLines
INFO: about to create map ctx for RoadSegments with bounds ReferencedEnvelope[-0.0042 : 0.0042, -0.0024 : 0.0024]
Feb 4, 2010 6:59:36 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.EncodeHTMLImageMap encode
INFO: HTML ImageMap generated in 53 ms
Feb 4, 2010 6:59:36 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapRuleWithFilters
INFO: about to create map ctx for RoadSegments with filter on name and bounds ReferencedEnvelope[-0.0042 : 0.0042, -0.0024 : 0.0024]
Feb 4, 2010 6:59:36 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProducePoints
INFO: about to create map ctx for BuildingCenters with bounds ReferencedEnvelope[0.0010 : 0.0022, 6.0E-4 : 9.0E-4]
INFO: HTML ImageMap generated in 14 ms
Feb 4, 2010 6:59:36 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProduceMultiPoints
INFO: about to create map ctx for BuildingCentersMultiPoint with bounds ReferencedEnvelope[0.0010 : 0.0022, 6.0E-4 : 9.0E-4]
INFO: HTML ImageMap generated in 6 ms
Feb 4, 2010 6:59:36 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProduceCollection
INFO: about to create map ctx for RoadSegments with bounds ReferencedEnvelope[-0.0042 : 0.0022, -6.0E-4 : 9.0E-4]
INFO: HTML ImageMap generated in 21 ms
Feb 4, 2010 6:59:36 AM org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest testMapProduceNoCoords
INFO: about to create map ctx for NamedPlaces with bounds ReferencedEnvelope[2.0 : 6.0, 2.0 : 6.0]
INFO: HTML ImageMap generated in 2 ms
Tests run: 12, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 3.054 sec <<< FAILURE!
Results :
Failed tests:
testMapProduceReproject(org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapTest)
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/imagemap/target/surefire-reports> for the individual test results.
[INFO] Total time: 9 minutes 12 seconds
[INFO] Finished at: Thu Feb 04 06:59:36 EST 2010
[INFO] Final Memory: 54M/139M
