See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/402/changes>
Changes:
[ang05a] - Caters for polymorphism filters.
- Caters for feature chaining mapping with mappingName.
- Refactors feature chaining filters.
[riniangreani] Updated test comments with test mapping file changes.
[riniangreani] - Update tests for feature chaining filter handling where multiple mapping for the same type exists.
- Update tests for polymorphism feature handling.
[...truncated 24277 lines...]
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:128)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: org.geotools.data.DataSourceException: Feature type exposureColor not found. Has the data access been registered in DataAccessRegistry? Available: [http://www.cgi-iugs.org/xml/GeoSciML/2:MappedFeature, http://www.cgi-iugs.org/xml/GeoSciML/2:ControlledConcept, http://www.cgi-iugs.org/xml/GeoSciML/2:CompositionPart, http://www.cgi-iugs.org/xml/GeoSciML/2:CGI_TermValue, http://www.cgi-iugs.org/xml/GeoSciML/2:GeologicUnit, http://example.com:SimpleContent, http://example.com:FirstParentFeature, http://example.com:SimpleContent, http://example.com:SecondParentFeature, http://www.opengis.net/om/1.0:Observation\]
at org.geotools.data.complex.DataAccessRegistry.throwDataSourceException(DataAccessRegistry.java:169)
at org.geotools.data.complex.DataAccessRegistry.getFeatureSource(DataAccessRegistry.java:136)
at org.geotools.data.complex.NestedAttributeMapping.getFeatures(NestedAttributeMapping.java:215)
at org.geotools.data.complex.DataAccessMappingFeatureIterator.setAttributeValue(DataAccessMappingFeatureIterator.java:361)
at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:655)
at org.geotools.data.complex.AbstractMappingFeatureIterator.next(AbstractMappingFeatureIterator.java:192)
... 71 more
Tests run: 10, Failures: 8, Errors: 0, Skipped: 0, Time elapsed: 4.328 sec <<< FAILURE!
Running org.geoserver.test.XYGeomTest
Apr 7, 2010 3:55:31 AM org.geoserver.test.FeatureChainingWfsTest testAnyType
INFO: WFS GetFeature&typename=om:Observation response:
<ows:ExceptionReport version="1.0.0" xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.lang.RuntimeException: org.geotools.data.DataSourceException: Feature type exposureColor not found. Has the data access been registered in DataAccessRegistry? Available: [http://www.cgi-iugs.org/xml/GeoSciML/2:MappedFeature, http://www.cgi-iugs.org/xml/GeoSciML/2:ControlledConcept, http://www.cgi-iugs.org/xml/GeoSciML/2:CompositionPart, http://www.cgi-iugs.org/xml/GeoSciML/2:CGI_TermValue, http://www.cgi-iugs.org/xml/GeoSciML/2:GeologicUnit, http://example.com:SimpleContent, http://example.com:FirstParentFeature, http://example.com:SimpleContent, http://example.com:SecondParentFeature, http://www.opengis.net/om/1.0:Observation\]
Feature type exposureColor not found. Has the data access been registered in DataAccessRegistry? Available: [http://www.cgi-iugs.org/xml/GeoSciML/2:MappedFeature, http://www.cgi-iugs.org/xml/GeoSciML/2:ControlledConcept, http://www.cgi-iugs.org/xml/GeoSciML/2:CompositionPart, http://www.cgi-iugs.org/xml/GeoSciML/2:CGI_TermValue, http://www.cgi-iugs.org/xml/GeoSciML/2:GeologicUnit, http://example.com:SimpleContent, http://example.com:FirstParentFeature, http://example.com:SimpleContent, http://example.com:SecondParentFeature, http://www.opengis.net/om/1.0:Observation\]</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Apr 7, 2010 3:55:31 AM org.geoserver.test.FeatureChainingWfsTest testFilteringXlinkHref
INFO: WFS filter GetFeature response:
</ows:Exception>
Apr 7, 2010 3:55:32 AM org.geoserver.test.XYGeomTest testDescribeFeatureType
INFO: WFS DescribeFeatureType response:
<xsd:schema elementFormDefault="qualified" targetNamespace="http://test" xmlns:test="http://test" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:include schemaLocation="<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/app-schema-mock48392data/featureTypes/test_PointFeature/GeometrylessTest.xsd"/>>
</xsd:schema>
Apr 7, 2010 3:55:32 AM org.geoserver.test.XYGeomTest testGetFeature
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-04-07T03:55:32.125-04:00" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc"
xmlns:ows="http://www.opengis.net/ows" xmlns:test="http://test" xmlns:wfs="http://www.opengis.net/wfs" xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://test <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/app-schema-mock48392data/featureTypes/test_PointFeature/GeometrylessTest.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMembers>
<test:PointFeature gml:id="mf1">
<test:loc/>
</test:PointFeature>
<test:PointFeature gml:id="mf2">
<test:loc/>
</gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.518 sec
Running org.geoserver.test.SRSWfsTest
Apr 7, 2010 3:55:33 AM org.geoserver.test.SRSWfsTest testGetFeatureContent
INFO: WFS GetFeature&typename=ex:geomContainer response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-04-07T03:55:33.179-04:00" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc"
xmlns:ows="http://www.opengis.net/ows" xmlns:wfs="http://www.opengis.net/wfs" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/app-schema-mock48394data/featureTypes/ex_geomContainer/NestedGeometry.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<ex:geomContainer gml:id="1">
<ex:geom>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
<gml:posList>-1.2 52.5 -1.2 52.6 -1.1 52.6 -1.1 52.5 -1.2 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested.2">
<ex:geom>
<gml:Point>
<gml:pos>42.58 31.29</gml:pos>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
<ex:geomContainer gml:id="2">
<ex:geom>
<gml:Point>
</gml:Point>
</ex:geom>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested.1">
<ex:geom>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
Apr 7, 2010 3:55:33 AM org.geoserver.test.SRSWfsTest testReproject
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326 response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-04-07T03:55:33.591-04:00" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc"
<ex:geom>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
<gml:posList>-1.1999999999634965 52.5 -1.1999999999634965 52.6 -1.099999999966089 52.59999999999999 -1.099999999966089 52.5 -1.1999999999634965 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:geom>
<gml:Point>
<gml:pos>42.58000004047607 31.29</gml:pos>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
<ex:geom>
<gml:Point>
</gml:Point>
</ex:geom>
<ex:nestedFeature>
<ex:geom>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
Apr 7, 2010 3:55:33 AM org.geoserver.test.SRSWfsTest testFilters
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326&featureid=1response:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-04-07T03:55:33.638-04:00" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc"
<ex:geom>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:geom>
<gml:Point>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.501 sec
Results :
Failed tests:
testPolymorphism(org.geoserver.test.PolymorphismWfsTest)
testFirstValueFilters(org.geoserver.test.PolymorphismWfsTest)
testSecondValueFilters(org.geoserver.test.PolymorphismWfsTest)
testAnyTypeFilters(org.geoserver.test.PolymorphismWfsTest)
testMappingNameFilters(org.geoserver.test.PolymorphismWfsTest)
testGetFeatureContent(org.geoserver.test.FeatureChainingWfsTest)
testGetFeature(org.geoserver.test.FeatureChainingWfsTest)
testComplexTypeWithSimpleContent(org.geoserver.test.FeatureChainingWfsTest)
testGetFeaturePropertyFilter(org.geoserver.test.FeatureChainingWfsTest)
testGetFeatureWithFeatureIdFilter(org.geoserver.test.FeatureChainingWfsTest)
testGetFeatureWithGmlObjectIdFilter(org.geoserver.test.FeatureChainingWfsTest)
testAnyType(org.geoserver.test.FeatureChainingWfsTest)
testFilteringXlinkHref(org.geoserver.test.FeatureChainingWfsTest)
Tests run: 29, Failures: 13, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[INFO] Total time: 8 minutes 40 seconds
[INFO] Finished at: Wed Apr 07 03:55:34 EDT 2010
[INFO] Final Memory: 50M/125M
Failed to send e-mail to ang05a because no e-mail address is known, and no default e-mail domain is configured
Failed to send e-mail to riniangreani because no e-mail address is known, and no default e-mail domain is configured
