[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x #376
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/376/&gt;
[...truncated 21409 lines...]
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/classes&gt;
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/surefire-reports&gt;
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/web-gwc-2.0.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/web-gwc-2.0.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/web-gwc-2.0.2-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/web-gwc-2.0.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.0.2-SNAPSHOT/web-gwc-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/web-gwc-2.0.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.0.2-SNAPSHOT/web-gwc-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/web-gwc-2.0.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.0.2-SNAPSHOT/web-gwc-2.0.2-SNAPSHOT-sources.jar
[INFO] Building WFS UI Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target&gt;
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/classes&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wfs.web.WFSAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.401 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/web-wfs-2.0.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/web-wfs-2.0.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/web-wfs-2.0.2-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/web-wfs-2.0.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.0.2-SNAPSHOT/web-wfs-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/web-wfs-2.0.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.0.2-SNAPSHOT/web-wfs-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/web-wfs-2.0.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.0.2-SNAPSHOT/web-wfs-2.0.2-SNAPSHOT-sources.jar
[INFO] Building WCS UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target&gt;
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/classes&gt;
[INFO] snapshot org.geoserver:wcs1_1:2.0.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs1_1:2.0.2-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wcs.web.data.WCSLayerConfigTest
Mar 29, 2010 11:32:57 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Mar 29, 2010 11:32:58 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Mar 29, 2010 11:33:00 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/./target/mock22285data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.649 sec
Running org.geoserver.wcs.web.WCSAdminPageTest
Mar 29, 2010 11:33:03 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/./target/mock22287data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.208 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/web-wcs-2.0.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/web-wcs-2.0.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/web-wcs-2.0.2-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/web-wcs-2.0.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.0.2-SNAPSHOT/web-wcs-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/web-wcs-2.0.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.0.2-SNAPSHOT/web-wcs-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/web-wcs-2.0.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.0.2-SNAPSHOT/web-wcs-2.0.2-SNAPSHOT-sources.jar
[INFO] Building Demoes Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target&gt;
[INFO] snapshot org.geotools:gt-sample-data:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-sample-data:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/classes&gt;
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.demo.MapPreviewPageTest
Mar 29, 2010 11:33:14 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.415 sec
Running org.geoserver.web.demo.DemoRequestsPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.382 sec
Running org.geoserver.web.demo.SRSListPageTest
Mar 29, 2010 11:33:26 AM java.util.prefs.FileSystemPreferences$7 run
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.533 sec
Results :
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.2-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0.2-SNAPSHOT/web-demo-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0.2-SNAPSHOT/web-demo-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0.2-SNAPSHOT/web-demo-2.0.2-SNAPSHOT-sources.jar
[INFO] Building Security UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target&gt;
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target/classes&gt;
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.security.user.NewUserPageTest
Mar 29, 2010 11:33:36 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 7.966 sec <<< FAILURE!
Running org.geoserver.web.security.user.UserListPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.388 sec
Running org.geoserver.web.security.data.DataAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.347 sec
Running org.geoserver.web.security.data.NewRulePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.039 sec
Running org.geoserver.web.security.ConfirmRemovalUserPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.364 sec
Running org.geoserver.web.security.user.EditUserPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.463 sec
Running org.geoserver.web.security.ConfirmRemovalServicePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.31 sec
Running org.geoserver.web.security.ConfirmRemovalDataAccessRulePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.298 sec
Running org.geoserver.web.security.service.ServiceAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.762 sec
Running org.geoserver.web.security.catalog.CatalogModePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.587 sec
Results :
Tests in error:
  testFill(org.geoserver.web.security.user.NewUserPageTest)
Tests run: 18, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 6 minutes 20 seconds
[INFO] Finished at: Mon Mar 29 11:33:50 EDT 2010
[INFO] Final Memory: 46M/115M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/377/&gt;
