[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x #354
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/354/changes&gt;
Changes:
[aaime] Add copyright headers and follow the proper coding conventions (swapped tabs with spaces)
[...truncated 23996 lines...]
                                        </gsml:CGI_TermValue>
                                    </gsml:proportion>
                                    <gsml:role>interbedded component</gsml:role>
                                </gsml:CompositionPart>
                            </gsml:composition>
                        </gsml:GeologicUnit>
                    </gsml:specification>
                </gsml:MappedFeature>
            </om:result>
        </om:Observation>
    </gml:featureMembers>
</wfs:FeatureCollection>
Mar 17, 2010 5:58:22 AM org.geoserver.test.FeatureChainingWfsTest testFilteringXlinkHref
INFO: WFS filter GetFeature response:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-03-17T05:58:22.408-04:00" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:gsml="http://www.cgi-iugs.org/xml/GeoSciML/2&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:om="http://www.opengis.net/om/1.0&quot; xmlns:ows="http://www.opengis.net/ows&quot;
    xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd http://www.cgi-iugs.org/xml/GeoSciML/2 http://schemas.opengis.net/GeoSciML/geosciml.xsd&quot;&gt;
    <gml:featureMembers>
        <gsml:MappedFeature gml:id="mf1">
            <gml:name>GUNTHORPE FORMATION</gml:name>
            <gsml:positionalAccuracy>
                <gsml:CGI_NumericValue>
                    <gsml:principalValue uom="urn:ogc:def:uom:UCUM:m">200.0</gsml:principalValue>
                </gsml:CGI_NumericValue>
            </gsml:positionalAccuracy>
            <gsml:observationMethod>
                <gsml:CGI_TermValue>
                    <gsml:value codeSpace="http://urn.opengis.net">urn:ogc:def:nil:OGC::missing</gsml:value>
            </gsml:observationMethod>
            <gsml:shape>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.2 52.5 -1.2 52.6 -1.1 52.6 -1.1 52.5 -1.2 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </gsml:shape>
            <gsml:specification>
                <gsml:GeologicUnit gml:id="gu.25699">
                    <gml:description>Olivine basalt, tuff, microgabbro, minor sedimentary rocks</gml:description>
                    <gml:name codeSpace="urn:ietf:rfc:2141">Yaugher Volcanic Group</gml:name>
                    <gml:name>-Py</gml:name>
                    <gsml:occurence xlink:href="urn:cgi:feature:MappedFeature:mf1"/>
                    <gsml:exposureColor>
                            <gsml:value codeSpace="some:uri">Blue</gsml:value>
                    </gsml:exposureColor>
                    <gsml:outcropCharacter>
                            <gsml:value codeSpace="some:uri">x</gsml:value>
                    </gsml:outcropCharacter>
                    <gsml:composition>
                        <gsml:CompositionPart>
                            <gsml:proportion>
                                    <gsml:value codeSpace="some:uri">significant</gsml:value>
                            </gsml:proportion>
                    </gsml:composition>
Mar 17, 2010 5:58:22 AM org.geoserver.test.XYGeomTest testDescribeFeatureType
INFO: WFS DescribeFeatureType response:
<xsd:schema elementFormDefault="qualified" targetNamespace="http://test" xmlns:test="http://test" xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot;&gt;
    <xsd:include schemaLocation="<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/app-schema-mock57356data/featureTypes/test_PointFeature/GeometrylessTest.xsd&quot;/&gt;&gt;
</xsd:schema>
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.316 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.485 sec
Running org.geoserver.test.SRSWfsTest
Mar 17, 2010 5:58:23 AM org.geoserver.test.XYGeomTest testGetFeature
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-03-17T05:58:22.963-04:00" xmlns:gml="http://www.opengis.net/gml&quot; xmlns:ogc="http://www.opengis.net/ogc&quot;
    xmlns:ows="http://www.opengis.net/ows&quot; xmlns:test="http://test" xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot;
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://test <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/app-schema-mock57356data/featureTypes/test_PointFeature/GeometrylessTest.xsd&gt; http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
        <test:PointFeature gml:id="mf1">
            <test:loc/>
        </test:PointFeature>
        <test:PointFeature gml:id="mf2">
            <test:loc/>
Mar 17, 2010 5:58:23 AM org.geoserver.test.SRSWfsTest testGetFeatureContent
INFO: WFS GetFeature&typename=ex:geomContainer response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-03-17T05:58:23.796-04:00" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot; xmlns:ogc="http://www.opengis.net/ogc&quot;
    xmlns:ows="http://www.opengis.net/ows&quot; xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/app-schema-mock57358data/featureTypes/ex_geomContainer/NestedGeometry.xsd&gt; http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
        <ex:geomContainer gml:id="1">
            <ex:geom>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                <ex:nestedGeom gml:id="nested.2">
                    <ex:geom>
                        <gml:Point>
                            <gml:pos>42.58 31.29</gml:pos>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
        <ex:geomContainer gml:id="2">
            <ex:geom>
                <gml:Point>
                </gml:Point>
            </ex:geom>
            <ex:nestedFeature>
                <ex:nestedGeom gml:id="nested.1">
                    <ex:geom>
                        <gml:Polygon>
                            <gml:exterior>
                                <gml:LinearRing>
                                </gml:LinearRing>
                            </gml:exterior>
                        </gml:Polygon>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Mar 17, 2010 5:58:26 AM org.geoserver.test.SRSWfsTest testReproject
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326 response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-03-17T05:58:26.497-04:00" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot; xmlns:ogc="http://www.opengis.net/ogc&quot;
            <ex:geom>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.1999999999634965 52.5 -1.1999999999634965 52.6 -1.099999999966089 52.59999999999999 -1.099999999966089 52.5 -1.1999999999634965 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                        <gml:Point>
                            <gml:pos>42.58000004047607 31.29</gml:pos>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
            <ex:geom>
                <gml:Point>
                </gml:Point>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                        <gml:Polygon>
                            <gml:exterior>
                                <gml:LinearRing>
                                </gml:LinearRing>
                            </gml:exterior>
                        </gml:Polygon>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Mar 17, 2010 5:58:26 AM org.geoserver.test.SRSWfsTest testFilters
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326&featureid=1response:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-03-17T05:58:26.582-04:00" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot; xmlns:ogc="http://www.opengis.net/ogc&quot;
            <ex:geom>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                        <gml:Point>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.595 sec
Results :
Tests in error:
  org.geoserver.test.DataAccessIntegrationWfsTest
Tests run: 22, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 8 minutes 28 seconds
[INFO] Finished at: Wed Mar 17 05:58:27 EDT 2010
[INFO] Final Memory: 50M/144M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/355/changes&gt;
